Old 10-14-2012, 07:41 PM   #5986
Gordy
Team Listo
Gordy's Avatar
Oddometer: 18,300
I hate to bring this up...but.
Which lightweight battery is working out the best now and where to buy them?
I am going crazy reading about Shorai and Shorai problems.
I need one, pronto.
Gordy is offline   Reply With Quote
Old 10-14-2012, 07:54 PM   #5987
Sutherngintelmen
on the mend
Sutherngintelmen's Avatar
Oddometer: 977
I believe antigravity is the rage nowadaze.
I need one, pronto.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All posted pics < 6/30/12 deleted courtesy of Apple
Sutherngintelmen is offline   Reply With Quote
Old 10-14-2012, 07:57 PM   #5988
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 3,856
Originally Posted by thorinoakenshield View Post
nice job, eagle eyes! hahaha!
i was pissed when i did that. it didn't take much, did it? i was like "wtf!!??"
you live and learn,and there's no serious damage.
it just took me by surprise and i've never seen a nilos ring before on any other bike i've had.
it must be a ktm thing.
i had to google what it was.
good info
and here
The same problem is with blackSP's bike, and that's an 2012.
So you were once able to remove the spacer?
Yeah, I was pissed too when I did it. That thing bent like it was made out of putty. I used VERY little pressure.
It used to wiggle out without much trouble at all. I suspect mine has a groove worn in the spacer that is catching on the dust seal.
I'm betting if we check a service manual, we are supposed to lube it everytime we disassemble the rear wheel...
BK.RD.RNR is online now   Reply With Quote
Old 10-14-2012, 11:23 PM   #5989
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 858
Originally Posted by Sutherngintelmen View Post
Given y'all's posts, my attack order is: Injector clean. Battery - maybe low volts? - oem @ 4 years. CA fuel pump. ECU.
I think you've got an electrical problem. Either a short somewhere or bad connection. Have you checked out the plug lead, mine was acting up like yours a while back so I took the plug connector off, cut 10mm off the coil lead and put it back together, ran fine after that...might be worth a crack
"You cannot harm me...my wings are like shields of steel" - Batfink
My KTM 690
Night Falcon is offline   Reply With Quote
Old 10-14-2012, 11:25 PM   #5990
Night Falcon
Adventure NZL
Oddometer: 858
I need one, pronto.
don't know what everyone else is using but I repaced my battery with a motobat http://motobatt.com/ works well and well priced.
My KTM 690
Old 10-15-2012, 12:48 AM   #5991
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 519
Originally Posted by LukasM View Post
If you are not going to do ride in deep ruts or between big rocks the Fastway Adventure pegs are fantastic for giving stable and comfortable footing all the time, even better than the KTM Rally Replica pegs.
For enduro type riding both are a bit too wide IMO.
Originally Posted by BK.RD.RNR View Post
I like my Pivot Pegz. you can configure them to lower 10mm, and move rearward 5mm. They cost about the same as the KTM Hardparts pegs, that give the same amount of relocation. I have not put hands on the hardparts pegs, but I think the PPegz mounting system is better. IMO.
Originally Posted by Oldbear View Post
If you need even more legroom Motobau makes "Bear traps" which are 3 cm lower than the originals:
http://www.motobau.de/shop/product_i...asten-690.html
Thanks for all the help. I'm setting the bike up for rally use and need to open up the cock-pit a bit after I fitted a Scotts damper. That required fitting the bar in the rear position to centre it over the steering stem. Now the bars are too close to me when standing. Also had 3 knee operations, so a slightly lower peg set-up will be better than an adjustable riser solution.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 10-15-2012, 09:11 AM   #5992
Noyah
poser
Noyah's Avatar
Oddometer: 258
Finally got my hands on a decent solution for extra petrol
KTM 690 Enduro R
--> My Movies <--
Noyah is online now   Reply With Quote
Old 10-15-2012, 11:02 AM   #5993
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 398
Yeah, you ought to lube it and get the grime out...
I'm at a lost as to how I'd be able to apply equal pulling force on all sides of the spacer, without mutilating the rubbing bearing or nilos ring (only $7,btw).
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650
"In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read
thorinoakenshield is online now   Reply With Quote
Old 10-15-2012, 12:20 PM   #5994
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 316
I used a small blunt punch from the backside of the spacer and just lightly tapped it at an angle (in the groove between the spacer and the bearing), alternating sides. The spacer slowly walked out without gouging/scratching/prying/damaging anything.
The Letter J is offline   Reply With Quote
Old 10-15-2012, 02:18 PM   #5995
motoged
motoged's Avatar
Oddometer: 528
What he said....
Ged Schwartz
Kamloops , BC
'96 GS 1100
'04 450 EXC
'09 690 EXC
Baja '05
Baja 06/07
Baja 08/09
BC Alpine Single Track
motoged is offline   Reply With Quote
Old 10-15-2012, 03:32 PM   #5996
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 3,856
Keep in mind.. IIRC, the rubber dust seal underneath has a space between it and the bearings. If you are going to clean behind the spacer, you will probably have to remove/ replace the dust seal to do so..
Old 10-15-2012, 04:27 PM   #5997
Sutherngintelmen
on the mend
Oddometer: 977
Thanks for that - will add it to check out.
Old 10-15-2012, 05:26 PM   #5998
Pundy
Oddometer: 329
LED relay goes kaput!
I installed some new LED signals front and rear. When I finally plugged in my new Sicass relay http://sicassracing.com/store/produc...signal_flasher it flashed quickly for a few seconds then stopped working.
Do I have a bad relay, or might it be something else?
Pundy is offline   Reply With Quote
Old 10-15-2012, 06:15 PM   #5999
Kirkster
Parts Murderer
Oddometer: 162
I'm changing my stock tires out.
Should I be able to remove the spacer in the rear sprocket?
When I spin the spacer, it feel kind of grimey. I want to take it out and re-grease it, of course.
I can't remove the dang thing. I dont want to pry it out because the sorounding metal "nilos ring " is very soft.
On other bikes I have I can, so I was wondering....but in the 690 owners manual, it doesnt mention removing and inspecting that particular spacer.
Maybe it was overtorqued in the factory? Should I go to my crappy dealer? Doubtful there is any real problem.....besides being anal retentive...just wondering.
Mine fell out when I was changing the tire... but then again so did all of rubber bits in my cush drive...
I don't crash. I burn in and make a crater....
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
1972 Honda CL125 - Retired but ready to ride in AZ
Kirkster is offline   Reply With Quote
Old 10-15-2012, 06:35 PM   #6000
ramjet
ramjet's Avatar
Oddometer: 1,671
Interesting. Will standby for further development.
Qui Desiderant Pacem Preparate Bellum
ramjet is offline   Reply With Quote
Times are GMT -7.   It's 05:42 AM.
