Old 10-01-2012, 02:21 PM   #5776
NovaMoto
Oddometer: 79
+500 for RR parts & service!
NovaMoto is offline   Reply With Quote
Old 10-01-2012, 02:21 PM   #5777
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,205
Originally Posted by Olleg View Post
How about handling, did you notice difference between them (safari vs rally raid)?
Comparing to the stock, is it a big difference?
RR is 9 liters I think while Safari is 12 iirc. thats about 15 lbs vs 22 lbs (fuel weight) pluss a few more for the weight of the tanks and hardware. i did not notice a lot of handling difference between the two ore even over stock. The safari tank makes its presence known as it is a bit wider where the RR's feel a little more stream lined.
Seth S
Husaberg tank for sale: HERE
Seth S is online now   Reply With Quote
Old 10-01-2012, 02:50 PM   #5778
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 817
Splitting hairs... The existing RR tanks are morel like 9.5l. Go with the new RR tanks. it will be worth the wait. I got to sit on the prototype and it is noticeably narrower then the originals because it doesn't use the side covers. Also, i hear they hold more fuel then the originals.
When they are empty, i find the RR tanks don't add noticeable weight.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting.
Open-Exporers----->A collection of travel blogs
Old 10-01-2012, 03:06 PM   #5779
Gordy
Team Listo
Gordy's Avatar
Oddometer: 18,303
Are those the ones that are currently on their web-site and have an availability in 4-6 weeks?
Gordy is offline   Reply With Quote
Old 10-01-2012, 03:33 PM   #5780
motoged
motoged's Avatar
Oddometer: 530
Originally Posted by The Letter J View Post
Did you use an EXC front sprocket? They fit over the countershaft splines but are narrower which could take pressure off the seal? Next guess would be that your chain is just too tight? How many miles are on the bike? It may just be time to replace the seal anyway, they are cheap and easy to change anyway.
When mine started leaking it just needed the $1 o-ring behind the sprocket spacer replaced, the seal itself is only ~$7.
Riders,
Aftermarket sprockets that are not KTM-specific will often set up a leak for a few reasons:
1) The backside of the aftermarket sprocket ( which is the point of contact on the spacer collar) does not have an "extruded collar" (for lack of a better description) that puts pressure on the spacer and subsequently the o-ring, thus not making a seal at the o-ring point of contact;
2) The seal is leaking and might require a replacement....;
3) the sprocket doesn't have to make contact with the seal....just the metal collar that holds the o-ring;
4) You are not supposed to re-use the cupped washer, as one use renders it flatter and less efficient in that pressure function on the spacer and o-ring (if you must use a used cupped washer, place it over a large socket, place another smaller socket against the washer and give it a couple or more whacks so as to "re-cup" the washer.
I learned all this on my 450 EXC.....and suspect it is true for the 690 countershaft setup.
If I am mistaken, I am sure one of you kind souls will make the mistake evident
Ged Schwartz
Kamloops , BC
'96 GS 1100
'04 450 EXC
'09 690 EXC
Baja '05
Baja 06/07
Baja 08/09
BC Alpine Single Track
motoged is offline   Reply With Quote
Old 10-01-2012, 03:47 PM   #5781
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Really? I did, especially in the woods. The front end felt heavier when turning in but it's acceptable for a long distance bike.
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-01-2012, 04:49 PM   #5782
Hooked
Hooked's Avatar
Oddometer: 8
Hard starting when sitting awhile
I don't know where to turn to figure the hard starting on my 08. If I take it to the dealer they will charge me $100 plus an hour to tell me they can't find a problem. I have read of this problem but have not found what the cure is. With 21K Kms it should still have lots of life left. Any help from the group? It doesn't happen all the time but often enough it starting to concern me.
Hooked is offline   Reply With Quote
Old 10-01-2012, 08:20 PM   #5783
modeselector
Common as muck
modeselector's Avatar
Oddometer: 482
Not too sure on reliable delivery date with RR but I'm hoping they take the time to really get the fitment and installation documentation right. Looks promising.
modeselector is offline   Reply With Quote
Old 10-01-2012, 08:26 PM   #5784
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
Originally Posted by motoged View Post
Riders,
Hey mate
- mine was # 1 on your list I grabbed the old sprocket outa the bin and the new one is a couple mm thinner :-{
B2 screwed with this post 10-02-2012 at 12:55 AM
B2 is offline   Reply With Quote
Old 10-01-2012, 10:57 PM   #5785
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 585
Originally Posted by beaney View Post
Yeah whatever, carry on, I've never raced a 690 and know nothing about them!!!!!!!!!!!!!!
OH by the way you have to change the oil pressure rgeultor in the back of the engine for a temp regulator plus add the pipes, I prefer the more robust cooler from the 690rr mounted behind the fairing. I personally dont bother with an oil cooler any more because i change the oil after every 10 hours of racing like on the Tuareg and Maroc rallies, the 690 holds more than enough oil for a days racing.
If you want a cheap kit then I've got one in my scrap pile of stuff that was no good for racing.
That's not what I mean. My point is I wasn't going to mount it in the location KTM want's it mounted. I realize it will probably need custom oil lines. My initial question is more about how it plumbs into the oil system on the bike.
If possible I would like to mount it underneath a baja designs 8 inch round headlight, or some close facsimile there of.
tattewell is offline   Reply With Quote
Old 10-01-2012, 11:34 PM   #5786
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 173
Take a look at page 63 of the RR spare parts manual here. Shows where it plumbs in. The KTM lines and cooler are not cheap if you go this route.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 10-02-2012, 08:54 AM   #5787
Seth S
Seth S's Avatar
Oddometer: 3,205
I have not ridden the bike too much in the woods since I put the tanks on. I did notice the weight of the full Safari tank in the woods but I didn't feel it was a major hinderence to handling. It has been quite a while since I have ridden the bike without any tanks on the front so i might notice a difference with them off.
Seth S
Old 10-02-2012, 09:16 AM   #5788
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Excellent Information
Riders,
This is good info for all of us. BTW I have a KTM 14 tooth countershaft sprocket and, when fitting it, I noticed that the 15 tooth OEM sprocket has (I am guessing medium durometer) rubber washer type shock absorbers glued on to both sides. I think this may have been commented on somewhere before. My 14 tooth KTM c/s did not have these but seems to be working just fine and keeping the oil in. Hence, it apparently has the aforementioned extruded collar.
On another subject, could you please re-post those gruesome photos of your broken leg bone and scar. As I recall, one is a photo the hideous scar and the other of the X-Ray showing the break. I have some very annoying small children in the neighborhood and I want to print these and put them on our front door in order to scare the begesus out of them on Halloween.
Cheers,
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 10-02-2012, 10:02 AM   #5789
motoged
motoged's Avatar
Oddometer: 530
Cheers,
NB,
As you well know, installation of countershaft sprockets can be done easily using only commercial grade Velcro. No need for torque specs, o-rings or cupped washers.....and certainly no need for that cute rubber (latex???) skirt that the KTM unit wears....minimal function, I am sure.
As for the request..... :
I assured the doctor that I only needed Velcro instead of all that fancy schmancy titanium and stuff....he just rolled his eyes .....
Ged Schwartz
Kamloops , BC
'96 GS 1100
'04 450 EXC
'09 690 EXC
Baja '05
Baja 06/07
Baja 08/09
Old 10-02-2012, 10:20 AM   #5790
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
... I did notice the weight of the full Safari tank in the woods but I didn't feel it was a major hinderence to handling. It .
Same here with the Rally Raid.
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Times are GMT -7.   It's 07:59 AM.
