Old 12-10-2012, 03:44 AM   #6496
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
Originally Posted by Roadracer_Al View Post
Ha. Yeah. I bought a V-Strom 1000, and it has a ridiculous lean surge (EPA mandated, have to add a PowerCommander to make it run right), and an un-believable clutch chudder at low-to-mid RPM. Makes me wish I'd bought a Wee.
Same here. Had an '03 1000, and aside from the chudder, idle hammer, and lean surge it was a good ride. PC fixed the surge. SV1000 clutch fixed the chudder, and I just leared to live with the idle hammer. Oh, yeah... SV calipers, and master cylinder got the brakes working right.... Now I have a 2012 DL650A, and LOVE it!! Not as 2nd gear wheelie happy as the Vee, but I'm showing high 50's for mpg's so far. EVERY bike has something that needs fixing... The 690 has maybe more than most, but it's by far one of the best all around bikes I've owned.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 12-10-2012, 07:37 AM   #6497
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,808
Originally Posted by mickd View Post
HI ALL
well i had my first PITA on the 690 today,having a nice easy ride in mt mee,the 690 stalled with a loud "POP" and a PSHHHHHHH, the sound came from under the air box area,so i had a good look around only to find the rubber boot had came away (see pic) and also the airbox was pushed back towards the battery
bike is a 2012,with less than 2000ks with a akro slip on inc akro mapping.
1, so what would make this happen,
2, is there a fix for this,cos i dont want it to happen again (PITA)
3, has there been a recall for this
Mine did it too. 2012. I think it was because I was being impatient, and blipping the throttle to quickly while starting. I have been sure to keep my hand off the throttle when starting since, and have not had a repaeat...
BK.RD.RNR is offline   Reply With Quote
Old 12-10-2012, 07:41 AM   #6498
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,808
Originally Posted by Bumpaman View Post
Hi all. I want to use the Kriega Fork Seal Savers on my 2010 690 R but the plastic protector rings on the outer part of the fork leg have to come off. Has anyone done this and know how they come off? Just wanted to tap any expertise on the subject before I go and bung things up . Thanks very much.
I shaved some of the neoprene from the seal saver where it lined up with the ring on the forks. seemed to work pretty well.
Old 12-10-2012, 09:29 AM   #6499
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 431
Originally Posted by Sutherngintelmen View Post
Yep, that made absolutely no difference at all.
Good news is the issue is predictable and repeatable. Now just to wonder why.
Ran 15 minute idle test - puuuurrrrfect. Cut it off, put on the helmet start and stall. When temps hit 3/4, choke and puke.
Here's what happens
With all the talk about it, do you think the reg/rect is overheating? I haven't looked at it but if it's a part that's easily swapped you can borrow mine to see if it fixes the problem.
FriedDuck is offline   Reply With Quote
Old 12-10-2012, 09:35 AM   #6500
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Originally Posted by TheMuffinMan View Post
V-strom 650's
I my 690.
Uhhh not so much, grenaded my Vstrom motor at 46K miles.
Old 12-10-2012, 12:11 PM   #6501
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 982
Here's what happens
Is at 3/4 temp also where your fan kicks in? If so, check if unplugging the fan sensor has an effect.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 12-10-2012, 03:50 PM   #6502
DirtJack
DirtJack's Avatar
Oddometer: 1,600
After it stalls does it re-start? If not, do you hear the fuel pump prime sequence? If you don't hear it, I would suggest replacing the fuel pump. Your problem sounds similar to problems described in this FI thread. I replaced mine with the CA Cycleworks FP-HUS. Problem fixed. Many other 690 owners have reported good results with this pump and it is much cheaper than the OEM KTM pump.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 12-10-2012, 09:40 PM   #6503
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 785
Unplugging the fan sensor will not allow the fan to come on at all. Its a simple thermo switch, only 2 wires.
tattewell is offline   Reply With Quote
Old 12-11-2012, 03:45 AM   #6504
Bill the Bong
Supern00ba
Oddometer: 982
Exactly
Old 12-12-2012, 01:14 PM   #6505
dguevin
Always ginger cravin
dguevin's Avatar
Oddometer: 19
Here's what happens
Mine used to do that too!!.. It stopped doing it after a valve adjustment on my bike... I did also replace the fan swith for the suzuki ltz too over the same winter. What fixed it ?? I'd say the valves but with the new switch my fan kicks on around the 5th bar of heat out of 8 and rarely goes over 6 bars even if stopped for a while.
Dan
dguevin is offline   Reply With Quote
Old 12-12-2012, 01:23 PM   #6506
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,717
When my 690 blew the headgasket last spring we had to stop at a random house and fill the radiators with water. The bike was burning water in a low performance water injection kind of way...bike still ran well amazingly. But when the water was running out the temperature gauge was pegged and it will start to flash as well as a warning light comes on. The bike ran fine right to that point but I was into service and shutting it off as fast as possible. I have not torn into the bike since to fix it other than to dump the remaining liquid out.
Seth S
Seth S is offline   Reply With Quote
Old 12-13-2012, 08:27 AM   #6507
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Goodbye, Adios, Maa as-alaama
I just sold my 2010 690 R using the "bikes" section of the Flea Market. My advert resulted in a number of potential buyer leads with the sale eventually going to a fellow senior from Montana. Start to finish the process took 4 days. It truly is a big tent here.
Being 66 I am getting softer and softer preferring to do my desert exploring now in this (a 2013 Jeep Rubicon).
DSCN1496
DSCN1520
After a lifetime of riding I think it is safe to say I have owned my last motorcycle.
Since I will not likely be posting here again I want to thank all of the members who provided a myriad of useful information and creative solutions/fixes for the 690. This site is the best and I wish all inmates a Merry Christmas & a Happy New Year.
Cheers,
Tom
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 12-13-2012, 10:40 AM   #6508
Seth S
Seth S's Avatar
Oddometer: 4,717
Originally Posted by nippybit View Post
DSCN1520
Tom
Just a heads up...the Rubicon shares the same EFI system as the 690.
just kidding. Enjoy your new toy.
Seth S
Old 12-13-2012, 11:54 AM   #6509
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Good Grief--Is The Rubicon The Same As The 690?
Seth,
I am now going down to the garage to see if the muffler has melted-off my left rear turn signal, then I am going to check to see if the radiator shrouds have pulled out of the radiator causing a leak, then I am going to see if the radiator fan is contacting the radiator eating holes in it, then I am going to see if I have the same fuel pump as the 690, then I am going to check the speedo to see if there is white powder in it indicating impending doom, then I will pull each injector and see if they are spraying, then I will sit on the drivers seat again and see if feels like a two-by-four wrapped in barbwire (if so I will quickly be on the phone to Jim Renazco), then I will sit and worry about what I have missed.
Just for a minute, before scrolling down, you had me going then I remembered that Chrysler makes Jeep and they are now owned by Fiat so I knew the FI unit had to be made by Fueleo Inzionne Especialle Superleggera Bertone Magnetti-Marelli, of Turin.
Cheers,
Tom
Old 12-13-2012, 12:19 PM   #6510
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Cheers,
Tom
Well Merry Xmas and Happy New Year to you as well. Have fun with the Jeep!
Times are GMT -7.   It's 12:46 PM.
