Old 10-23-2012, 09:55 PM   #6061
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 768
Good outcome. As crank says above - replace the internal fuel filter with an external one. I fitted mine inline after the quick-connect. So much easier to swap out whenever you feel like it
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 10-24-2012, 03:57 AM   #6062
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,052
Fueling issues
Over a year ago my 08 690 on occasions would stall & be a bit hard to restart . I replaced the fuel filter & fitted 1 of those screen filters to the top of the injector. I noticed the old fuel filter was full of black crap . First ride with the new filters I travelled about 100 kays & the bike would barely run . I removed the small screen filter from the injector & it was full of tiny black particles . I left the injector filter out & the bike ran ok again but I still had occasional stalling issues & the bike started to feel a bit doughy in the power department . In other words no improvement . The fuel pump always primed whenever the ignition was turned on . The bike seemed to get more doughy over time till it felt gutless . I pulled out the injector & back flushed it . Tiny little bits of black crap came out . Refitted the injector & went for a test ride . The bike felt a lot better for 20 minutes then went gutless again , reflushed the injector & more tiny bits of black crap came out .Refitted went for another test ride , went ok for 20 minutes , bike stops & wouldn`t restart . Got the bike home , back flushed injector again , more tiny bits of black crumbly stuff came out , refitted injector & bike still wouldn`t go . Turned out to be a fouled plug . On close examination of the plug I could see the spark arcing across to tiny small bits on the porcelain near the centre electrode . I then bought a fuel pressure gauge & tested . Only 25 psi pressure . I pulled the pump out & tested it in a bucket in case a hose was kinked or something . Still only 25 psi . I also noticed the recently fitted in tank fuel filter was again full of black crap . I replaced the fuel pump with a C.A. pump , replaced the injector & filter & refitted the little gauze filter to the top of the injector . The bike goes like a rocket again & hasn`t missed a beat for the last 5000km .
I have no doubt the black crap in the filter , injector & on the plug were bits of the brushes from the fuel pump .I know these tiny bits were getting through the standard tank filter over time & blocking the injector ( & tiny injector filter ) The original pump always primed & never needed a tap to get going yet in the end it would only pump half required pressure .
Note : When back flushing the injector I aimed it into a clean white tray & used a magnifying glass too see the black particles .
Brute screwed with this post 10-24-2012 at 04:03 AM
Brute is offline   Reply With Quote
Old 10-24-2012, 04:44 AM   #6063
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Just a side note. You don't need to build a fancy 9 volt battery thingy to cycle the injector you HAVE a very expensive injector cycler sitting in the garage, and it happens to be in an area where you're already working.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 10-24-2012, 06:16 AM   #6064
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,125
Originally Posted by MFS View Post
You tube, a wonderful thing!! A clip on there entitiled "How to clean KTM motorcycle fuel injector"
Was on a fuel injected 350, but a nice 1:30 video. Using 9 volt battery, opened the injector nozzle, then reverse-blew out the dirt particles with an air hose. Tried that, hooked it all back up and started right away! Scared the crap outta me
Gotta link to that video?
rickypanecatyl is offline   Reply With Quote
Old 10-24-2012, 06:50 AM   #6065
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
The original (Thanks Google)
http://www.youtube.com/watch?v=rBF7jWhpfq0
I like this setup better. He is using carb/injector cleaner, not just pressurized air.
http://www.youtube.com/watch?v=7aT4S...endscreen&NR=1
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 10-24-2012, 06:53 AM   #6066
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,718
Originally Posted by RoninMoto View Post
The 08 is running great but she is burning more oil. The '10 would use the extra .3L (left over from the oil change) once in the interval.
The 08 is burning about 2 times that. I don't see any blue smoke during cold start. It is a pita though. Might take a look into her in a few months.
I'm beginning to think that modern motor oil doesn't really smoke much when it burns. I know when my valve seals went out on my V Strom I had no clue I was burning oil. No smoke at all, but it burned up 3 qts in 1K miles.
Old 10-24-2012, 08:54 AM   #6067
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
You might be right. Would explain a lot.
Old 10-24-2012, 09:59 AM   #6068
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,497
I went through 300ml in a 500 mile, day long trip, on on a Honda 125 scooter - no smoke, no leaks, no clues - still don't know where it all went. The oil capacity was only 850ml.
MeinMotorrad is offline   Reply With Quote
Old 10-24-2012, 10:14 AM   #6069
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 914
singles in particular vent a good deal of oil at high rpm.s
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is online now   Reply With Quote
Old 10-24-2012, 10:22 AM   #6070
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
Thankfully I've been lucky in that department. Recent 5,600km ride with some very long blacktop stretches and high speed. Didn't have any noticable oil loss. Bike now has 17k kms on the clock. Maybe my unsympathetic break in did it some good.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 10-24-2012, 11:17 AM   #6071
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Yup, big single cylinder, high compression. Check the airbox and you guys will see where at least some of the missing oil is going.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 10-24-2012, 02:28 PM   #6072
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,718
Heck, I'm amazed at the fact mines never used oil considering that I ring the crap out of it. It spends so much time at red line it's not even funny. I'm not surprised at all I'm doing a valve and ring job at 27K miles though.
Old 10-24-2012, 03:05 PM   #6073
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 267
Mapping Switch
Anyone got a good link for a supplier of Mapping Switch that I can mount on my bars for my 2011 690E. Am UK based as well.
Cheers
I'll get me coat..............
Harty is offline   Reply With Quote
Old 10-24-2012, 03:46 PM   #6074
Night Crawler
Night Crawler's Avatar
Oddometer: 94
http://www.renazcoracing.com/index.c...&ItemID=538871
Night Crawler is offline   Reply With Quote
Old 10-24-2012, 03:52 PM   #6075
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 267
Thanking you sir, you're a star
Times are GMT -7.   It's 10:04 AM.
