11-05-2012, 03:45 AM
#6241 | |
8 lug oil burner
Oddometer: 9,173
Start off checking the injector. Sounds like it could be fuel related. is the pump cycling when powered up? I know you replaced the pump already, but I'd start with fuel, and spark. |
11-05-2012, 06:47 AM
#6242 |
n°°b
Oddometer: 1,831
Honestly it is acting like the pump but I don't want to go there. The pump is making noise. I checked the spark before I put it all back together. I guess I'll study up on the injector.
Your cycle had a bell on it. |
11-05-2012, 08:05 AM
#6243 |
Oddometer: 135
Fuel Injector
That's where I'm at right now also. I cleaned mine myself, and the 690 fired up all sweet like (previously was not starting at all) but it does stall. Changed the fuel filter, recleaned the injector and and runs poor. Stalls when decelerating/stopping, and misses when accelerating. Holding Rpm, it runs, say doing steady 80 kph, or higher. But crack the throttle and it misses.
I have checked spark, wires, everything I could myself and taking the injector out and putting it back in was the only item that resulted in a positve. So now today I'm in the process of finding someone to do the "ultrasonic" cleaning? Or at least at more "proffessional" cleaning than I gave it. Funny though, the shops I've called so far seem to do the same, homemade cleaning style that I do, just blow air backwards through it. Once I can rule out the injector, then I'll look at a different part I suppose...but I think it's got something to do with it... MFS |
11-05-2012, 09:34 AM
#6244 | |
Oddometer: 415
Growing old is mandatory... growing up is optional! ![]() Raid de L'Amitié 2011 RR (link) 690R & 990Adv |
11-05-2012, 11:43 AM
#6245 |
Oddometer: 26
The power wires going to the coil, the 2 spade connectors, were very corroded on my 2010. The gauge size is too small. I was have similar type of problems, it would run great, than barely idle or not start at all and no pattern to it. Just something else you may want to check
A ship is safe in the harbor, but that's not why ships are built... '10 KTM 690R:) |
11-05-2012, 01:02 PM
#6246 | |
TrackBum
Oddometer: 463
2009 KTM 690r Enduro in da house 2002 RC51 SOLD 2010 KTM 990 Supermoto R |
11-05-2012, 01:11 PM
#6247 |
Oddometer: 135
power wires to coil
Hmm, pictures? Or verbal description of the wires/connectors that you mean? I couldn't find any noticeable problems with my wires, but then again, I know not what I look for
Are we talking down on the right side of bike? MFS |
11-05-2012, 01:39 PM
#6248 |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 171
Yes, there are 2 spade connectors on the coil. Check those. Also make sure the earth is clean and not corroded/rusty
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com |
11-05-2012, 01:46 PM
#6249 | |
Wanderer
Oddometer: 817
I had weak to no spark and spade connector on the coil was so loose it fell off when I removed the coil. Problem solved. I also re-sanded the grounding while I was at it.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting. RTW Ride Report --> http://advrider.com/forums/showthread.php?t=781893 Blog ------------------> http://rtwwithnoah.blogspot.com/ Facebook------------> https://www.facebook.com/RtwWithNoah Open-Exporers----->A collection of travel blogs |
11-05-2012, 02:31 PM
#6250 |
Oddometer: 26
Yah. I started cutting back my wires to get clean copper. My wires were black for about 4 inches. Those spades seem to get loose quite easily.
11-05-2012, 05:27 PM
#6251 |
n°°b
Oddometer: 1,831
My coil connectors were fine and I was dissapointed.
I pulled the injector but I have never messed with one on a bike before. I don't know how much fuel should come out on startup. When I turn on the key the fuel line going to the injector "chubbed up" so I figured the fuel pump is building pressure. I listened carefully to it though and it seems a bit noisy. Cranking the bike with the throttle closed produced a light mist, I just don't know how much it should be. I do know that a bosch CIS system that just pees fuel all the time would produce a wetter output at the injector.
11-05-2012, 05:31 PM
#6252 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
11-05-2012, 06:06 PM
#6253 | |
n°°b
Oddometer: 1,831
11-05-2012, 07:30 PM
#6254 |
8 lug oil burner
Oddometer: 9,173
Mini,
Fuel spray looks light Pull the injector out of the holder. Divert incoming fuel to another container. With the injector still plugged into the electrical hook up a tube and airhose to the output side. Then push some air/solvent through backeards as you spin the motor to cycle the injector. I can take some pics tomorrow if it'll help. |
11-05-2012, 09:16 PM
#6255 |
Oddometer: 135
Injector Screen
The good thing about doing things yourself, is that the second time everything goes sooo much smoother.
That said, this is still the first time, and a lesson has now been learned! Next time, I will defineatley pull the infector screen before reverse-blowing air through it. Like ever other screen/filter, from shop vac to bike do we not always take filter out, as seperate component and clean it then? This time however, I messed up trying to get that lil sucker out, and have punctured it ![]() Have the injector soaking in Diesel fuel conditioner (recommended?) for the night, will put the screen back in tommorrow, reinstall it all and try it out! Small puncture, but it can't run any worse! Will try to order injector screen kit tomorrow. um, if there is such a thing. Did check the spade connectors on the coil, the rubber housing on one was loose, and rubbed through by a rad hose. Pinched it on a bit tighter and hopefully that and a super clean injector will make a difference.... Gonna be "extra ready" for spring... MFS |
