10-20-2012, 02:27 PM
#6031 |
Oddometer: 135
Denial is over...
So I'm ripping apart all my wiring this weekend. I've taped up 3 bared wires already, checked the plug, pump works but 2010 KTM 690 R = No Start. Haven't checked the side stand switch, forgot all bout that one, but highly doubt it.
Going to cut/splice the bared wires proper, and take every wire off and look at each connection. Gotta be something there? Battery is charged, and looking at the wires something had to give somewhere, although I just haven't seen it yet. Arrghhh, at least I'll be confident in identifying future problems anyway! Run Baby Run!!! MFS |
10-20-2012, 05:03 PM
#6032 | |
Wanderer
Oddometer: 808
Is your battery dead? Does the bike turn over? Does the starter relay get power? Does the starter motor get power? Does the starter button get power? Are all your fuses good? I'm not trying to be a dick.. I would try to narrow things down before you tear into your wiring. (although bare wire is a good indication.)
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting. RTW Ride Report --> http://advrider.com/forums/showthread.php?t=781893 Blog ------------------> http://rtwwithnoah.blogspot.com/ Facebook------------> https://www.facebook.com/RtwWithNoah Open-Exporers----->A collection of travel blogs |
10-20-2012, 05:30 PM
#6033 | |
Oddometer: 331
Proud to be supporting Pyndon in the 2013 Dakar ! 2007 KTM 990 Adventure 2008 KTM 300 XC (plated) 2008 KTM 690 Enduro 1998 KTM 400 RXC (sold) |
10-20-2012, 06:00 PM
#6034 |
Oddometer: 31
![]() Cracked 3/4 of the way round. Replaced lower tank bushings last year. Now this shit. Got it welded, we'll see how long it lasts. |
10-20-2012, 06:36 PM
#6035 |
Oddometer: 135
Hey there RoninMoto,
My electric ability is limited unfortunatley, but the starter turns, I've had the plug out and she sparks when starter button is hit. All fuses good, and she pumps gas, can smell er if I crank long enough. Poor battery is on the charger, the past week has worn er out... The wiring was a noticeable (ie visual) flaw, and confirming there are no other poor ones, and check my connections. 2 more items... -The side stand switch, how does that work exactly? (too rule out any fault) If figured there would be a contact point down there that would "switch" it on or off, but the way it looks is it a magnetic gizmo of sorts? The wire ends in what looks to be a black box or housing, with 2 screw heads. It looks intact, is it adjustable in some way? Clutch Thought I'd try starting it in gear, out of gear, and when I had it in gear, with clutch in the bike lurched forward on me when I hit the start button. This could mean what in realation to not starting?? I can mess with this all day, in the end it'll be blind luck if it runs again cause of me. I do not have the capability to try a remap, once battery is charged tomorrow and I have the wiring reconnected I'll maybe pull the pump and have a look. I do like and enjoy the process, but do realize my limitations when it comes to electrical ![]() That all said, Ronin I've followed your RR since you hit Canada. No way your trying to be a dick, ![]() That said, be safe on your travels! Any comments, or suggestions from any and all are welcome. It'll be headed back to a non-KTM shop next week, but the more I figure out on my own, the better. They did a valve check, (without making an adjustment,all good) for me and dropped it off. Didn't run right and now has stopped. Could be as simple as them pressure washing it to hard in the wrong spot (cause the bike came back CLEAN), or maybe starting it before the gauges did there "sweep" and messed up FI timing? Won't start regardless ![]() Fruuustraaateeddd Innncoorrpaaraatteeddd... MFS |
10-20-2012, 07:43 PM
#6036 | |
Engineer
Oddometer: 14
Weld
The weld on the flange looks much nicer, looks like TIG. I'd grind down the bracket weld to almost nothing and get the repair done with TIG. John |
10-20-2012, 09:28 PM
#6037 |
louder, louder, louder!
Oddometer: 1,067
Yep. Mine started cracking at the front heat shield tab. I just removed the heat shield entirely and ground off the brackets.
------------------------------ Suck, Squeeze, Bang, Blow ------------------------------ New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better! |
10-20-2012, 09:46 PM
#6038 |
Oddometer: 169
Good deal?
Been shopping around for a secondary bike to my F800, and am waffling between a 500EXC and the 690 Enduro.
Well, went to the dealer and dropped my bike in the parking lot (I had just come down a mountain and had an angry hornet fly under my shirt tearing the crap outta my gut before I was able to stop, rip off gear and stomp the mofo into the ground, that's my excuse and I am sticking to it) but I digress... They had a 2010 KTM 690 Enduro (i thought it was the 2013 model when I first saw it) with less than 100 miles (n00b knobs still all over the tire). I do like the 690 because I can tip toe both feet with my 30" inseam, unlike the 500 EXC. They were looking for basically $8500 (same price as another low mileage one in Texas). So, good deal or not? We are heading into winter in the Sierras (first real storm come Monday), so the riding season is coming to a close (ah, there is always California). I know a less about the KTM's than I'd like, so thought I would ask for help... Going price? Things to look out for? Assuming it sat for a year (or two), first things to look at? How good do these bikes work in the snow? Heated gear... How many spare watts does the system have? Thanks! |
10-20-2012, 10:26 PM
#6039 |
Common as muck
Oddometer: 482
10-21-2012, 06:06 AM
#6040 | |
Oddometer: 31
10-21-2012, 03:44 PM
#6041 |
on the mend
Oddometer: 976
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding. All posted pics < 6/30/12 deleted courtesy of Apple
10-21-2012, 04:01 PM
#6042 | |
on the mend
Oddometer: 976
Bike should not lurch when starting with clutch lever pulled. Needs adjustment. Should not impact starting if you can't get it fired up in neutral.
10-21-2012, 04:23 PM
#6043 | |||
Oddometer: 331
Proud to be supporting Pyndon in the 2013 Dakar ! 2007 KTM 990 Adventure 2008 KTM 300 XC (plated) 2008 KTM 690 Enduro 1998 KTM 400 RXC (sold) DirtJack screwed with this post 10-21-2012 at 04:58 PM |
10-21-2012, 07:22 PM
#6044 | |
ya mo be there
Oddometer: 398
Keep the f800. For 690 info you can start here: http://www.advrider.com/forums/showthread.php?t=766514 Dunno if that's the best thread, but it should lead you in the right direction. It can handle heated gear just fine, just dial it down when you're going slow, like below 2000rpms. If it sat for a year or two I'd worry about ethanol.
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650 "In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read |
10-22-2012, 04:55 AM
#6045 | |
Torque Stick
Oddometer: 3,853
It wears fairly quickly on pavement, but I felt like I could use the front brake on dirt like I normally could on pavement.
