Old 10-08-2012, 12:43 PM   #5896
ktmmitch
Oddometer: 576
Originally Posted by The Letter J View Post
I know that it is too early in development to put a price tag on it, but do you have a rough ballpark figure for price? I have already had my R shock modified for 285mm travel and had extensive valving work done and just cannot seem to get the results I'm after, it's either too soft on the big hits but perfect everywhere else or too rough on the little hits with light bottoming on the big ones. I'm getting close to revalving AGAIN but I have been interested in the ttx rear since rumor started about it for the 690 a couple years ago.
I was having similar issues with the front end and finally switched to 300mm twin chamber forks and voila! problem solved! I'm hoping that the ttx rear has similar results.
Not yet,it depends on final design of the shock top,but it will be around 900/ $1450,same as std TTS units.
Glad the change to Twin Chamber sorted your problems,We have had a lot of success with SXS & Cone Valve Forks on the 690's.
ktmmitch is offline   Reply With Quote
Old 10-08-2012, 04:22 PM   #5897
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
+1 on that score, the Twin Chambers transformed the 690.
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-09-2012, 04:48 PM   #5898
daveknievel
daveknievel's Avatar
Oddometer: 400
What twin chamber forks should i look for? Can i revalve for supermoto use? I want to use my 09 enduro R for some wera clubman racing next year. But i still ride offroad in the winter. Would it be better to revalve my forks and use this new shock, or swap it out with twin chambers? Just trying to find my best option. I also use this bike on the street with a supermoto setup. But i feel i am out riding the suspension at the track and the street. Thanks for any replys.
daveknievel is offline   Reply With Quote
Old 10-09-2012, 05:58 PM   #5899
crankshaft OP
crankshaft's Avatar
Oddometer: 14,003
This is what I have on my 690....
http://www.ktm-parts.com/14187D1402.html
Just say'IN
Old 10-10-2012, 02:02 AM   #5900
daveknievel
Oddometer: 400
Kind of pricey. How much better are those compared to ones revalved by someone like slavens or racetech?
Old 10-10-2012, 07:00 AM   #5901
crankshaft OP
crankshaft's Avatar
Oddometer: 14,003
Well, suspension is your connection to the ground and it makes all the difference in the world. I guess you need to tell me how important it is to you.
I suck at riding and need all the help I can get, so its money well spent.
Just say'IN
Old 10-10-2012, 07:23 AM   #5902
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,442
A full suspension upgrade on a 690 could be close to $3000 once you buyt the fork and rear shock...possibly more for valving and springs. Sounds expensive but it will be the best upgrade you could ever do.
Seth S
Seth S is offline   Reply With Quote
Old 10-10-2012, 07:31 AM   #5903
Leviathan
Tenerider
Leviathan's Avatar
Oddometer: 142
I got a weird problem.
In the last couple of days, the bike's having problems starting when cold. This seems to be something electrical, though I have no idea where to start troubleshooting it.
When I hit the starter button the bike does what seems to be like a quarter of a crank and then it's like the bike is restarting (the displays restarts and the fuel pump primes).
If I keep the starter button pressed, this will go on continuously.
When this happens, I turn the switch on and off, and after a couple of times the bikes starts just fine.
Any ideas where to look before I take the bike down to the dealer?
Leviathan is offline   Reply With Quote
Old 10-10-2012, 07:41 AM   #5904
ramjet
ramjet's Avatar
Oddometer: 2,131
What year is the bike?
Coffee first. Then your mundane socialist bullshit.. Lenny Bruce
ramjet is offline   Reply With Quote
Old 10-10-2012, 08:04 AM   #5905
Leviathan
Tenerider
Leviathan's Avatar
Oddometer: 142
2010 Enduro R with 20,000 Kilometers
Old 10-10-2012, 08:17 AM   #5906
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 902
[QUOTE=Seth S;19786650]A full suspension upgrade on a 690 could be close to $3000 once you buyt the fork and rear shock...possibly more for valving and springs. Sounds expensive but it will be the best upgrade you could ever do.[/QUOTE]
I dissagree Seth..........fixing the fuel delivery issues is top on my list right now
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 10-10-2012, 08:19 AM   #5907
Seth S
Seth S's Avatar
Oddometer: 4,442
[QUOTE=bobzilla;19786951]
assuming your bike runs fine of course the suspension upgrades will be the most beneficial.
Seth S
Old 10-10-2012, 08:33 AM   #5908
crankshaft OP
crankshaft's Avatar
Oddometer: 14,003
Sounds like a weak battery to me
Just say'IN
Old 10-10-2012, 09:37 AM   #5909
Leviathan
Tenerider
Leviathan's Avatar
Oddometer: 142
Thanks. I'll check that out.
Any other ideas are welcome.
On another subject- is it possible to take out the spark plug without removing the airbox?
I'm thinking about buying this little gizmo, but I'm not sure if it'll be less work than to pump a tire full of air by hand.
Old 10-10-2012, 09:52 AM   #5910
rudyunknown
rudyunknown's Avatar
Oddometer: 723
Brake Lever
Hi guys
So i have this weird problem on the 690, i have a giant loop bag for the adventure ride...what that does is push me further in the seat...so when i am sitting on the bike with my legs on the footpegs, the feet is at an angle to the brake pedal....
and so when i try to apply the rear brake, i have to either lift my feet and readjust to brake or if in the same position i just end up locking the rear brakes....
is there a way to move the rear pedal further out maybe by few inches....i am also trying to get a tail rack so that i can try to move the giant loop further out...
Rudy
Indian among Americans
Husky 250 "hit that tree"
Adventure bike KTM 690e
Vstrom 1000 For everything else
rudyunknown is offline   Reply With Quote
Times are GMT -7.   It's 01:59 AM.
