Old 10-30-2012, 11:08 AM   #6166
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Originally Posted by crankshaft View Post
My wild ass guess was correct, 61hp at the rear wheel at 7500 rpm
Linear curve, right to 7500! Now its time to ride it in anger for a bit and make sure everything is good!
Post up some fuel tables from the 'squirt system, if you can... I'd be interested to look at that.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 10-30-2012, 11:41 AM   #6167
cantweallridealong
cantweallridealong's Avatar
Oddometer: 23
Ktm 690 enduro help needed pls
Hi all
i am currently traveling south america on a KTM 690 Enduro and have a problem..
engine noise ticking very rapidly turned into a full melt down from the bike
i am some what mechanically inclined so i set to work.. to try to see what the hell had happened..
I was quite sure that this was a valve issue. took off the head to reveal a super f**ked Valve Rocker Bearing that has stripped its self and seized.. also damaging the Valve Cams too..
As i can tell there dos not appear to be any other damage done to any other parts..
my questions for anyone who can help is would this have done any other damage to the motor... i.e. the piston, cylinder etc... this is not an easy thing too tear down to check..
and other than ordering a new Rocker Arm and Valve Cam what else does anybody recomend i should replace with these..
many thanks
James
cantweallridealong is offline   Reply With Quote
Old 10-30-2012, 11:58 AM   #6168
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 322
Aw man, that aint pretty...
I would verify the oil pumps are in spec in terms of pressure and volume.
No use replacing parts if'n the oil ain't gettin there.
Bigbugberg is offline   Reply With Quote
Old 10-30-2012, 01:31 PM   #6169
Mini Trail
nb
Oddometer: 2,282
When my rockers went bad I did some searching and discovered that it wasn't uncommon. I note that you have the newer style rockers not what came with my 2009. On mine one shaft came out and I was able to push the other one out with my finger plus the needle bearing came apart. Yours just looks ceased.
I would replace both rockers.
What is that red oil you are using?
Your cycle had a bell on it.
Mini Trail is offline   Reply With Quote
Old 10-30-2012, 02:15 PM   #6170
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,688
LOL, so the more I tear into my motor the more I find I need to do. So new piston to go along with the new rings, and of course the cylinder needs to be worked over. If the cylinder is worn past spec, then it's going to have to be sent off.
I did pick up a used cylinder and piston with rings with 4.5K miles on Ebay for $100. Figure I'll toss that on for now, and next time I need to do a top end just swap cylnders and pistons.
Old 10-30-2012, 02:47 PM   #6171
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,120
So your sending it off to be bored out too 728cc
Mudguts is offline   Reply With Quote
Old 10-30-2012, 02:53 PM   #6172
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,688
Hmmmm Might have to look into that.
Old 10-30-2012, 03:35 PM   #6173
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 456
Yeah, I read about bad rockers in the supermoto forums.
Somewhere in here:
http://www.supermotojunkie.com/forum...KTM&order=desc
thorinoakenshield is offline   Reply With Quote
Old 10-30-2012, 03:55 PM   #6174
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Does anyone know anything about the BIg bore kits for the 690? Char on SM junkie did a big bore mod to his 690sm using a stock comp JE piston. I'm interested in finding out more info. Wasn't it 692cc?
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-30-2012, 04:12 PM   #6175
Mudguts
Mudguts's Avatar
Oddometer: 2,120
Have a look here
http://www.gw-racing-parts.de/index2...is=2010&lan=en
KTM 690 bigbore - tuningkit. New camshaft stage 2. Cylinder boring for 104 mm and new LFC plating. CP forged pistonkit of the extra class 104,00 mm, + 2 mm oversize, 717 cc, compression 12,5 : 1. Delivery including the suitable piston rings, wrist pins and wire locks.Cylinder head porting inclusive radius valve seat cutting. Inclusive shot peen of the combustion chamber and channels. Including crankshaft balancing.
Old 10-30-2012, 04:18 PM   #6176
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Have a look here
I was hoping for something made here in the good ole US of A. 220, so after the duty, taxes and exchange.... $5,000,000 US dollars
Just say'IN
Old 10-30-2012, 04:22 PM   #6177
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,688
Heh, I was just looking through that. I think it was 699 cc.
Old 10-30-2012, 04:29 PM   #6178
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,688
Char got his stuff here. The piston was a JE from Engine Dynamics.
Old 10-30-2012, 04:35 PM   #6179
Mudguts
Mudguts's Avatar
Oddometer: 2,120
Or the monster 790cc.
http://www.frauenschuh-tuning.at/ind...id=ktm_lc4_690
Old 10-30-2012, 04:47 PM   #6180
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
My wiener isn't small enough. Yea, says the guy that owned a 950
Just say'IN
Times are GMT -7.   It's 04:20 PM.
