Old 11-09-2012, 07:48 AM   #6271
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,534
Originally Posted by Reshad View Post
No doubt about it, mineral oil won't be a very good lubricant compared to the recommended Motorex, but for a significant drop in overall lubricity, I think you would need to have more mineral oil go in than seepage amounts. My clutch has mostly been fine though i must admit, recently, on a few occasions it didn't go straight into neutral as it always has...might be a sign. Will dismantle my slave, see what I find and report back.
Did you ever manage to lay your hands on another engine to replace your damaged one?
As of yet I have not repaired mine... I did however go out and get a new 2012 690E. I have not decided if I will bother repairing the 08, or just use it for parts etc...
Speaking of which, I have a number of NTO, and used parts taking up space in the garage. I doubt that I'll sell any of the NTO stuff at this point, but I have an 08 stock muffler, the tailrack with the horseshoe thingy on it, an 08 stock seat (with damaged seat pan), and some other stuff.
If somebody needs something, feel free to pm me.
Originally Posted by metaljockey View Post
None of us are exceptionally skilled riders (excepting when I'm drunk, then I'm fcking quick).
BK.RD.RNR is offline   Reply With Quote
Old 11-09-2012, 08:11 PM   #6272
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Next logical step to me is to heat up the nut a bit and try again... Any recommendations on how to proceed?
At 212 F, Red Loctite looses roughly 30% of its strength. It looses 80% at 300 F.
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 11-10-2012, 10:17 PM   #6273
Reshad
Oddometer: 13
Paul Jr
Cheers Paul Jr. I managed to get the nut loose in the end, but good facts to know for future reference.
Reshad is offline   Reply With Quote
Old 11-11-2012, 02:55 AM   #6274
Reshad
Oddometer: 13
I've completely dismantled my clutch; everything I could check with the service manual is in spec and my only remaining concern is the ~0.5 mm axial play in the mainshaft. Could this be normal? ...no mention in the manual! Looking at the half washers, since they could decrease axial play when the clutch is assembled, I see they both appear to be crushed, or maybe it's just the normal finish, would greatly appreciate your views. They both measure 2.95 mm in thickness, does anyone know if this is in spec, as there is nothing noted in the service manual on this. Similarly, the stepped washer i measure is 5.1 mm in thickness, is this in spec? Cheers
Old 11-11-2012, 05:19 AM   #6275
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,480
Originally Posted by Pantah View Post
I paid $9700 for my 12 plus taxes and reg.
Nice bike...
You from RI Pantah ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 11-11-2012, 06:36 AM   #6276
Pundy
Oddometer: 339
Frank, you need a 690, it's the greatest all around bike. You'd love it for the type of adventuring you do.
Pundy is offline   Reply With Quote
Old 11-11-2012, 07:04 AM   #6277
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,126
Originally Posted by DockingPilot View Post
Nice bike...
Thanks. I live downtown Boston in a high rise.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 11-11-2012, 07:37 AM   #6278
DockingPilot
Oddometer: 9,480
Hi Sam! Your right !
Frank Reinbold
Old 11-11-2012, 07:38 AM   #6279
DockingPilot
Oddometer: 9,480
India wharf threw me. There is one in Providence.
Frank Reinbold
Old 11-12-2012, 08:11 AM   #6280
wsmc831
wsmc831's Avatar
Oddometer: 706
Long shot I know...but posting for a friend. He had a bit of a lowside yesterday on a gravel road at speed. Left side. No real damage to himself fortunately.
Bad part is it is very difficult, or near impossible to shift out of 5/6 down to 3/4. Looking at the fiche appears there are 3 different splines so he's thinking he bent the fork for 3/4 being in 4th at the time.
I've NEVER heard of that on these bikes and am a bit disappointed if a fall on a gravel road can do that much damage, but don't see what else it could be.
Wondering if anyone has heard of similar?
Bike is a 2012 R with 2k miles.....
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 11-12-2012, 08:20 AM   #6281
NovaMoto
Oddometer: 133
I had a similar fall on my '11, shredded the shifter, left peg and muffler. No tranny issues.
NovaMoto is offline   Reply With Quote
Old 11-12-2012, 08:25 AM   #6282
wsmc831
wsmc831's Avatar
Oddometer: 706
Nice peg!!!
A bit baffled on how the damage could have been done. Lever is tucked up pretty well, his oversized pegs folded up nicely and dinged the rearset, but don't see how forces could have either pushed the shift shaft in, or pushed the shift lever up or down enough to bend something in the tranny. I've taco'd many a shift lever on my 530 without any internal damage.
...but, nothing to be done about it I suppose, eliminate the simple stuff, then split the cases.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
Old 11-12-2012, 10:25 AM   #6283
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,560
Pull the shift lever off, it's possible that he stripped the splines and the lever isn't moving the shift shaft far enough.
It's also possible that the shifter shaft is bent, and preventing it from moving far enough to make the shift.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 11-12-2012, 02:05 PM   #6284
brzda
brzda's Avatar
Oddometer: 18
KTM 690 idle doesnt run after cleaning
Hello, I have problem with my KTM 690R 2009. KTM doesnt run to idle after Karcher pressure cleaning. It sometimes starts and goes with turning the throttle but stops to idle. FI on speedometer doesnt flash. It is OK after an hour. Do You have any experience? Thank You. Sorry for my english
brzda is offline   Reply With Quote
Old 11-12-2012, 02:51 PM   #6285
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
You could be getting water under the spark plug cap , or you have bad connection , Check as many of the connection as you can , check spark plug lead and make sure the spark plug cap is connected firmly
Mudguts is online now   Reply With Quote
Times are GMT -7.   It's 03:32 AM.
