Old 11-20-2012, 08:04 AM   #6331
wsmc831
wsmc831's Avatar
Oddometer: 729
Originally Posted by Oldbear View Post
That's about it. Well, there are a few other small changes, mainly cosmetic.
20082011 Enduro models share the same instrument panel with 2012 Enduro R, previous Enduro R had a different one. I think the 2012 model also has slightly different mounting points on the side panels.
Oh yeah, 2012 model also has a different oil pump cover because of the new oil pressure switch. The official service interval also went up from 7,5k to 10k for the 2012.
Other than that there shouldn't be too many differences.
Actually, 08 and 12 share the same instrument cluster/light (as well as other 690's). 09-11 Enduro's use a setup off the exc's, small dash, rubber strap mounted smaller headlight.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 11-20-2012, 08:45 AM   #6332
SKINNY
SKINNY's Avatar
Oddometer: 645
The 2012 model has a much better turn radius than previous models...
different lower triple clamp...I think
my 2008 model has the same turn radius as the Exxon Valdez...
SKINNY is offline   Reply With Quote
Old 11-20-2012, 09:11 AM   #6333
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,469
Only time this is really a problem is when you are rolling it around in the garage
Seth S
Seth S is offline   Reply With Quote
Old 11-20-2012, 10:53 AM   #6334
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,189
I find it a pain on the singletrack switchbacks here in the Rockies. I havent mastered the wheelie turn yet on it
Dont think I ever will either.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 11-20-2012, 11:02 AM   #6335
CordR
Oddometer: 511
I think this was touched on awhile back but couldn't find the answer.
With the bikes being so similar (the '12 vs all the previous years), and the change from 7.5 to 10K, would it be safe to ASSume that all years are safely capable of a 10K service interval?
Or are there some major/minor mechanical differences that I'm not understanding?
Always looking to be educated.....
C
CordR is offline   Reply With Quote
Old 11-20-2012, 02:11 PM   #6336
Oldbear
Don't want a pickle
Oddometer: 222
Right, thank's for the correction. I also realized that I wrote "oil pump cover" in my previous post when I meant "oil filter cover"
That new filter cover (with the new oil pressure switch) means that you need an open-ended short filter so the filters from previous models are not compatible.
You can still use old type filters but then you have the annoyance of watching the oil pressure light glowing in the dash.
Oldbear is offline   Reply With Quote
Old 11-20-2012, 04:45 PM   #6337
NovaMoto
Oddometer: 133
Hello all!
Can I ask that someone out there with a 2011 ER & TuneECU snap a screenshot of the 'Diagnostics' page; specifically the values under throttle? Blip the throttle several times then snap a photo with it closed :)
The 11 ER has a different TPS/TB from the 08-10 ER thus my question.
It's the best I can get in terms of APAD/THAD values (connector attached of course)
Thanks all
NovaMoto screwed with this post 11-20-2012 at 05:32 PM
NovaMoto is offline   Reply With Quote
Old 11-20-2012, 05:30 PM   #6338
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Yep, Everywhere else I steer with the throttle
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 11-21-2012, 01:52 AM   #6339
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 232
Suspension travel 275 -> 250mm for 2010 to 2012 enduro R
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 11-21-2012, 03:55 AM   #6340
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,134
My dealer and I learned this the hard way. Replaced lots of parts searching for the reason for the low oil pressure light. Turned out the 2011 filters were installed at the first service. Correct 2012 filters solved it.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is online now   Reply With Quote
Old 11-21-2012, 05:19 AM   #6341
johnno950
Oddometer: 1,049
If the oil pressure sender is the same as the 690 rally bikes you may find the light will flicker/etc from time to time.The switch isnt very good quality and if mounted at 10am on the cover same as rallys will glow flicker when idling on side stand,was worried and checked oil pressure at oil filter housing reading was 55psi at idle with cold 10/60w motorex crosspower oil, what is the part no for a 2012 r filter?
johnno950 screwed with this post 11-21-2012 at 05:32 AM
johnno950 is offline   Reply With Quote
Old 11-21-2012, 05:42 AM   #6342
Oldbear
Don't want a pickle
Oddometer: 222
Part number for the filter is 75038046100.
The switch is located at the end of the pipe that starts from the filter cover (#31 in the picture).
Old 11-21-2012, 06:58 AM   #6343
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Actually, 08 and 12 share the same instrument cluster/light (as well as other 690's). 09-11 Enduro R's use a setup off the exc's, small dash, rubber strap mounted smaller headlight.
Actually, outside US, non R Enduro has been produced and sold even in the "mid years"...
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio is offline   Reply With Quote
Old 11-21-2012, 07:02 AM   #6344
johnno950
Oddometer: 1,049
Same filter as the rally replicia,wonder if the sender same part no,583 38 091 100?,be interested if the swich on the 2013 690 is a more reliable unit.
Old 11-21-2012, 09:09 AM   #6345
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 577
C
I would think so, but I'm far from an expert, so don't believe my word on it. I tend to service oil & filters every 5k km's on my '08, just to be sure (mixed track, offroad and street use).
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos is offline   Reply With Quote
Times are GMT -7.   It's 06:08 PM.
