Old 12-18-2012, 02:37 PM   #6541
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by ktmmitch View Post
We have designed a replacement solid front disc,300mm,to suit the KTM 690 Enduro which has a hole to accept the KTM EXC magnet & circlip,to line up with the M8 tapped hole in the caliper mount.
This will enable an ICO to be used without having to drill the existing floating disc,or glue a magnet on.
We also have a rear disc designed to offer as a straight replacement for the OEM item.
These are expected to be available by end January.
Another spin-off is they will fit KTM 950/990 Adventure models,all 690 & 450 Rallye.
Can you make a solid rear rotor for the 690? I have a Moose solid rear disc for my 500 and love it for enduro, my pads last much longer now.
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-18-2012, 02:46 PM   #6542
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,177
It will fit,but the flat sensor for the speedo is not activated by a magnet,but from the 6 disc screws.The hole is for a KTM EXC magnet to work with an ICO,or similar.
Hello - I must buy an ICO Racing 'Checkmate' computer to compete in an event in 2014 aboard a '12 690R. Do I want your front disk to make it easier?
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 12-18-2012, 02:48 PM   #6543
Velociraptor
TrackBum
Oddometer: 1,122
Brass fuel line quick disconnect
http://www.beemerboneyard.com/cpcqkdiscon1.html
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 12-18-2012, 02:56 PM   #6544
toast
toast's Avatar
Oddometer: 243
Thanks guys!
Thanks for the replies, I have the parts on order and they are due in Thursday.
Happy Holidays my friends! Ride on!
2008 KTM 530 exc
2007 KTM 950 Super Enduro
YouTube
Spot
toast is offline   Reply With Quote
Old 12-18-2012, 02:56 PM   #6545
giuspepp
Oddometer: 4
spring pre-load adjuster
Hi guys!
Which of these tools should i buy to adjust the spring pre-load,U6910066 or U6951172?(bike 690enduro r)
U6910066: http://www.cyclehuttktm.com/ktm-part...tment=bigbikes
U6951172: http://www.cyclehuttktm.com/ktm-part...tment=bigbikes
and someone does know where i can find it in europe?
giuspepp is offline   Reply With Quote
Old 12-18-2012, 02:58 PM   #6546
NovaMoto
Oddometer: 133
Why is it they cheap out on shit like this? Rotten. I'm buying the MP bits too!
Originally Posted by toast View Post
My fuel line connector pictured below is broken and KTM is back-ordered until Dec 28.
This is the connector under the seat that allows you to take the sub frame off and provide you the convenience of a quick disconnect of the fuel line.
Do any of you fine inmates have this part you can sell me?
I also heard some people swap the factory plastic stuff for some quality brass fittings, but I can't seem to find that posting.
Any help is appreciated.
NovaMoto is offline   Reply With Quote
Old 12-18-2012, 03:07 PM   #6547
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,698
Originally Posted by giuspepp View Post
Hi guys!
You don't have one of these in your toolbox?
Old 12-18-2012, 04:35 PM   #6548
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,610
it will make life easier. I drilled my rotors for a magnet to run my ICO Rally.
Seth S
Seth S is offline   Reply With Quote
Old 12-18-2012, 04:44 PM   #6549
690Emaf10
Oddometer: 68
Were you able to find one? I have the #10 from that pic if that helps. It includes the 120mm hose and the quick disconnect. Item #75007016050
Toast
Ride on!
690Emaf10 is offline   Reply With Quote
Old 12-18-2012, 05:01 PM   #6550
Seth S
Seth S's Avatar
Oddometer: 4,610
Toast
The brass one from the Bimmer barn works great as a direct replacement and it is much more rugged. Or just go the inline fuel filter route. Both are worlds better than the stock piece...which will just break again.
Seth S
Old 12-18-2012, 05:39 PM   #6551
MrHix
MrHix's Avatar
Oddometer: 384
OK,
Thanks.
MrHix
MrHix is offline   Reply With Quote
Old 12-18-2012, 09:15 PM   #6552
13x
13x's Avatar
Oddometer: 48
Hi guys! Got my 2013 Enduro R sitting @ the local dealership, thinking of getting my exos, rad guard and air filter fixed up before i run any miles on it.
Could anyone advice on the RR foam air filter conversion (seems too exposed) or should i just keep the snorkel and run a uni foam filter?
I'm setting up the bike for adventure riding and simple trail riding.
Thank you in advance!
13x
13x is offline   Reply With Quote
Old 12-19-2012, 12:06 AM   #6553
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,220
13x
I run the uni filter in mine and its fine for what your describe. Easy to clean and much better than the stock paper jobby.
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 12-19-2012, 12:42 AM   #6554
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
13x
What country are you in? The 13s have not hit the states yet.
Old 12-19-2012, 01:18 AM   #6555
13x
13x's Avatar
Oddometer: 48
sweet! thanks!
Singapore, I could be wrong abt the MY12\13 thou. Arrived earlier this mth from KTM motherland. Any major changes between both years?
Times are GMT -7.   It's 11:33 AM.
