Old 11-19-2012, 02:54 PM   #6301
Velociraptor
TrackBum
Oddometer: 1,122
Thanks a ton for that info. I just ordered a couple of those gadgets from you. The first time I had my pump out it took a long time to figure out how to disconnect those things! I guess I managed to do it OK as I have had no problems, but the perfect tool is always a godsend.
Originally Posted by ktmmitch View Post
We have had problems getting those "snap" connectors apart,once they have been immersed in fuel for a while,and had a couple of bikes that were loosing fuel pressure and would start,but not run,because owners had used screwdrivers etc to push back the barbs on the connectors when getting them apart.This meant they did not re-secure properly when re connected,and the fuel pump pressure was forcing them apart,so loosing pressure.But you could not tell,because the leaky connector just leaks internally into the tank.The only way we proved it was to pull the pump and pipework right out,put it in a bucket with petrol and cycle the pump,then we saw the fuel coming out of the connector.
Since then we have made our own plastic tool to disconnect the snap-fit connectors properly,which we supply to several KTM dealers,as even these guys struggle with them,as a lot of the SX and EXC are using the same connectors on their FI system.
Link to Clip
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 11-19-2012, 03:43 PM   #6302
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,748
Originally Posted by MeinMotorrad View Post
About running the tank low - I thought the thinking was to fill up before the low fuel light came on in an attempt to stop the fuel pump self destructing. Do I need to keep doing this, cos' it's a bit of a PITA.
I don't know what others here have been doing, but..
With my 2008, I ran it until the fuel light came on most times, however, NEVER ran it completely out of gas that I can remember. I had a little over 30k miles on it when the engine died, and was still on the original fuel pump/ filter. Although, I did carry a CA Cycleworks pump for backup on longer trips, just in case..
YRMV
BK.RD.RNR is offline   Reply With Quote
Old 11-19-2012, 11:29 PM   #6303
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 259
I mostly fill up after the fuel light is on for some time. Ran it dry a couple of times, no problems with fuel pomp. Did 28.000km so far. Change the fuel filter every year and had to buy a new injector a few month ago.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 11-19-2012, 11:36 PM   #6304
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,122
Originally Posted by SKINNY View Post
During a 2 day ride in Big Bend, I decided to see how far my 2012 690 could go after the low fuel warning light comes on...
The KTM manual only says that when the light comes on, the trip odo changes to zero and counts up ....
doesn't say how far it will count or what those numbers represent...???
Anyone have a guess as to what the numbers mean???
Do we care what the numbers mean??
I ran my 08 out of gas may 6-8 times. The best I ever got was 32.4 miles after the low fuel light came on but I also remember running out of fuel at 24.
I just posted a new (1 mile) 2011 690 for sale in the flea market. I've also got a few extras I may be willing to sale separately as well...
http://advrider.com/forums/showthrea...8#post20081878
rickypanecatyl is offline   Reply With Quote
Old 11-20-2012, 04:18 AM   #6305
Oldbear
Don't want a pickle
Oddometer: 239
Originally Posted by TheMuffinMan View Post
I'm looking at a 690 for my next bike and have heard mixed reports about the differences between a 2009-2011 690 and 2012+.
Are there any differences other then the seat height, suspension travel, engine displacement, and headlight?
That's about it. Well, there are a few other small changes, mainly cosmetic.
20082011 Enduro models share the same instrument panel with 2012 Enduro R, previous Enduro R had a different one. I think the 2012 model also has slightly different mounting points on the side panels.
Oh yeah, 2012 model also has a different oil pump cover because of the new oil pressure switch. The official service interval also went up from 7,5k to 10k for the 2012.
Other than that there shouldn't be too many differences.
Oldbear is offline   Reply With Quote
Old 11-20-2012, 07:04 AM   #6306
wsmc831
wsmc831's Avatar
Oddometer: 759
Actually, 08 and 12 share the same instrument cluster/light (as well as other 690's). 09-11 Enduro's use a setup off the exc's, small dash, rubber strap mounted smaller headlight.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 11-20-2012, 07:45 AM   #6307
SKINNY
SKINNY's Avatar
Oddometer: 645
The 2012 model has a much better turn radius than previous models...
different lower triple clamp...I think
my 2008 model has the same turn radius as the Exxon Valdez...
SKINNY is offline   Reply With Quote
Old 11-20-2012, 08:11 AM   #6308
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,605
Only time this is really a problem is when you are rolling it around in the garage
Seth S
Seth S is offline   Reply With Quote
Old 11-20-2012, 09:53 AM   #6309
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,277
I find it a pain on the singletrack switchbacks here in the Rockies. I havent mastered the wheelie turn yet on it
Dont think I ever will either.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 11-20-2012, 10:02 AM   #6310
CordR
Oddometer: 513
I think this was touched on awhile back but couldn't find the answer.
With the bikes being so similar (the '12 vs all the previous years), and the change from 7.5 to 10K, would it be safe to ASSume that all years are safely capable of a 10K service interval?
Or are there some major/minor mechanical differences that I'm not understanding?
Always looking to be educated.....
C
CordR is offline   Reply With Quote
Old 11-20-2012, 01:11 PM   #6311
Oldbear
Don't want a pickle
Oddometer: 239
Right, thank's for the correction. I also realized that I wrote "oil pump cover" in my previous post when I meant "oil filter cover"
That new filter cover (with the new oil pressure switch) means that you need an open-ended short filter so the filters from previous models are not compatible.
You can still use old type filters but then you have the annoyance of watching the oil pressure light glowing in the dash.
Old 11-20-2012, 03:45 PM   #6312
NovaMoto
Oddometer: 133
Hello all!
Can I ask that someone out there with a 2011 ER & TuneECU snap a screenshot of the 'Diagnostics' page; specifically the values under throttle? Blip the throttle several times then snap a photo with it closed :)
The 11 ER has a different TPS/TB from the 08-10 ER thus my question.
It's the best I can get in terms of APAD/THAD values (connector attached of course)
Thanks all
NovaMoto screwed with this post 11-20-2012 at 04:32 PM
NovaMoto is offline   Reply With Quote
Old 11-20-2012, 04:30 PM   #6313
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Yep, Everywhere else I steer with the throttle
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 11-21-2012, 12:52 AM   #6314
GezwindeSpoed
Oddometer: 259
Suspension travel 275 -> 250mm for 2010 to 2012 enduro R
Old 11-21-2012, 02:55 AM   #6315
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,176
My dealer and I learned this the hard way. Replaced lots of parts searching for the reason for the low oil pressure light. Turned out the 2011 filters were installed at the first service. Correct 2012 filters solved it.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Times are GMT -7.   It's 02:50 AM.
