11-07-2012, 08:15 PM
#6256 | |
Oddometer: 11
11-07-2012, 08:23 PM
#6257 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
11-07-2012, 09:34 PM
#6258 |
Oddometer: 11
Cheers for the advice crankshaft. Would def prefer to use an impact gun, but i don't have one, the bike is in my sitting room oil drained and the closest impact gun is down town and attached to an unmovable compressor... I'm concerned if i apply too much torque using a breaker bar or extension pipe the primary shaft might get sectioned as it is hollow in that part, or that the gears will eat up my wedge putting unnecessary perpendicular pressure on the crank and clutch cage cog, pushing either of them them out of trueness... What do you reckon are they all rock solid and i should just apply pressure until the nut loosens?
11-07-2012, 11:18 PM
#6259 |
Oddometer: 11
Managed to remove the nut by mimicking an impact wrench by firmly using a piece of wood as impactor against the flex wrench so as not to damage my ratchet..three taps and the nut came loose! I then removed the inner clutch hub; it looks mint in condition. The clutch cage definitely has some play at the needle-bearing interface and it came out easily too. All contact surfaces look fine with only normal wear. If the clutch cage play is not normal, then either the bearing is worn or either of the surfaces, shaft or clutch cage are worn. The primary shaft bearing looks intact, no traces of seizure or damage to the bearing cage, but here’s what I found that doesn’t seem quite right…The main shaft turns freely inside the bearing, no radial play but full axial play, so either the shaft or bearing surface is worn :/ I’d put my money on the shaft being softer and wearing rather than the bearing. Do yous reckon it’s it normal the shaft moves in and out of the bearing like that? Doesn’t seem normal to me, but as I’m no expert with the LC4 I might be wrong. The fact the whole assembly looks in such good condition, I’m tempted to replace the needle bearing only, put it all back together and play it by ear. Any thoughts? The alternative is a full rebuild to check/change the shaft or bearing, yikes for the wallet :/
11-08-2012, 03:48 AM
#6260 | |
Torque Stick
Oddometer: 3,856
I am no one to diagnose your issue from afar, but my thoughts.. I now believe that my issue was caused by a leaky slave cylinder. When I took a few of the metal pieces (still covefred in oil) and put them on a clean piece of paper, I noticed a clear ring soak into the paper before the engine oil did. I think it was mineral oil from the clutch system. If I am correct, the bearing that went on me was the one closest to where that mineral oil would escape the clutch system. I would say from the sounds of it, you are in much better shape than me at this point (having caught it earlier). Do you have any marking from the basket on the inside of the clutch cover?
11-08-2012, 05:42 AM
#6261 | |
goodtimesgreatoddies
Oddometer: 88
tps?
I had very similar issues with my 09. I went thru everything you are, new fuel filter, new injector, new pressure regulator(that one was my fault). Spent hours screwing with it. In the end it was a faulty throttle position sensor. 100 bucks fixed everything. I hate to say it but bring it to a dealer and have them plug it in to the bazillion dollar ktm computer. In a couple minutes they will let you know if its a computer/electrical issue. good luck with it. |
11-08-2012, 05:50 AM
#6262 |
Oddometer: 11
Axial play in main-shaft
I also have a leaky slave…my hydraulic fluid container has got progressively darker over the last few months; the oil level is still the same though! From what I have read in the other forums, this appears to be a common problem and not just with KTM. Anyhow, I need to get around replacing the slave O-ring then the fluid, once I've decided how to proceed with my shaft problem.
I doubt such a tiny amount of hydraulic fluid being constantly mixed into fresh oil could attack a bearing or shaft for that matter, any fluid experts out there? I'm more inclined to believing you had a random catastrophic bearing failure, but here are some points to ponder over… 1. If the slave does leak fluid to the engine and the fluid does attack bearings or shaft metal, it would begin leaking into the engine on the LHS of the engine close to the LHS main-shaft bearing, causing mayhem there… Have you split your case yet to see the state of things on the LHS? 2. Looking at the exploded diagram of a 690 LC4, hydraulic fluid cannot end up directly at the RHS main-shaft bearing. Any fluid leftover from the LHS heading towards the clutch side would have to work its way through the main-shaft and in so doing would end up being dumped inside the clutch via the pressure piece/bearing. At the speed the clutch turns any hydraulic fluid IMO would probably get flung all over the place under the clutch cover, mixing well into the oil if they are miscible. Even if the bike was not running and fluid seeped out from the slave through the shaft, it would drip from the clutch rather that move inwards towards the bearing. 3. If the fluid was the cause in my case, why are all my visible contact surfaces so clean? For instance, at the needle bearing i should seen more wear where the needles contact the shaft compared to where there is no contact, yet, the shaft surface is clean and even from the main-shaft bearing all the way to the inner clutch hub mating area. Similar observation on the clutch cage needle bearing mating surface, clean and even. 4. Lastly, if hydraulic fluid can attack bearings, then the bearing failure should affect many more people and not just KTM users seen as the leaky slave is a common moto issue. Unless it’s down to the specially silver coated bearings, but then many more KTM owners would have the problem. Considering these four points, I really can't associate my problem with a hydraulic fluid leak. If anything my bearing is bad and caught occasionally, eventually wearing the shaft, but that would have to happen often and I would then expect to see a bright blue bearing yet it appears as fresh as. Furthermore, with the clutch removed the main-shaft bearing spins ever so smoothly. The fact my main-shaft slides so smoothly in and out of the bearing means either the two bearings or both sides of the shaft (more probable) are worn. I may just have a naff shaft they forgot to harden or perhaps it's the other way around the the bearing were not properly hardened, but both is a bit farfetched! I'm so tempted to leave it as is and change only the needle bearing which has some radial play, rather than have to tear down the whole engine. Big risk though, especially when I see the pics in your post. BTW, no markings whatsoever on my clutch cover, the shaft doesn't move out far enough, yet, for the basket to touch it. Would love to have a clear clutch cover, that would be an awesome Powerpart and let you keep an eye on goings on inside |
11-08-2012, 06:54 AM
#6263 |
Torque Stick
Oddometer: 3,856
Interesting points.
