Old 10-26-2012, 07:13 AM   #6106
ramjet
ramjet's Avatar
Oddometer: 2,288
Re: decal removal-try this in a small area. Sandpaper the surface to break the clearcoat then try the chemicals. Lacquer thinner, acetone, mek. Some of these may melt the surface of the plastic so be careful and try a very small area first. Or just buzz the entire decal off with sandpaper and refinish with plastic renew. Now you got some work on your hands. But it will work.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is online now   Reply With Quote
Old 10-26-2012, 08:11 AM   #6107
wiswoodsguy
Kmart shopper
wiswoodsguy's Avatar
Oddometer: 2,120
Whoa hold on there
ALL of those chemicals you just described will MELT the plastic - DO NOT USE THEM
And Id love to see what happens when he grabs some 80g sandpaper and shreds off the stickers. For delicate matters like sticker removal, you need to have finesse and patience. I would start with some 600 or 800 wet sandpaper and lightly remove the initial surface - this light sanding might also remove the embossed decal as well. What you really dont want to happen is create a scratch in the plastic underneath the decal. Then you have to use aforementioned Plastic Renew - which never replicates the original look of the plastic, but more of a clear coated plastic that scratches far easier than the plastic itself.
If you do happen to get the stickers off - remove the residual glue off with cleaners that are specifically designed to do so. GooGone is a great choice in this situation, 3M also makes a nice remover as well
I would avoid this scenario all together and stop being a cheapskate - BUY some new plastic and put the stock stuff in storage.
wiswoodsguy is offline   Reply With Quote
Old 10-26-2012, 08:51 AM   #6108
ghostman
Oddometer: 8
I would love to buy new plastic but it comes with the stock graphics already in place.
ghostman is offline   Reply With Quote
Old 10-26-2012, 08:57 AM   #6109
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
'08-'11 plastics fit on the '12 690 enduro. This will allow you to make your own color combination and install any graphic you want.
Have also a look at the '12 smc-r shrouds color scheme, imho nicer than the enduro one.
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio screwed with this post 10-26-2012 at 09:13 AM
Maurizio is offline   Reply With Quote
Old 10-26-2012, 09:16 AM   #6110
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Fuel Pump Issues--Check Private Messages!!
[QUOTE=Reshad;19879463]Only just got around reading the last few weeks of Advrider subscriptions and was most enthused to see a the string of posts on the OEM fuel pump issue and thought Id share my experience. Sorry for the bulky essay style, but this is the best way for me to share
Reshad, check your PM's (private messages). I know you are new to the site so look in the upper right corner of the screen and you will see an unread message or two. One of them is mine. Look forward to hearing from you.
Cheers,
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 10-26-2012, 09:34 AM   #6111
wsmc831
wsmc831's Avatar
Oddometer: 760
I thought the same thing but I can only find replacements with the "decal" already on it.
Odd, none of the plastic I've purchased came with the 125$ graphics on them...
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is online now   Reply With Quote
Old 10-26-2012, 10:15 AM   #6112
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 429
Originally Posted by Mini Trail View Post
I finally got my new rockers and the intake is TIGHT. I expected to have to adjust the valves but I don't exactly know where to start. Is there a way to estimate the shims particularly when they are tight? They aren't cheap.
I saved these a long time ago. They're Harley-Davidson part #s for the 10mm v-rod shims that also fit our engines. They're good for two reasons: they come in half-sizes, and they're said to be cheaper. Providing 'em just in case they help. Next time I have an adjustment (coming up) I'm going to buy a bunch in bulk to save a trip to the dealer. (My last @#$(*$%$#@ KTM dealer wouldn't even sell shims.)
PS: Verify info before you buy--I haven't bought 'em yet!
