Old 11-18-2012, 01:21 PM   #6286
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,998
Originally Posted by Mini Trail View Post
I took it all apart and cleaned the injector with no improvement. I cut the hose clamp off at the injector housing and I get good voume of fuel but zero pressure. I guess 6000 miles out of the first pump was pretty good compared to the 400 out of the replacement.
That's exactly how mine was.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 11-18-2012, 02:58 PM   #6287
Mini Trail
nb
Oddometer: 2,323
The fuel pump is out.
It is a CA. Cycleworks.
Is there anything to test at this point? Can I run it outside of the tank?
Are those gray star things on the fuel line connectors that come apart?
Your cycle had a bell on it.
Mini Trail screwed with this post 11-18-2012 at 05:44 PM
Mini Trail is offline   Reply With Quote
Old 11-18-2012, 05:59 PM   #6288
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,998
Mini, How far with testing are you willing to go? Drop it in a some fuel and attach a pressure gauge... About all you can do. Other than power it up and see that it spins up every time. After that you'll need to get technicial to trouble shoot it any deeper.
My bad
Old 11-18-2012, 06:36 PM   #6289
Mini Trail
nb
Oddometer: 2,323
I don't have a gauge, but I could easily hold back the pressure with my thumb over the hose. I even tried a loose grip on it once and it barely sprayed past my thumb at all.
I think I thought I might find something obviously wrong if I pulled the pump. Everything is clean though. I did cycle it a bunch of times to try to pump the gas out that I couldn't siphon and it eventually quit running.
I'll pick up some kind of gauge next week, can I just submerse the pump in a jar of gas to test it? I have almost no time to work on it now but I will have a mandatory week off after Christmas. I want to order whatever I need to get this running by then.
Then I'm going to trade it on a Road Glide or something fun that runs.
Old 11-18-2012, 08:49 PM   #6290
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 929
dont bother with the gauge . it needs 55 psi. unless you have a kink in the hose or a completely plugged filter you need a new pump or your pump is not getting electricity, or you have a leak in the fuel line....i have seen that also
they do go bad. even the California cycle ones
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 11-18-2012, 09:43 PM   #6291
ktmmitch
Oddometer: 710
We have had problems getting those "snap" connectors apart,once they have been immersed in fuel for a while,and had a couple of bikes that were loosing fuel pressure and would start,but not run,because owners had used screwdrivers etc to push back the barbs on the connectors when getting them apart.This meant they did not re-secure properly when re connected,and the fuel pump pressure was forcing them apart,so loosing pressure.But you could not tell,because the leaky connector just leaks internally into the tank.The only way we proved it was to pull the pump and pipework right out,put it in a bucket with petrol and cycle the pump,then we saw the fuel coming out of the connector.
Since then we have made our own plastic tool to disconnect the snap-fit connectors properly,which we supply to several KTM dealers,as even these guys struggle with them,as a lot of the SX and EXC are using the same connectors on their FI system.
Link to Clip
ktmmitch is online now   Reply With Quote
Old 11-19-2012, 08:04 AM   #6292
SKINNY
SKINNY's Avatar
Oddometer: 668
Low fuel
During a 2 day ride in Big Bend, I decided to see how far my 2012 690 could go after the low fuel warning light comes on...
The KTM manual only says that when the light comes on, the trip odo changes to zero and counts up ....
doesn't say how far it will count or what those numbers represent...???
Anyone have a guess as to what the numbers mean???
Do we care what the numbers mean??
Light came on at about 125 miles
the count got to 295 before I found a gas pump....
I put 2.9 gallons in at 165 miles....
50/50 mix of open desert & pavement, I averaged 58 MPG on day1 and 56 MPG on day 2
I have run totally dry at 145 miles on my 08 model in similar riding...
SKINNY screwed with this post 11-19-2012 at 08:32 AM
SKINNY is online now   Reply With Quote
Old 11-19-2012, 10:10 AM   #6293
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,315
Interesting post. Thanks. That suggests you have about 200 miles range out of a tankful. But the confusing part is the fuel light mileage count. If the light came on at 125 miles and at the pump your low fuel count was up to 29.5 miles, then you actually got about 186 miles worth of range in a tankful and averaged 53.27 MPG.
That is close to what I experience on my 2012, although the ecomomy seems to be improving. My low light typically comes on about 135 miles. I have the motor on the soft map setting. I usually get low 50mpg and usually refuel at about 160 miles or so. I'm getting more than 50mpg, but not much. I am easy on the throttle too. I cruise the highways above 74 or so in the country and mid 60's around cities.
I think if I stayed about 55mph in sixth gear I could probably get close to 60mpg.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 11-19-2012, 11:32 AM   #6294
RoteEddie
Oddometer: 531
My Evo 2 kitted 12' averages 51,35 mpg. Worst 47,49, best 54,94 mpg. Pretty impressive!
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is offline   Reply With Quote
Old 11-19-2012, 12:17 PM   #6295
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,026
Do you guys use metric gallons-always wanted to know
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 11-19-2012, 01:09 PM   #6296
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,944
I've run mine dry at like 90 before.
Old 11-19-2012, 01:42 PM   #6297
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,586
Dirty
I think RoteEddie is converting from litres to US gallon. I've had 70 mpg imperial (UK) before, but mostly I get in the low to mid 60's using the mild map.
About running the tank low - I thought the thinking was to fill up before the low fuel light came on in an attempt to stop the fuel pump self destructing. Do I need to keep doing this, cos' it's a bit of a PITA.
MeinMotorrad is offline   Reply With Quote
Old 11-19-2012, 02:15 PM   #6298
RoteEddie
Oddometer: 531
Correct! We measure in litres, but I use an app called Road Trip to log my riding. Easy to convert from l/100 km to mpg
14' KTM 500EXC
Old 11-19-2012, 02:31 PM   #6299
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 929
BTDT several times and once in a real sandy/duney streach out at 75
I have never gotten 150 out of a tank
Ride the DEZ
76 CB750
Old 11-19-2012, 02:32 PM   #6300
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,376
I'm looking at a 690 for my next bike and have heard mixed reports about the differences between a 2009-2011 690 and 2012+.
Are there any differences other then the seat height, suspension travel, engine displacement, and headlight?
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Times are GMT -7.   It's 02:14 PM.
