Old 12-18-2012, 03:56 PM   #6571
giuspepp
Oddometer: 4
spring pre-load adjuster
Hi guys!
Which of these tools should i buy to adjust the spring pre-load,U6910066 or U6951172?(bike 690enduro r)
U6910066: http://www.cyclehuttktm.com/ktm-part...tment=bigbikes
U6951172: http://www.cyclehuttktm.com/ktm-part...tment=bigbikes
and someone does know where i can find it in europe?
giuspepp is offline   Reply With Quote
Old 12-18-2012, 03:58 PM   #6572
NovaMoto
Oddometer: 133
Why is it they cheap out on shit like this? Rotten. I'm buying the MP bits too!
Originally Posted by toast View Post
My fuel line connector pictured below is broken and KTM is back-ordered until Dec 28.
This is the connector under the seat that allows you to take the sub frame off and provide you the convenience of a quick disconnect of the fuel line.
Do any of you fine inmates have this part you can sell me?
I also heard some people swap the factory plastic stuff for some quality brass fittings, but I can't seem to find that posting.
Any help is appreciated.
NovaMoto is offline   Reply With Quote
Old 12-18-2012, 04:07 PM   #6573
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,425
Originally Posted by giuspepp View Post
Hi guys!
You don't have one of these in your toolbox?
Old 12-18-2012, 05:35 PM   #6574
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,471
Originally Posted by Pantah View Post
Hello - I must buy an ICO Racing 'Checkmate' computer to compete in an event in 2014 aboard a '12 690R. Do I want your front disk to make it easier?
it will make life easier. I drilled my rotors for a magnet to run my ICO Rally.
Seth S
Seth S is offline   Reply With Quote
Old 12-18-2012, 05:44 PM   #6575
690Emaf10
Oddometer: 68
Were you able to find one? I have the #10 from that pic if that helps. It includes the 120mm hose and the quick disconnect. Item #75007016050
Toast
Ride on!
690Emaf10 is offline   Reply With Quote
Old 12-18-2012, 06:01 PM   #6576
Seth S
Seth S's Avatar
Oddometer: 4,471
Toast
The brass one from the Bimmer barn works great as a direct replacement and it is much more rugged. Or just go the inline fuel filter route. Both are worlds better than the stock piece...which will just break again.
Seth S
Old 12-18-2012, 06:39 PM   #6577
MrHix
MrHix's Avatar
Oddometer: 384
Originally Posted by ktmmitch View Post
It will fit,but the flat sensor for the speedo is not activated by a magnet,but from the 6 disc screws.The hole is for a KTM EXC magnet to work with an ICO,or similar.
OK,
Thanks.
MrHix
MrHix is offline   Reply With Quote
Old 12-18-2012, 10:15 PM   #6578
13x
13x's Avatar
Oddometer: 48
Hi guys! Got my 2013 Enduro R sitting @ the local dealership, thinking of getting my exos, rad guard and air filter fixed up before i run any miles on it.
Could anyone advice on the RR foam air filter conversion (seems too exposed) or should i just keep the snorkel and run a uni foam filter?
I'm setting up the bike for adventure riding and simple trail riding.
Thank you in advance!
13x
13x is offline   Reply With Quote
Old 12-19-2012, 01:06 AM   #6579
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,011
13x
I run the uni filter in mine and its fine for what your describe. Easy to clean and much better than the stock paper jobby.
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 12-19-2012, 01:42 AM   #6580
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,485
13x
What country are you in? The 13s have not hit the states yet.
Old 12-19-2012, 02:18 AM   #6581
13x
13x's Avatar
Oddometer: 48
sweet! thanks!
Singapore, I could be wrong abt the MY12\13 thou. Arrived earlier this mth from KTM motherland. Any major changes between both years?
Old 12-19-2012, 03:53 AM   #6582
tertsu
Oddometer: 16
From MotionPro. There are different models available i.e. this one http://www.motionpro.com/motorcycle/...ect_couplings/
tertsu is offline   Reply With Quote
Old 12-19-2012, 06:19 AM   #6583
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,203
Thanks for the replies, I have the parts on order and they are due in Thursday.
Happy Holidays my friends! Ride on!
If you don't already you will soon know that the oem clamps are one and done - they need to be cut off the hoses and new ones procured. This is a good chance to change out for more field service friendly version. I was unfamiliar with high pressure FI clamps but your standard hardware store hose clamp versions are less suitable for this task.
The two auto parts places close to my house didn't have properly sized replacements, ended up ordering from here.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 12-19-2012, 06:38 AM   #6584
giuspepp
Oddometer: 4
I have already used a screwdriver with bad result,now i can't hit more the shock collar without ruin it completely and so, no one knows which tool works??U6910066 or U6951172?
Old 12-19-2012, 07:19 AM   #6585
ktmmitch
Oddometer: 597
Hi guys!
These are only for EXC,there is not enough room around the rear tank on a 690 to get 1 notch movement at a time with those C spanners.
We change the OEM(weak) lock rings for our stainless thicker locking ring,then it is possible,by using a jack-up stand to take the weight off the rear wheel,to turn the lock ring using an aluminium or brass bar.
Shock Collar
ktmmitch is offline   Reply With Quote
Times are GMT -7.   It's 04:25 PM.