Size Part #
2 18666-01K
2.025 18624-01K
2.05 18667-01K
2.075 18625-01K
2.1 18668-01K
2.125 18626-01K
2.15 18669-01K
2.175 18627-01K
2.2 18670-01K
2.225 18628-01K
2.25 18671-01K
2.275 18629-01K
2.3 18672-01K
2.325 18630-01K
2.35 18673-01K
2.375 18631-01K
2.4 18674-01K
2.425 18632-01K
2.45 18675-01K
2.475 18638-01K
2.5 18676-01K
2.525 18639-01K
2.55 18677-01K
2.575 18655-01K
2.6 18678-01K
2.625 18656-01K
2.65 18679-01K
2.675 18657-01K
2.7 18680-01K
2.725 18658-01K
2.75 18681-01K
2.775 18659-01K
2.8 18682-01K
2.825 18692-01K
2.85 18683-01K
2.875 18693-01K
2.9 18684-01K
2.925 18694-01K
2.95 18685-01K
2.975 18695-01K
3 18686-01K
FriedDuck screwed with this post 10-26-2012 at 10:27 AM
FriedDuck is offline   Reply With Quote
Old 10-26-2012, 11:13 AM   #6113
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,755
I know that my 08 graphics almost came off with the pressure washer.
My 08 plastic did not quite line up on my 2012. there seems to be some very slight difference in placement of the mounting points, or holes in the panels. I did manage to use them anyway, but the (rear) side plastics are very slightly bowed over the tank, and for the front side panels, I had to manipulate the rubber mounting points on the radiator a little to get them to line up. The difference I would guess is between 1 and 3mm all the way around. I did not have any trouble with the mounting points on top of the tank, self tapping screws under rear fender, the front fender, or the headlight mask...
BK.RD.RNR is offline   Reply With Quote
Old 10-26-2012, 11:49 AM   #6114
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Yours is an old bike...
maurizio
Old 10-26-2012, 12:32 PM   #6115
wiswoodsguy
Kmart shopper
Oddometer: 2,120
Aftermarket should have some good choices without any graphics
Old 10-26-2012, 12:33 PM   #6116
ghostman
Oddometer: 8
The online fiche says that the decal is included on the lower radiator shrouds only and the price reflects that. Have you purchased the lower shroud without the decal. Maybe I am looking in the wrong place.
Old 10-26-2012, 03:26 PM   #6117
ramjet
ramjet's Avatar
Oddometer: 2,288
I've done alot of plastic refinishing and agree with the warnings above but if you want to go this route, work in a small spot and above all wear protective gear. Gloves and organic vapor respirator working with massive ventilation. If working indoors with lacquer thinner, mek, methylene chloride use only enclosed gear with dedicated air supply. These are seriously health danger chemicals and not to be underestimated. I have this gear. If you don't, please reconsider cost vs reward. The plastic melters will alter the surface and then evaporate. Your fender will not turn into a puddle at your feet. Wipe with thin film repeat. I've found chemical process leaves less work than sanding. Plastic renew with 4 coats. I swear by that stuff. It is to restore the high gloss not a protective coat. Don't be afraid to use whatever grit you want, you will just have to do more work with progressively finer grits. Start with 200. Go lower if needed. I finish with 1000 then plastic renew. Also I use wet/dry paper wet.
Old 10-26-2012, 05:18 PM   #6118
MightyTaco
Oddometer: 75
MightyTaco is offline   Reply With Quote
Old 10-26-2012, 06:42 PM   #6119
Mini Trail
nb
Oddometer: 2,282
Originally Posted by RoninMoto View Post
What you will need:
-A set of calipers for measuring the shim you remove.
-a shim kit About the same price as 1 hour of shop time at your local KTM shop?
-strong magnet (easiest way to remove the shims, like you use when you drop a socket into a motor and have to fish it out)
-Feeler gauge.
Amazon had the shim kit for $54.00 & Free shipping from powersport superstore. Woot
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Your cycle had a bell on it.
Mini Trail is online now   Reply With Quote
Old 10-26-2012, 08:39 PM   #6120
offworlder
Oddometer: 256
690 headlight burning out ?
Replaced the headlight bulb in my 2010 690, thinking the old bulb had simply burnt out. The new bulb fired up for a few seconds then quickly died. Checked the voltage at the (lighting wiring) terminals, seems solid, non-intemittent; approx 12+ volts with the engine off, and 14+ volts with the engine running, no shorts between the high and low beams, etc...
Any ideas from the collective ?
Thanks.
offworlder is offline   Reply With Quote
Times are GMT -7.   It's 11:05 AM.