Although I don't know if it is a language barrier, mistake, or if you are not aware.. The fluid in the hydraulic clutch system is mineral oil. If this is a misconception on your part, I'm sure you must realize the difference in lubricity between mineral oil, and hydraulic fluid in that environment.. I find your theory about the way such a leak would end up in the engine case interesting, and worhty of consideration. I did fail to mention that I was having clutch engagement/ disengagement issues over a period of months before my failure happened. Flushing the system of old fluid, and bleeding it "seemed" to cure the problem (had to do 2 or 3 times in those 5 or so months preceeding the failure). My theory could certainly be flawed, it wouldn't be the first time.
11-08-2012, 07:23 AM
#6264 | |
Oddometer: 79
I think you would have to have a lot of mineral fluid in the case to damage a bearing. Many of us have run our engines with a litre of coolant/water mix in the case for kilometers without knowing or without choice. I'm one of those guys & 5,000km later my engine is as quiet as it was when it was new. That said, perhaps the longevity has been compromised
![]() Quote:
NovaMoto screwed with this post 11-08-2012 at 09:52 AM |
11-08-2012, 10:03 AM
#6265 |
SE Asia adventure tours
Oddometer: 582
Fair price for new '11
Hey guys I've got a brand new '11 690R enduro I'm thinking of putting up for sale and was wondering what y'all think a good price is? I haven't discussed that particular bike much for legal reasons - its actually better than new; here is the scoop on it.
1. It's a brand new '11 that I haven't ridden or even sat on. 2. It had 2 days being set up and going over by KTM NA's top two 690 mechanics - Tyler Berner andd 1 other guys I'm forgetting right now. It was not touched by a local dealer! Most on here are familiar with my bikes reliability problems as of course is KTM NA and Austria. As they thought some of those reliability issues may have come from poor dealer set up this bike got to have 2 days time of the top 2 KTM guys going over it. 3. In addition to the stock dash/light it also has the larger 08 E set up. 4. KTM hard parts pannier racks; pelican cases. 5. Stock seat AND Renazco suede. And lots of little stuff - any ideas what's its worth? It's in the Seattle area if that makes a difference. Did the '12 knock down the price of the 654's? What are guys walking out the door with them for? |
11-08-2012, 10:12 AM
#6266 | |
Oddometer: 207
How was the 08 dash added? Sure hate the small one of my 10, though I have it covered up with a zumo 660.
1997 TL1000S 2002 Ktm 300Mxc, 2008 Ktm 690 Duke, 2008 Ktm 530 Xcrw, 2010 Ktm 690 Enduro R 20+ years, 100k+ miles, 15 state's, 5 Countries, 3 years on asphault looking for the checkered flag, 7 dirt trying to stay on my minute. |
11-08-2012, 10:43 AM
#6267 |
Torque Stick
Oddometer: 3,856
I paid $9600 for my new 2012 (+taxes etc.etc..). No setup fee.
11-08-2012, 12:34 PM
#6268 | |
Oddometer: 582
Lightwise I've been running a FX-R, 50 watt Bi-Xenon projector which has the most brillant road legal pattern possibly anywhere. I haven't really plugged it because all though the light is 100X better than stock its cheap and not very rugged. |
11-08-2012, 01:18 PM
#6269 |
Oddometer: 207
Would love to know how they got the larger dash in there. Same dash on my 08 duke, friends 08 e, and 2012 r...but different connector from my 2010, worthless dash. More room behind the light like 08/12 sure would be nice as well...
11-08-2012, 02:10 PM
#6270 |
Red Sox Nation
Oddometer: 8,900
I paid $9700 for my 12 plus taxes and reg.
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
