Old 09-09-2011, 11:20 PM   #46
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 982
Originally Posted by Ryman View Post
Took me a while to catch on, but I'm in!
I wondered why I lost about 1000 posts!
Well, look at it this way: we'll have your 1000 post celebration in the WUNDERFEST
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 09-10-2011, 05:02 AM   #47
Tbone675
Tbone675's Avatar
Oddometer: 118
where can i find a cheap bar riser? im 6'2" and am hunched over when standing.
lol my post count is back to 1? i know i posted in other threads besides the old 690 thread...
2009 KTM 690R
2010 Triumph Daytona 675
SE
Tbone675 is offline   Reply With Quote
Old 09-10-2011, 05:28 AM   #48
SidewinderX
Hey, watch this!
SidewinderX's Avatar
Oddometer: 1,152
SWEET!!!!
I got my Tune ECU update yesterday evening and it is a completely different bike now. A pure joy to ride!
Daniel
What would you attempt to do in life if you knew that you could not fail?
SidewinderX is offline   Reply With Quote
Old 09-10-2011, 05:49 AM   #49
Tbone675
Tbone675's Avatar
Oddometer: 118
Originally Posted by SidewinderX View Post
SWEET!!!!
what mods do you have and what map did you choose?
2009 KTM 690R
SE
Old 09-10-2011, 06:12 AM   #50
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 190
Cheap solution here: http://www.ktmtwins.com/ktm-690-part...ebar-riser-kit
My Rally Raid solution here: http://www.rally-raidproducts.co.uk/...r-scott-ohlins - should be available from KTM Twins in USA
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 09-10-2011, 06:16 AM   #51
ABuck99
0.0
ABuck99's Avatar
Oddometer: 627
Originally Posted by FriedDuck View Post
Get the suspension back yet? I wanna hear a ride report!
Yes I did get it back and then it sat on my work bench for 10days till I finally got time to reinstall it- and have only ridden it up & down the street to make sure everything was working right. I may head out Monday to ride - will let you know.
Basic details-
It was Javiers level 3 suspension package- then w/ 90nm rear spring for my fat arse, .50 front springs and the travel increased both ends from 250mm to 268mm.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 09-10-2011, 08:56 AM   #52
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I picked up a set of these, Bar Riser 1-1/8"x30mm. From these guys. http://www.wheelingcyclesupply.com/s...13/index.shtml
I am at one with my duality.
Barman is offline   Reply With Quote
Old 09-10-2011, 11:27 PM   #53
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 768
Another request for advice please. Best place for clutch and brake levers? OEM or alternate brand? Got my 08 690E yesterday . Replaced the grips and fitted the rego plate is all so far. will fit the safari tank and pannier racks this week ready for a ride on the w/e.
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 09-11-2011, 01:17 PM   #54
Bill the Bong
Supern00ba
Oddometer: 982
Suspension
My 2011 R has been twitchy on fast gravel from the word go. When I fitted a toolbag on the tail weighing a couple of Kg's, it deteriorated to a point where my skill levels were not cutting it anymore.
I revisted the rear sag, as that was the only variable which effectively changed. I found that to get in the 70 - 80 mm prescribed sag range, static sag was only about 6mm. Almost 75% of the shock's pre-load is used.
I know that I need a heavier spring.
Q1: KTM optional or Superplush (via KTM Twins). Any other options?
Q2: Will I need to go heavier on the fork springs as well or do they have a higher rate than the shock spring stock? Or should I rather start of with an adjustable pre-load fork top to fine tune the front sag?
Q3: Has anybody got a departure point for static and rider sag for the front? Its not stated in the manual (likely because its not pre-load adjustable as delivered).
Help me tame my ride!
Old 09-11-2011, 02:08 PM   #55
DirtJack
DirtJack's Avatar
Oddometer: 1,600
The earlier models had adjustable offset cams on the steering stem (I presume the current model has this). The factory setting gives more offset resulting in quicker steering. Reducing the offset increases trail and improves stability at speed. The triple clamp must be disassembled (not difficult) to change the setting. You can check to see if the 11's have the feature by removing the cap over the stem (don't remove the pinch bolt). You should be able to see the top cam and if a dot is in the rear, yours is set at max offset (less trail). You may prefer more trail. Of course, as you note, proper sag affects trail as well.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 09-11-2011 at 07:08 PM
DirtJack is offline   Reply With Quote
Old 09-11-2011, 02:38 PM   #56
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,647
Originally Posted by DirtJack View Post
The earlier models had adjustable offset cams on the steering stem (I presume the current model has this). The factory setting gives more offset resulting in quicker steering. Reducing the offset increases trail and improves stability at speed. The triple clamp must be dissambled (not difficult) to change the setting. You can check to see if the 11's have the feature by removing the cap over the stem (don't remove the pinch bolt). You should be able to see the top cam and if a dot is in the rear, yours is set at max offset (less trail). You may prefer more trail. Of course, as you note, proper sag affects trail as well.
DirtJack, Outstanding explanation of the offset/trail adjustability on some 690s. Maybe you could snap a couple of pics and post up to be used in the HOW website. Would probably help some of us non-suspension guys.
Anyway...good stuff for sure, and much appreciated.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is online now   Reply With Quote
Old 09-11-2011, 04:41 PM   #57
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,722
who prescribes 80mm sag? we set ours around 105mm
Seth S
Seth S is offline   Reply With Quote
Old 09-11-2011, 06:45 PM   #58
Velociraptor
TrackBum
Oddometer: 1,128
My turn
My 2009 690r started cutting out along the highway today and finally just outright quit on me. My first KTM troubleshoot along the roadside. Probably not fuel related at fuel pump was priming, a good shot of fuel came out near the injector, and the injector was giving a good spray. Had a spare injector so threw it on and made no difference. Checked a lot of electrical stuff and found no obvious fault. Eventually bike started running again so made it about 40 easy miles before it started trying to die again but would catch and keep running until it eventually died again on city streets. Pulled stuff off again, got it going, rode 2 ft and died again. Pulled stuff off AGAIN and started wiggling wires while I tried to start it. Seems to be related to something in or around the big wiring bundle slightly to the front and right and below the spark plug. I started wiggling that and the bike would try and start then die as I moved it. It finally started for good and after that when I moved the bundle it had no effect. Bike ran fine the 10 miles left to home. Time to strip the bike and see if I can find the exact problem.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 09-11-2011, 07:17 PM   #59
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Some of your experiences sound a bit like mine, particularly the part about the bike seeming to fix itself. See:
my FI issues. I don't know if I really have it fixed because of the intermittent nature of the problem. I'm still not sure I can trust her to get me back if I go out by myself.
2008 KTM 690 Enduro
Old 09-11-2011, 07:51 PM   #60
Velociraptor
TrackBum
Oddometer: 1,128
Maybe similar but the fuel pump was pressurizing every time and it seems like moving that wiring loom around had a direct effect....maybe! I know the feeling of not knowing exactly what it might be. I may buy one of those aftermarket pumps just to cover the bases. For now the bike is parked and I will have a look next weekend.
2014 KTM EXC 500
2002 RC51 SOLD
Times are GMT -7.   It's 07:40 PM.
