Old 01-02-2013, 10:46 AM   #6766
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,660
Originally Posted by yuu View Post
You sig confirms my thought that it's an 08 based on the pic alone. There was a bad run for bearings for the rockers that a lot of the 08 bikes got. Mostly it manifest as score marks, parallel to the rotation axis of the bearing. I don't see any there, but sure doesn't look right. Does the bearing turn freely?
Bearing turns freely... and theres no sign of heating. Also, the cam doesn't seem to have abnormal wear.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-02-2013, 10:51 AM   #6767
yuu
yuu's Avatar
Oddometer: 122
Which is a mercy... I'd be putting a new rocker on my parts list for ASAP replace. In the mean time, if it runs free and (as noted) the cam looks good then you might finish up the trip on it. Rockers are sub $60 (us) so no bad on the budget to replace and very easy as well.
Just keep an ear out for (extra) odd noises
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-02-2013, 12:50 PM   #6768
NovaMoto
Oddometer: 133
Edit: What everyone else said! :)
Is your TPS adjusted properly? All your tuning is in vain if those two sensors are out of whack. I was down a similar road with my 690 recently..
Originally Posted by MAXVERT View Post
My '08 690 has run like crap for the last year.
I've done all the tuning with TuneECU, tried different maps
etc.
The bike still stalls when off the throttle.
Can anyone recommend a tuner in the Tucson area who can help me
get this bike running right again ?
Max
NovaMoto is offline   Reply With Quote
Old 01-02-2013, 12:57 PM   #6769
yuu
yuu's Avatar
Oddometer: 122
Do you know the condition of your fuel filter? Mine was past done at 4K miles.
Have you cleaned the injector? Related to the fuel filters griming up early, the fuel injectors get an extra early does of nasty.
And just saying you've used TuneECU doesn't really give sufficient insight. It can be a tool for good or evil...
*Edit - looks like my questions were already addressed....
yuu screwed with this post 01-02-2013 at 01:31 PM
Old 01-02-2013, 01:23 PM   #6770
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,160
Thanks,
It's got a new fuel pump,
the TPS is correct,
I have tried the akro map.
Does the injector need to be cleaned in a ultra sound cleaner ?
Anyone have the part # for a new injector ?
Max
I'm heading down to Mexico sometime this next year on my 690R.
I have an extra fuel pump already and will purchase an extra injector for that JIC scenario.
The new part # is 75041023144. Cheap @ only $150 bucks for peace of mind.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 01-02-2013, 06:27 PM   #6771
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 264
Originally Posted by Ryman View Post
Anybody know who makes the little aluminum bits that replace the plastic swingarm guards. Looking for a better tie down point for the giant loop.
http://www.advmachines.com/product_p/mduro1004.htm
I'll get me coat..............
Harty is offline   Reply With Quote
Old 01-03-2013, 07:59 AM   #6772
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,660
Turns out the KTM dealer in Istanbul has new Exhaust and Intake rockers for me. I'm replacing those tonight.. they have also let me borrow a shim kit and I will return what I don't use
Old 01-03-2013, 08:05 AM   #6773
yuu
yuu's Avatar
Oddometer: 122
Nice!
Onward to Tbilisi
Old 01-03-2013, 08:26 AM   #6774
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,350
Awesome, hard to find such good dealers these days.
Old 01-03-2013, 12:59 PM   #6775
motoged
motoged's Avatar
Oddometer: 907
Noah,
That's good service and luck.....it would take me three weeks to get parts
Also following your RR and digging it.....latest intel suggests Croatia in the summer is the ticket
Have fun riding the slopes....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-03-2013, 06:35 PM   #6776
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,753
whoops wrong thread
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan screwed with this post 01-03-2013 at 07:02 PM
TheMuffinMan is online now   Reply With Quote
Old 01-03-2013, 09:05 PM   #6777
Unkgd
Oddometer: 344
Might want to replace that roller
Take this FWIW - especially as it is based on one picture. To me it looks like the surface of the roller is starting to fail and part of it is starting to flake off. Failure mode is often described as "brinneling" and basically the surface of the roller has a bunch of micro fractures and the metal starts spalling off as the fractures connect. Also looks like there is a matching track on the cam below it. Generally caused by excessive loading of the surface of the material.
Would recommend replacing the roller. Also check the other rollers as well for similar surface cracking indications.
Just out of curiousity - what weight oil are you running?
I was checking my clearance today and they are loose. So tomorrow I will shim them. On one of my intake rollers it has some funny wear or deposited that I have not seen before.
I have 1700 km to Tbilisi Georgia then I won't be riding for 4 months to rebuild the suspension and whatever else is needed. It seems like my only option would be to get to Georgia then order parts if this should be replaced. Your thoughts?
Unkgd is offline   Reply With Quote
Old 01-03-2013, 10:35 PM   #6778
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
I think I have just come up with a design for an external fuel pump /duel pump/ manifold for multiple tanks its so simple .
Now I just have to get it out of my head and on to paper
Mudguts is offline   Reply With Quote
Old 01-03-2013, 11:23 PM   #6779
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,660
I was able to replace both rocker arms last night. I have a theory about the increased loading.. I don't think the "automatic decompression" is laying completely flat when the motor is at speed.
The cam behind it was ok but there was some scaring on the decomp.
I am running 10W 60 Motul right now. Its been either that or Motorex 10W 60
Old 01-04-2013, 12:35 AM   #6780
LOZ
Oddometer: 1,201
HALLELUIAH
loz
LOZ is offline   Reply With Quote
Times are GMT -7.   It's 06:05 PM.
