Old 01-09-2013, 11:36 AM   #6841
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,771
First, unless your bikes are setup exactly similar I wouldn't compare them, each bike is different enough in stock trim and comparing two similar but not exact setups can cause a person to chase the wrong troubleshooting variables.
Basically we need to find the problem so lets be methodical. Did this problem appear out of the blue or after some change? Did the bike ever not stall?
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 01-09-2013, 12:09 PM   #6842
yuu
yuu's Avatar
Oddometer: 122
Not trying to say that the filter or injector is the root cause. Just issues than could make an existing fueling issue harder to deal with.
And his final ratio should make it feel *more* grunty and powerful. One would run out of RPMs earlier but pick up more quickly. So if you two had the same final drive, his would feel further weaker.
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-09-2013, 01:12 PM   #6843
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 888
Well it was not an exact comparison, but the fact is that there is an issue with the idling just when the throttle is cut and the clutch pulled.
The comparison between bikes engine response was related to yuu's query on fuel filter service and injector cleaning, as in fact we noticed different behavior with his bike pulling significant less.
BTW, thanks for the link in your signture, was not awar of a ktm690 info.
Agree, still it's a valid point as i'm in the auto industry and have seen quite a few problems related to injector condition.
I stand corrected on your calculation. His bike situation is worse than expected.
690R
Old 01-09-2013, 01:35 PM   #6844
Hoots
Hoots's Avatar
Oddometer: 1,376
Originally Posted by Gustavo.Ramos View Post
A friend's 690'10 Enduro R has this weird behavior:
when closing the throttle and pulling the clutch, the idle drops so low that sometimes the engine stall... This does not happen always, sometimes the revs drop low but still it manages to keep working.
Upon some testing the idle drops but slowly (maybe the idle stepper motor) gets the revs back to normal idle.
Aaah - the slip-on is the original cause. The less restrictive pipe doesn't give enough back pressure.
I have the same problem (2012 690 R), and came to a similar conclusion - not always, but occasionally - e.g. brake and clutch hard before a corner, and chuggs right down low +/- stalls - mine also resulted in a flashing oil pressure light, which persists for a while - oil pressure tested and OK.
Hoots is online now   Reply With Quote
Old 01-09-2013, 02:57 PM   #6845
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,882
check with your dealer as there is a brand new mapping just come out from ktm for this,
mickd
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is online now   Reply With Quote
Old 01-09-2013, 03:11 PM   #6846
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 323
After a Wings exhaust install, I updated my FI map to match Beanys suggestion and have no stalling but also runs a little fat for my tastes. In TuneECU my F-L switch is set to 10,10,0,0,0,0,0,0 and the FTrim is 4%.
Conversely, the Akro and stock map F-L Switch is 20,35,39,39,39,39,39,39 and the FTrim is 0%.
Maybe the butterflys are closing (because of the F-L switch values) and choking the engine off???
Probably going to FTrim at 2% very soon.
Never half-ass anything, always use your full ass
2010 KTM 690 Enduro
2009 KTM 400XCW Plated
Bigbugberg is offline   Reply With Quote
Old 01-09-2013, 08:36 PM   #6847
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
I just picked up a 2009 690R with 8800 miles.
It seems she was pretty much a street bike.
She already has a Safari tank and a custom Corbin seat. (Never knew they did custom) Very comfy.
I've already ordered in a FMF Q4.
Next on a long list of things to be resolved is the headlight.
What have you guys been doing about that POS BA20 bulb? I saw a note about a possible mod to put a H4 in there. Anybody know the details?
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 01-09-2013, 09:16 PM   #6848
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 891
Hey I know that bike... I'm pretty sure that was owned by a police officer in Santa Maria and was on consignment at Santa Barbara Motorsports?
As far as the appliance lightbulb, you can change the entire headlight to the much better 2008/2012 version and get not only an H4 bulb but a much better reflector that is DOT approved to boot. I opted to change to a 7" round light but the stock 08/12 light is actually pretty good and with a bulb upgrade is totally acceptable.
KTM part numbers for light to follow...
headlight housing: 76514001000
wiring harness (plugs right in): 76511079000
mask (orange): 7650800100004
brakeline guide: 76513025000
I believe the misc hardware from your existing light can be reused for adjustment screws, mounting, etc. This setup should come out to ~$150
At a similar pricepoint and light output you can get a Trailtech X2 that allows the hi/low beams to be on at the same time and the housing lends itself well to HID conversions: http://trailtech.net/ktm-x2-ds-halogen-kits.html this light is also a straight plug in to your 690
The Letter J screwed with this post 01-09-2013 at 09:33 PM
The Letter J is online now   Reply With Quote
Old 01-09-2013, 09:21 PM   #6849
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Yup that the bike. That PO took really nice care of the bike. Lots of stuff done. Much more to do. Along with the headlight is to raise the suspension back up and put heavy springs on for my Fat Arse.
Hmm replace the headlight assembly. Maybe so as the final product. I would like to use the existing for now. Spend my money on the other dirt stuff needed.
Tom
My2Wheels
690 WIKI
Old 01-09-2013, 09:49 PM   #6850
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Thank you.
I don't think much of the TT X2. I had one that I was going to put on my 525. Not nearly as much light as the standard Baja Designs rectangle headlight. I'm not sure I could go so far as to put one of those on my new Ginger. Been considering the big 7 or 8 inch units as well. Is yours hi/lo?
Tom
My2Wheels
690 WIKI
Old 01-09-2013, 10:08 PM   #6851
Baja Dad
Baja Dad's Avatar
Oddometer: 1,959
Thank you.
I have an H-4 690 light and a HID 690 light That will fit in that mask
I also have a Leo Vance rear pipe section and a Scotts Stablizer tower and a Tourtech bash plate and Disc shark fin.
I will sell you send me a PM
Welcome to the 690 club
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 01-10-2013, 09:50 AM   #6852
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Anybody got some heavy FF springs sitting around? 90 or 100 rear and maybe 60 for the front.
Yes, I plan on getting the new spring collar before installing that rear.
Tom
My2Wheels
690 WIKI
Old 01-10-2013, 10:03 AM   #6853
Baja Dad
Baja Dad's Avatar
Oddometer: 1,959
I have a complete set of Trail tricks reworked forks I may trade+$
Old 01-10-2013, 10:07 AM   #6854
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Mark, You are killing me.
Send me a PM with your complete list of available 690 stuff. Should only take a page or two.
Did you get my txt?
Tom
My2Wheels
690 WIKI
Old 01-11-2013, 09:20 AM   #6855
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Could somebody with a 2009 or 2010 R please give me a length in mm on the sidestand? The PO apparently cut or replaced this one when he lowered the bike. I'll be raising it back up to full height. 2008 & 2012 shows 295 mm. I expect 09 & 10 would be longer some. The microfiche don't show for the 09.
I might do an adjustable style like I did on the 950.
Tom
My2Wheels
690 WIKI
Times are GMT -7.   It's 10:33 PM.
