Old 10-27-2012, 12:00 AM   #6121
ghostridergary
Oddometer: 10
Home made mapping switch
Originally Posted by Harty View Post
Anyone got a good link for a supplier of Mapping Switch that I can mount on my bars for my 2011 690E. Am UK based as well.
Cheers
Hi Harty
I made this one for about 10 (bit of simple soldering) for my 2008e - cable tied near handlebars - still have to cycle ignition on and off though
Credit to this bloke..... http://www.ktmforum.co.uk/technical-...-selector.html
Cheers
ghostridergary is offline   Reply With Quote
Old 10-27-2012, 12:30 AM   #6122
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,669
Have a look at the regulator, loose grounds, intermittent shorts - look specifically for rubbed insulation. The latter two can cause voltage spikes.
a
Originally Posted by offworlder View Post
Replaced the headlight bulb in my 2010 690, thinking the old bulb had simply burnt out. The new bulb fired up for a few seconds then quickly died. Checked the voltage at the (lighting wiring) terminals, seems solid, non-intemittent; approx 12+ volts with the engine off, and 14+ volts with the engine running, no shorts between the high and low beams, etc...
Any ideas from the collective ?
Thanks.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 10-27-2012, 04:00 AM   #6123
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by MightyTaco View Post
Hey Taco, can you post this in the Supermega690 thread?
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-27-2012, 04:24 AM   #6124
LukasM
Oddometer: 5,426
I have heard that the ride-by-wire system is coming to the 690 Enduro models in 2013, can anybody confirm or deny that?
Here is some more info for those that have no idea what I'm talking about:
Originally Posted by LukasM View Post
No it's not. The 690 models (except the 2012 Duke) until now have a mechanical throttle cable that can be overriden by the EPT computer through a solenoid that controls the throttle butterfly. It sits on the right of the butterfly shaft in this picture:
The 2012 Duke 690 uses a true fly-by-wire system, or ride-by-wire as KTM calls it, so there is no mechanical connection there any more.
This is what the throttle grip looks like, it has a spring inside to mimick the feel of a regular throttle pull:
This system does of course offer some benefits because the computer can decide when it's a good idea to give it some more gas - e.g. when starting the bike etc - but at the same time it complicates things further.
IMO - great on a 690 Duke that I ride around town, not so great on a 690 Enduro (R) that I'm taking out into the boonies.
Old 10-27-2012, 05:06 AM   #6125
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,530
Fly by Wire
Take that spring out and you've got cruise control
MeinMotorrad is offline   Reply With Quote
Old 10-27-2012, 06:52 AM   #6126
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Originally Posted by Mini Trail View Post
Amazon had the shim kit for $54.00 & Free shipping from powersport superstore. Woot
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Good price.
Old 10-27-2012, 07:23 PM   #6127
offworlder
Oddometer: 256
Originally Posted by Roadracer_Al View Post
Have a look at the regulator, loose grounds, intermittent shorts - look specifically for rubbed insulation. The latter two can cause voltage spikes.a
Seems strange that the parking light, signals, etc... are all fine (as they use the same fuse as the headlight)....
offworlder is offline   Reply With Quote
Old 10-27-2012, 08:00 PM   #6128
MFS
MFS's Avatar
Oddometer: 224
Headlight
Not to be a guy who responds with an immediatley negative comment, and then post what may be an unreasonable solution but my thoughts..
Stock headlight is garbage, and useless. Had mine for 3 years, but never rode at night, this summer I started too, and realized it for the hazard it was. Too easy to get over your head with a light that's only good for 40 kms per hour or so...
I went through 2 bulbs myself, and rather quickly although I just wrote it off as poor judgement by KTM by putting a bulb and system in the bike that is not "quality", and is there strictly for show.
That's the negative..
The solution?
For my was the Lynx kit from Britannia Composites. Great (awesome) lighting and a functional, adjustable windscreen all in one. It costs money, but allows you to ride at night with confidence, to see better, and to be seen better as well by oncoming.
My opinion is forget the stock light, I'm not "hardcore" by any stretch of the imagination, but the stock light agreeably cannot be used for evening riding, to dim, hard to make out hazards on the flattest of surfaces.
Big Money to spend on the 690 to purchase for most, including me which was why I sat in denial so long and did multiple 2500 km trips with a stock 690. Don't wait like me, look for improved, reliable lighting (Lynx is my vote for value, service, look, fit and finish!) But there are other options. Money well spent, and will open you up to many more riding opportunities!
Even pavement riding will kill the filament in the bulbs used in the stock housing, let alone the shake rattle and roll of even the mildest offroad methinks.
Of course, this is advice from the guy who still hasn't chased down his own gremlin with the stalling, but snow and an unheated garage has dimmed my interest and my wits of late
MFS
MFS is offline   Reply With Quote
Old 10-27-2012, 09:10 PM   #6129
offworlder
Oddometer: 256
The solution?
MFS
Agree that the stocker sucks (2012 is supposed to be better, similar to the 08 "E"), but I digress. I do know Ian (Brittania composites), and the Lynx is a great product.
Nonetheless, while I may go with a 3rd party lighting system at some point, I dont ride at night, and simply want to figure out why the stocker is shorting....
Thanks.
Old 10-28-2012, 04:44 AM   #6130
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
The light on my 08E is MUCH better than that borrowed light from the RFS bikes they used between 09 and 11.
A couple aux LEDs and you're turning the night into day with low amp draw
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 10-28-2012, 05:32 AM   #6131
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 983
For what its worth, if you run the headlight on main beam only (as opposed to dipped), they last 3 times as long. I have an orange lense protector fitted to my light, so I can get away with it, you may not. I have had as little as 2 weeks on the dipped before it blew. Its more a shit bulb spec than a poor light, although I have some conserns about the reflector as well. I'm converting mine to a Rally Raid UK fairing kit, so that's 1 less issue to deal with.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 10-28-2012, 08:23 AM   #6132
daveknievel
daveknievel's Avatar
Oddometer: 816
My 09 R model had the 35w bulb. It blew out and i replaced with a 60w. Bad idea. Melted the housing. Now i use the trailtech X2 halogen. But the low beam was shit in that too. Replaced that bulb with a severe duty one and has been fine since.
daveknievel is offline   Reply With Quote
Old 10-29-2012, 01:13 AM   #6133
toniton
toniton's Avatar
Oddometer: 30
Originally Posted by ghostridergary View Post
Hi Harty
Cheers
I can't see the first photo. Do you have photo of the wire from the front to the switch under the seat?
KTM 690 Enduro R
toniton is offline   Reply With Quote
Old 10-29-2012, 05:36 AM   #6134
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,741
I heard that the 14 models were completely ride by wire. You sit on a couch and use an Xbox controller to ride the bike.
Seth S
Seth S is offline   Reply With Quote
Old 10-29-2012, 05:43 AM   #6135
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
'15 will be ride by wi-fi.
Heard it from the owner of my neighborhood grocery shop.
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio is offline   Reply With Quote
Times are GMT -7.   It's 08:46 AM.
