10-24-2012, 06:50 AM
#6091 |
Wanderer
Oddometer: 817
The original (Thanks Google)
http://www.youtube.com/watch?v=rBF7jWhpfq0 I like this setup better. He is using carb/injector cleaner, not just pressurized air. http://www.youtube.com/watch?v=7aT4S...endscreen&NR=1
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting. RTW Ride Report --> http://advrider.com/forums/showthread.php?t=781893 Blog ------------------> http://rtwwithnoah.blogspot.com/ Facebook------------> https://www.facebook.com/RtwWithNoah Open-Exporers----->A collection of travel blogs |
10-24-2012, 06:53 AM
#6092 | |
Kool Aid poisoner
Oddometer: 4,842
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
10-24-2012, 08:54 AM
#6093 |
Wanderer
Oddometer: 817
You might be right. Would explain a lot.
10-24-2012, 09:59 AM
#6094 |
Oddometer: 159
I went through 300ml in a 500 mile, day long trip, on on a Honda 125 scooter - no smoke, no leaks, no clues - still don't know where it all went. The oil capacity was only 850ml.
10-24-2012, 10:14 AM
#6095 |
Dirty Old Man
Oddometer: 772
singles in particular vent a good deal of oil at high rpm.s
Ride the DEZ 05 FE 550 Husaberg plated 09 KTM 690 |
10-24-2012, 10:22 AM
#6096 |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 173
Thankfully I've been lucky in that department. Recent 5,600km ride with some very long blacktop stretches and high speed. Didn't have any noticable oil loss. Bike now has 17k kms on the clock. Maybe my unsympathetic break in did it some good.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com |
10-24-2012, 11:17 AM
#6097 |
Way Offline
Oddometer: 1,162
Yup, big single cylinder, high compression. Check the airbox and you guys will see where at least some of the missing oil is going.
I am at one with my duality. |
10-24-2012, 02:28 PM
#6098 |
Kool Aid poisoner
Oddometer: 4,842
Heck, I'm amazed at the fact mines never used oil considering that I ring the crap out of it. It spends so much time at red line it's not even funny. I'm not surprised at all I'm doing a valve and ring job at 27K miles though.
10-24-2012, 03:05 PM
#6099 |
Bloody Good Bloke!
Oddometer: 177
Mapping Switch
Anyone got a good link for a supplier of Mapping Switch that I can mount on my bars for my 2011 690E. Am UK based as well.
![]() Cheers
I'll get me coat.............. 2011 KTM 690 |
10-24-2012, 03:46 PM
#6100 |
Oddometer: 52
10-24-2012, 03:52 PM
#6101 |
Bloody Good Bloke!
Oddometer: 177
Thanking you sir, you're a star
10-24-2012, 10:19 PM
#6102 |
Oddometer: 135
Napa 3011
Swapped out the Tank Fuel filter, with the Napa 3011. Stock filter was dark? But I didn't see any alien particles in there. New filter in, took the injector off and cycled the bike on and off to clear the fuel line into a bucket. Cleaned the injector again, hooked er all up and the bike started up instantly. But stalled again...
Haven't ran a pressure test on the pump, will have to pick up a gauge (thanks again for the tip Crankshaft). No one has a sparkplug in town, so will order one tommorrow, and probably just order a Cycleworks pump and drop that in. If it doesn't improve anything, well heck I got a spare pump then. If it fixes it then I'm good to go! Bike ran at idle for 5 minutes or so, then died. Started right back up easy enough, would idle, then die. TIre is still off it so I didn't try ridin. If I can't get it running perfect in the garage no sense trying to flog it down the road I figure... Was so intimidated at first by working on the fuel system, but it really is simple on the 690 I'm finding? Provided the pump fixes it and it gets runnin of course...no one within 3 hours who could remap it for me either. Suppose I could check the pressure, first, and if its working try to remap, incase its off for some reason. Will sleep on it, ride safe y'all!MFS |
10-25-2012, 05:23 AM
#6103 |
Dirty Old Man
Oddometer: 772
check the TPS? after you check pump pressure and plug
10-25-2012, 05:39 AM
#6104 |
Oddometer: 135
Tps
Referring to turning the electrical on and rolling the throttle on and off? Or a different check...
I'll search online before I head to work here and see... MFS |
10-25-2012, 07:20 AM
#6105 |
Dirty Old Man
Oddometer: 772
check the voltage readings and adjust. need tune ecu or the dealer.
