Old 11-24-2012, 04:07 PM   #6346
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by RoninMoto View Post
I added an extra loop of fuel line to get the filter out of the way of the air box. I am currently running a WIX (i think) universal plastic filter. It is visible from the side of the bike which is nice.
Sorry about the bad picture. I will try to get a better one up here soon if you guys want.
Do you know what the micron rating is by chance? DO we really need 10 micron?
Just say'IN
crankshaft is offline   Reply With Quote
Old 11-24-2012, 04:14 PM   #6347
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,695
I'll know when I look at the part number tomorrow and google it. My bike is locked up tight and tucked in for the night.. and its 1:00 am.
In Portugal the "95" (US 87 equivalent) was a dark color, almost black. The "98" (US 89 I think) was a nice blue. Almost like it had 2 stroke oil. I'm not sure if they add dye to it? Anyway, my filter is black now from 2 tanks of fuel from Portugal. No problems with the bike running but I will keep you updated.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 11-24-2012, 04:26 PM   #6348
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,137
Exactly what I will do , but use a golan or disposable car filter , 20 - 25 micron , 10 will block as with the EXC injector filters , we had a recall to swap out to 20 .
I will make it quick and easy to change . There is plenty o reusable filters on the market , earls do some rocket industries do some.
Mudguts screwed with this post 11-24-2012 at 04:31 PM
Mudguts is offline   Reply With Quote
Old 11-24-2012, 04:32 PM   #6349
Mini Trail
nb
Oddometer: 2,323
If you skip the internal filter, how do you connect the fuel lines? They took out a few feet of (crimped) fuel line when my pump was replaced, but the filter is close to the other end. Where do you get the little clamps?
Your cycle had a bell on it.
Mini Trail is offline   Reply With Quote
Old 11-24-2012, 04:37 PM   #6350
Mudguts
Mudguts's Avatar
Oddometer: 2,137
Originally Posted by modeselector View Post
New to this bike and new to fuel-injection so I'm turning to you "wise guys" for advice and/or input. I realize many are switching to the metal Napa filter and I will probably do the same. That said...
How much benefit would a secondary, in-line filter like this be?
http://justgastanks.com/product_info...oducts_id=2511
Those glass filter are a screen more then a filter , quick and easy to clean and change. You can get similar but billet and replaceable filter but a little bigger .
Old 11-24-2012, 04:49 PM   #6351
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
My local parts store had plastic fuel line repair kits in 1/4". Two brass barbed pipes and 4 crimps clamps for $5, worked like a charm.
Just say'IN
Old 11-24-2012, 05:29 PM   #6352
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,315
Seat Concepts for 690R
Just want to shout out for Seat Concepts. I used a KTM gelseat on my 950 for 7 years. Good for 6 hours anyway. I use a stock Yamaha WR250R seat with the addition of a 'Buttpad' to similar effect. Not so with my 2012 690R...
2 hours was tops with the stock seat. It is too soft for me. The buttpad helped, but not enough. So I bought the Seat Concepts kit and I am shocked at how nice it is. They must have the secret sauce for foam pads. Firm, but not too firm. Vibration absorbtion is terrific.
I spent an extra $40 buying staple gear that wasn't strong enough to do the job on that fiberglas seat pan. I gave finally it to a seat guy and presto! But the whole thing cost nearly $300 by the time it was finished. Just sayin...
Great value since it works!
PS: The motor is finally smooth all the way through the range at 3500 miles. It's still a single, but right up there with my old LC8 twin at highway speeds.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 11-24-2012, 05:44 PM   #6353
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,424
Drat...there was one forsale here in NZ including the seat which I almost bought but then I read too many reviews that said they were too hard and don't bother...now this report singin its praises! I guess like everything in motorcycling (tires, exhausts, shocks, make, model, yada yada) the only way to know if it works for you is for you to try it. I should have bought it
PS: my bike was nowhere near as clean as yours after 3500 miles
My EXC530 Adventure
Night Falcon is offline   Reply With Quote
Old 11-24-2012, 06:44 PM   #6354
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Thanks for the reply's.
Where would be a good place to "snip" for the in-line. Would like easy access. Does anyone know if the fuel line is 5/16 or 3/8's?
modeselector is offline   Reply With Quote
Old 11-24-2012, 06:51 PM   #6355
modeselector
Common as muck
Oddometer: 624
Trying to picture the "extra loop" part. Would be interested in seeing a close up picture of your set-up.
Also curious - anyone carry a spare quick connect (fuel line) piece as part of your parts/tool kit? Heard they may prone to failing.
Old 11-24-2012, 07:07 PM   #6356
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
I removed my quick disconnect and put the filter there. I have a 5/16 barbed end filter.
Just say'IN
Old 11-24-2012, 07:18 PM   #6357
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Albie View Post
I think you found the problem.
Interesting ....a week ago I asked about this potential issue:
Originally Posted by motoged
Riders,
Question: Why is it that these "cheap" plastic filters are used for a pressure between 40-60 lbs psi , whereas years some years ago the BMW folks replaced their internal filters with metal-clad filters "because of the psi factor" ( ie. the filter would not explode due to pressure). I externalized the fuel filter on my 1100GS with the appropriate metal-clad filter and have not had to go into the tank to change filters.
Just wondering
I haven't read here or heard otherwise that these cheapo plastic filters have caused any problems.....
Motoged
Most cars,petrol & diesel,now use plastic injection-moulded 2part filter housings,that are usually ultrasonically welded together after the filter element is put in.
The vast improvement in thermoplastic materials over the last couple of decades has allowed for the safe replacement of metal-clad filters,and other under-bonnet parts,from metal to plastic.
www.rally-raidproducts.co.uk
So, thermoplastic welding ain't all it's cracked up to be. .....so why don't we put that metal (quick-disconnect replacement) filter ( WIX 33012) in the tank as well????
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 11-24-2012, 07:30 PM   #6358
motoged
motoged's Avatar
Oddometer: 908
There are plastic QD's and metal ones....Buy the metal one....and also several extra Viton o-rings for the unit as they are easily nicked when reconnecting unless you are careful....press the release flange when reconnecting rather than just jamming them together to reconnect .
The failures are either cut o-rings or plastic ends (where fuel line is clamped) breaking off the main housing.
Learned all that years ago on the BMW GS thread....or Micapeak forum
P.S. CFL Grey Cup Game tomorrow.....new 50" plasma but no HD box connection yet....another excuse to not clean the garage
Ged Schwartz
Kamloops , BC
Old 11-24-2012, 07:41 PM   #6359
motoged
motoged's Avatar
Oddometer: 908
Potential for the 690???
Algae fueled, turbo charged Baja 1K bike.
I don't know if I saw this here first. A San Diego project to Baja Test future fuels. There always seems to be a camera around.....
http://www.youtube.com/watch?feature...&v=E7yePC-4nlg
Here's how it turned out......
http://www.youtube.com/watch?v=VRoLy...feature=relmfu
http://www.youtube.com/watch?v=DCqD2qodtdA
Looks like a beemer frame and drive train
Maybe BobZ can work this into his 690 alternative
Ged Schwartz
Kamloops , BC
Old 11-24-2012, 07:42 PM   #6360
Mudguts
Mudguts's Avatar
Oddometer: 2,137
Just went out and got an external fuel filter. A proflow 100m $40 , I will get a couple of replacement filters a 10 & 30m
http://pfefittings.com/product_info....oducts_id=6140
I suppose bigger the filter the longer it takes to clog so I'll try a 10 , being that is external it is easy to get to
Times are GMT -7.   It's 10:59 AM.
