10-26-2012, 09:16 AM
#6136 |
Nippybit
Oddometer: 92
Fuel Pump Issues--Check Private Messages!!
[QUOTE=Reshad;19879463]Only just got around reading the last few weeks of Advrider subscriptions and was most enthused to see a the string of posts on the OEM fuel pump issue and thought I’d share my experience. Sorry for the bulky essay style, but this is the best way for me to share…
Reshad, check your PM's (private messages). I know you are new to the site so look in the upper right corner of the screen and you will see an unread message or two. One of them is mine. Look forward to hearing from you. Cheers,
2010 KTM 690 R (sold 12/11/12) Previous bikes (way too many to list here and what's the point) Been riding mostly off-road since 1960--began at age 14. Watch this space as I am about to say something really prophetic! |
10-26-2012, 09:34 AM
#6137 |
Oddometer: 204
Odd, none of the plastic I've purchased came with the 125$ graphics on them...
1997 TL1000S 2002 Ktm 300Mxc, 2008 Ktm 690 Duke, 2008 Ktm 530 Xcrw, 2010 Ktm 690 Enduro R 20+ years, 100k+ miles, 15 state's, 5 Countries, 3 years on asphault looking for the checkered flag, 7 dirt trying to stay on my minute. |
10-26-2012, 10:15 AM
#6138 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Why die all tensed up?
Oddometer: 325
PS: Verify info before you buy--I haven't bought 'em yet!
FriedDuck screwed with this post 10-26-2012 at 10:27 AM |
10-26-2012, 11:13 AM
#6139 | |
Torque Stick
Oddometer: 3,856
My 08 plastic did not quite line up on my 2012. there seems to be some very slight difference in placement of the mounting points, or holes in the panels. I did manage to use them anyway, but the (rear) side plastics are very slightly bowed over the tank, and for the front side panels, I had to manipulate the rubber mounting points on the radiator a little to get them to line up. The difference I would guess is between 1 and 3mm all the way around. I did not have any trouble with the mounting points on top of the tank, self tapping screws under rear fender, the front fender, or the headlight mask...
10-26-2012, 11:49 AM
#6140 | |
690er
Oddometer: 132
maurizio '08 LC4 690 E "Orange Duck-R" '08 FLHCTUSE3 "White Anchor" '76 CB 750 F ss "76er" Sold: '03 LC8 ADV s "Big Orange" - '05 EXC 450 F "Orangina" |
10-26-2012, 12:32 PM
#6141 |
Oddometer: 200
10-26-2012, 12:33 PM
#6142 |
Oddometer: 7
The online fiche says that the decal is included on the lower radiator shrouds only and the price reflects that. Have you purchased the lower shroud without the decal. Maybe I am looking in the wrong place.
10-26-2012, 03:26 PM
#6143 | |
Oddometer: 1,671
Qui Desiderant Pacem Preparate Bellum |
10-26-2012, 05:18 PM
#6144 |
Oddometer: 74
10-26-2012, 06:42 PM
#6145 | |
n°°b
Oddometer: 1,830
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Your cycle had a bell on it. |
10-26-2012, 08:39 PM
#6146 |
Oddometer: 220
690 headlight burning out ?
Replaced the headlight bulb in my 2010 690, thinking the old bulb had simply burnt out. The new bulb fired up for a few seconds then quickly died. Checked the voltage at the (lighting wiring) terminals, seems solid, non-intemittent; approx 12+ volts with the engine off, and 14+ volts with the engine running, no shorts between the high and low beams, etc...
Any ideas from the collective ? Thanks. |
10-27-2012, 12:00 AM
#6147 | |
Oddometer: 4
Home made mapping switch
I made this one for about £10 (bit of simple soldering) for my 2008e - cable tied near handlebars - still have to cycle ignition on and off though Credit to this bloke..... http://www.ktmforum.co.uk/technical-...-selector.html Cheers |
10-27-2012, 12:30 AM
#6148 | |
louder, louder, louder!
Oddometer: 1,076
Have a look at the regulator, loose grounds, intermittent shorts - look specifically for rubbed insulation. The latter two can cause voltage spikes.
a Quote:
------------------------------ Suck, Squeeze, Bang, Blow ------------------------------ New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better! |
10-27-2012, 04:00 AM
#6149 |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
10-27-2012, 04:24 AM
#6150 | |
Oddometer: 4,911
I have heard that the ride-by-wire system is coming to the 690 Enduro models in 2013, can anybody confirm or deny that?
Here is some more info for those that have no idea what I'm talking about: Quote:
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
