Old 12-10-2012, 01:11 PM   #6526
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 952
Originally Posted by Sutherngintelmen View Post
Yep, that made absolutely no difference at all.
Good news is the issue is predictable and repeatable. Now just to wonder why.
Ran 15 minute idle test - puuuurrrrfect. Cut it off, put on the helmet start and stall. When temps hit 3/4, choke and puke.
Here's what happens
Is at 3/4 temp also where your fan kicks in? If so, check if unplugging the fan sensor has an effect.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 12-10-2012, 04:50 PM   #6527
DirtJack
DirtJack's Avatar
Oddometer: 1,459
After it stalls does it re-start? If not, do you hear the fuel pump prime sequence? If you don't hear it, I would suggest replacing the fuel pump. Your problem sounds similar to problems described in this FI thread. I replaced mine with the CA Cycleworks FP-HUS. Problem fixed. Many other 690 owners have reported good results with this pump and it is much cheaper than the OEM KTM pump.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 12-10-2012, 10:40 PM   #6528
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 765
Unplugging the fan sensor will not allow the fan to come on at all. Its a simple thermo switch, only 2 wires.
tattewell is offline   Reply With Quote
Old 12-11-2012, 04:45 AM   #6529
Bill the Bong
Supern00ba
Oddometer: 952
Exactly
Old 12-12-2012, 02:14 PM   #6530
dguevin
Always ginger cravin
dguevin's Avatar
Oddometer: 19
Here's what happens
Mine used to do that too!!.. It stopped doing it after a valve adjustment on my bike... I did also replace the fan swith for the suzuki ltz too over the same winter. What fixed it ?? I'd say the valves but with the new switch my fan kicks on around the 5th bar of heat out of 8 and rarely goes over 6 bars even if stopped for a while.
Dan
dguevin is offline   Reply With Quote
Old 12-12-2012, 02:23 PM   #6531
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,452
When my 690 blew the headgasket last spring we had to stop at a random house and fill the radiators with water. The bike was burning water in a low performance water injection kind of way...bike still ran well amazingly. But when the water was running out the temperature gauge was pegged and it will start to flash as well as a warning light comes on. The bike ran fine right to that point but I was into service and shutting it off as fast as possible. I have not torn into the bike since to fix it other than to dump the remaining liquid out.
Seth S
Seth S is online now   Reply With Quote
Old 12-13-2012, 09:27 AM   #6532
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Goodbye, Adios, Maa as-alaama
I just sold my 2010 690 R using the "bikes" section of the Flea Market. My advert resulted in a number of potential buyer leads with the sale eventually going to a fellow senior from Montana. Start to finish the process took 4 days. It truly is a big tent here.
Being 66 I am getting softer and softer preferring to do my desert exploring now in this (a 2013 Jeep Rubicon).
DSCN1496
DSCN1520
After a lifetime of riding I think it is safe to say I have owned my last motorcycle.
Since I will not likely be posting here again I want to thank all of the members who provided a myriad of useful information and creative solutions/fixes for the 690. This site is the best and I wish all inmates a Merry Christmas & a Happy New Year.
Cheers,
Tom
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 12-13-2012, 10:54 AM   #6533
Ryman
Oddometer: 756
Rubicon On.
Ryman is offline   Reply With Quote
Old 12-13-2012, 11:40 AM   #6534
Seth S
Seth S's Avatar
Oddometer: 4,452
Originally Posted by nippybit View Post
DSCN1520
Tom
Just a heads up...the Rubicon shares the same EFI system as the 690.
just kidding. Enjoy your new toy.
Seth S
Old 12-13-2012, 12:54 PM   #6535
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Good Grief--Is The Rubicon The Same As The 690?
Seth,
I am now going down to the garage to see if the muffler has melted-off my left rear turn signal, then I am going to check to see if the radiator shrouds have pulled out of the radiator causing a leak, then I am going to see if the radiator fan is contacting the radiator eating holes in it, then I am going to see if I have the same fuel pump as the 690, then I am going to check the speedo to see if there is white powder in it indicating impending doom, then I will pull each injector and see if they are spraying, then I will sit on the drivers seat again and see if feels like a two-by-four wrapped in barbwire (if so I will quickly be on the phone to Jim Renazco), then I will sit and worry about what I have missed.
Just for a minute, before scrolling down, you had me going then I remembered that Chrysler makes Jeep and they are now owned by Fiat so I knew the FI unit had to be made by Fueleo Inzionne Especialle Superleggera Bertone Magnetti-Marelli, of Turin.
Cheers,
Tom
Old 12-13-2012, 01:19 PM   #6536
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,350
Cheers,
Tom
Well Merry Xmas and Happy New Year to you as well. Have fun with the Jeep!
Old 12-13-2012, 01:29 PM   #6537
DirtJack
DirtJack's Avatar
Oddometer: 1,459
Nippy, I passed your point 6 years ago, so I know where you're coming from, but I'm keeping mine a bit longer, but not sure how much longer. I enjoyed your contributions to the 690 threads. Best of luck in the future.
2008 KTM 690 Enduro
Old 12-13-2012, 01:46 PM   #6538
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,368
I was just looking at this in the OC:
and was wondering if anyone has installed one of these:
Morimoto Mini DS2 HID Projector in one of these:
Yellow Pig is online now   Reply With Quote
Old 12-13-2012, 04:43 PM   #6539
motoged
motoged's Avatar
Oddometer: 907
Nippy,
Was just wondering where all that industrial velcro is on the jeep.....and did you wrap the headers in that mummy frayed tape?
Happy trails......
61 and still have 3 bikes....wanna ride until I really can't....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 12-13-2012, 05:46 PM   #6540
Uller
Uller's Avatar
Oddometer: 1,672
Enjoy your new adventure!!!!!
Uller is offline   Reply With Quote
Times are GMT -7.   It's 09:30 AM.
