Old 10-30-2012, 02:15 PM   #6196
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
LOL, so the more I tear into my motor the more I find I need to do. So new piston to go along with the new rings, and of course the cylinder needs to be worked over. If the cylinder is worn past spec, then it's going to have to be sent off.
I did pick up a used cylinder and piston with rings with 4.5K miles on Ebay for $100. Figure I'll toss that on for now, and next time I need to do a top end just swap cylnders and pistons.
Guess what doofus, nobody reads your lame blog.
Old 10-30-2012, 02:47 PM   #6197
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,659
So your sending it off to be bored out too 728cc
Mudguts is online now   Reply With Quote
Old 10-30-2012, 02:53 PM   #6198
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
Hmmmm Might have to look into that.
Old 10-30-2012, 03:35 PM   #6199
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 398
Originally Posted by Mini Trail View Post
When my rockers went bad I did some searching and discovered that it wasn't uncommon. I note that you have the newer style rockers not what came with my 2009. On mine one shaft came out and I was able to push the other one out with my finger plus the needle bearing came apart. Yours just looks ceased.
I would replace both rockers.
What is that red oil you are using?
Yeah, I read about bad rockers in the supermoto forums.
Somewhere in here:
http://www.supermotojunkie.com/forum...KTM&order=desc
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650
"In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read
thorinoakenshield is offline   Reply With Quote
Old 10-30-2012, 03:55 PM   #6200
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Does anyone know anything about the BIg bore kits for the 690? Char on SM junkie did a big bore mod to his 690sm using a stock comp JE piston. I'm interested in finding out more info. Wasn't it 692cc?
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-30-2012, 04:12 PM   #6201
Mudguts
Mudguts's Avatar
Oddometer: 1,659
Have a look here
http://www.gw-racing-parts.de/index2...is=2010&lan=en
KTM 690 bigbore - tuningkit. New camshaft stage 2. Cylinder boring for 104 mm and new LFC plating. CP forged pistonkit of the extra class 104,00 mm, + 2 mm oversize, 717 cc, compression 12,5 : 1. Delivery including the suitable piston rings, wrist pins and wire locks.Cylinder head porting inclusive radius valve seat cutting. Inclusive shot peen of the combustion chamber and channels. Including crankshaft balancing.
Old 10-30-2012, 04:18 PM   #6202
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
Have a look here
I was hoping for something made here in the good ole US of A. 220, so after the duty, taxes and exchange.... $5,000,000 US dollars
Just say'IN
Old 10-30-2012, 04:22 PM   #6203
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
Heh, I was just looking through that. I think it was 699 cc.
Old 10-30-2012, 04:29 PM   #6204
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
Char got his stuff here. The piston was a JE from Engine Dynamics.
Old 10-30-2012, 04:35 PM   #6205
Mudguts
Mudguts's Avatar
Oddometer: 1,659
Or the monster 790cc.
http://www.frauenschuh-tuning.at/ind...id=ktm_lc4_690
Old 10-30-2012, 04:47 PM   #6206
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
My wiener isn't small enough. Yea, says the guy that owned a 950
Just say'IN
Old 10-30-2012, 06:16 PM   #6207
DirtJack
DirtJack's Avatar
Oddometer: 331
My wild ass guess was correct, 61hp at the rear wheel at 7500 rpm
Linear curve, right to 7500! Now its time to ride it in anger for a bit and make sure everything is good!
Those are good numbers. Crankshaft what year is this bike, 2012 with an actual 690 cc or earlier with 654 cc?
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 10-30-2012, 06:40 PM   #6208
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
09 654cc
AFR is 13 across the board and I'm running it in open loop for now to make sure the fueling is good. Don't forget, 61 was with the insert still in the exhaust.
Just say'IN
Old 10-31-2012, 02:12 AM   #6209
LukasM
Oddometer: 4,900
You are not paying any of that shit for a shipment under $1000, at least not if it's mailed.
€220 is $285, shipping should be about $30 or so. I'd definitely prefer a proven piston designed by Emil Grossewächter (he is good and has a lot of experience with 690s) and manufactured by CP over a JE experiment....
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 10-31-2012, 06:37 AM   #6210
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
Thanks for the info Lukas, I agree. That price isn't bad actually and I tend to get stuff from Europe faster than I do from California
Just say'IN
Times are GMT -7.   It's 10:11 PM.
