10-17-2012, 03:34 PM
#6016 |
Still trying
Oddometer: 659
Air filter discussion
There is some recent airfilter discussion here too
http://www.advrider.com/forums/showt...57040&page=260
Cheers Graham |
10-19-2012, 06:04 PM
#6017 |
Oddometer: 542
What kind of oil do you think is best?
![]() ![]() ![]() No recent posts.....have we solved all the 690 issues? C'mon, somebody out there have a complaint or a pic of their new rally fairing held on by industrial velcro?
Ged Schwartz Kamloops , BC '96 GS 1100 '04 450 EXC '09 690 EXC Baja '05 Baja 06/07 Baja 08/09 BC Alpine Single Track |
10-19-2012, 06:16 PM
#6018 |
Dirty Old Man
Oddometer: 791
waiting on Crank. dont want to give up on the 690 but................
Im sure this will fix the problems............throwing money away anyway if I dumnp it now ![]() and there is nothing out there I want to replace it with...........bikes and beer are my only vises that cost $$ so I can have almost anything ....just dont see it.
Ride the DEZ 05 FE 550 Husaberg plated 09 KTM 690 |
10-19-2012, 06:47 PM
#6019 | |
lost in the 690 mega
Oddometer: 351
front tire quandry
I have been through a metric shit ton of tires on my bikes and usually once I find a set that works for a particular bike, that is all I will ever buy for it again. Here lies the problem: I've run all sorts of non-dot tires on the 690 and the michelin HP4 front was the only one I ever truly liked (yes Bobzilla I ran an m12 already and it chunked like none other). I've run quite a few DOT fronts including: mt21, d606, k760, motoz h/t, motoz s/t, motoz x-circuit and probably more that I can't remember... ALL of the DOT tires sucked! Being that my current motoz s/t (my least favorite tire in any on or offroad situation) is ready for the dumpster, it is time to experiment some more. I've been really curious about the pirelli 486 https://www.denniskirk.com/front-sco...re.p643248.prd and have found no reviews/ input whatsoever, anyone here ever run one? I ride the 690 like a dirtbike and don't care too much about mileage (as long as it last at least as long as a non-dot knobby on the rear does) and very little about onroad handling. The vast majority of the terrain that I ride is very hard packed with sharp/loose rocks on top and coarse desert sand. The only front tires other than the 486 that are currently on my radar are the dunlop 908 and the michelin desert and I've never run any of these. So what says the 690 brotherhood? Stick with the non-dot HP4 or try the p486/ d908/ or m desert? P.S. somebody buy my uprated (9.0) rear spring in the flea market so I can afford a new tire! |
10-19-2012, 07:05 PM
#6020 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
10-19-2012, 07:32 PM
#6021 | |
Oddometer: 351
I've run the H/T's already and while the rear worked pretty good, the front just didn't seem to have enough "bite." The rear worked good for the wide open stuff but the x-circuit rear had the advantage in both cornering and longevity so that will definately be my next rear tire. I've pretty much narrowed it down to (keep in mind this is only in regards to the front tire) pirelli 486, michelin desert, or dunlop 908. Of these tires, how do they fair for my described terrain? |
10-20-2012, 02:34 AM
#6022 |
Oddometer: 601
I say Michelin Des. Expensive, but a good one. Ever looked at Mitas?
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813 ![]() M Motoadventures
10-20-2012, 05:16 AM
#6023 |
Oddometer: 577
Bridgestone ED 78 rear / Maxxis Desert IT front
Works very well in hard/ rocky desert stuff Great in sand... Readily available and cheaper than Motoz/Michelin |
10-20-2012, 05:17 AM
#6024 |
Oddometer: 8
Mitas
10-20-2012, 05:37 AM
#6025 |
Oddometer: 12
i do not have an ignition switch itself
Just two kill switches One kills all power and the other is just an engaine kill my well have a look at the switches
10-20-2012, 05:57 AM
#6026 |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 176
+1. A lot of Dakar pedigree on the Michelin Desert. Isn't the HP4 a motocross tyre? How long did it last?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com |
10-20-2012, 10:47 AM
#6027 | |
Oddometer: 351
I may still try the michelin desert just so I won't always have to wonder how it works. It can't be worse than the motoz s/t that's on the front now (fingers crossed!) I do wonder if it is very narrow like the "90width" michelin m12 (measures closer to 80mm) I have or if it is a wider carcass like the "90width" michelin HP4 (measures closer to 95mm), it sure would be nice if they would standardize! |
10-20-2012, 10:52 AM
#6028 |
Oddometer: 606
I am really liking the Pirelli Scorpion Rally
10-20-2012, 11:42 AM
#6029 |
NooB Again
Oddometer: 124
I've been running the Scorion Pro for several years now, but our soil is a little more moist up here. I average 1200 miles per tire, 70% dirt.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it! |
10-20-2012, 02:03 PM
#6030 |
Oddometer: 351
that scorpion rally is actually looking like a good option... I think I'll order one! Thanks Uller!
