Old 01-16-2013, 09:48 PM   #6856
Canadian_Bacon
Oddometer: 201
Ktm 690 Throttle Switch on Handle Bars
I've read that you can purchase/install an actual switch on the handlebars of a ktm 690 to change the throttle maps on the fly. Does this switch exist? If so where can I get one?
Canadian_Bacon is offline   Reply With Quote
Old 01-16-2013, 10:17 PM   #6857
Hoots
Hoots's Avatar
Oddometer: 1,514
I had a nice Trail Tech switch on the Berg, but I don't think they make one for the 690 ...
Hoots is offline   Reply With Quote
Old 01-16-2013, 10:57 PM   #6858
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 973
Leo Vince makes one, but its not on the fly. You still have to stop
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 01-16-2013, 10:58 PM   #6859
Bill the Bong
Supern00ba
Oddometer: 973
Originally Posted by The Letter J View Post
I have no firsthand experience with the RR cam but I decided against it for my own bike after reading that, while providing a noticeable boost in power up top, there was an equally noticeable loss in power down low. I haven't found any other commercially available cam's for the 690 yet but I haven't looked terribly hard either.
Maybe that is the answer for folks running slower throttle cams to tame down the initial delivery...
Old 01-16-2013, 11:36 PM   #6860
Canadian_Bacon
Oddometer: 201
Do you have a link or something? I checked their site and couldn't find it.
Old 01-16-2013, 11:49 PM   #6861
Bill the Bong
Supern00ba
Oddometer: 973
Leo Vince
http://www.advrider.com/forums/showthread.php?t=487552
Old 01-17-2013, 01:05 AM   #6862
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,099
So I did the first valve check on my 2012 enduro with 624 miles on the clock. Fired right up, but there seemed to be more valve noise than usual, bike ran fine, warmed up. Changed the oil and the noise didn't subside. Took the skid plate off and it was still noisy.
My 950 has somewhat noisy valves, and my v-strom was noisy too. The 690 is the same noise but louder to the point where I'm a little worried (though it's a new bike so I'm kind of nit-picky ). Tore it down to the valves again and everything was at .13mm except one exhaust was .14mm . The bike had the same level of noisy valves after about 550 miles but they were all tight when I checked them and reshimmed them to .13mm but the noise persists.
I know these bikes are noisy but I looked more closely and saw some scoring marks on the rocker arm bearings, perhaps these marks are normal, and the noise is normal?
Here's a picture:
Larger Picture
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 01-17-2013, 01:17 AM   #6863
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 782
Im not sure if they fixed the rocker bearings, but mine let go on my 09 and ate the top end. If in doubt, swap em out!
tattewell is offline   Reply With Quote
Old 01-17-2013, 02:02 AM   #6864
LukasM
Oddometer: 5,425
Here you go, their stuff is normally very good quality as they only work with top manufacturers like CP etc.
http://www.gw-racing-parts.de/index2...is=2010&lan=en
Tuningkits
KTM 690 (2006-2010)
Product-Nr. Product Description Picture Retail €
(without tax)
KTM690/06-09/ST1Tuning-Kit 1Tuningkit KTM690 stage 1. New Camshaft Stage 2. CP forged pistonkit of the extra class 102 mm. Compression 11,8 : 1. Delivery including the suitable piston rings, wrist pins and wire locks. Inclusive cylinder honing with diamond honing stones. Cylinder honing is necessary concerning the correct running clearance and the surface roughness adequately to the piston ring.536,43
KTM690/06-09/ST2Tuning-Kit 2Tuningkit KTM690 stage 2. New Camshaft Stage 2. CP forged pistonkit of the extra class 102 mm. Compression 11,8 : 1. Delivery including the suitable piston rings, wrist pins and wire locks. Inclusive cylinder honing with diamond honing stones. Cylinder honing is necessary concerning the correct running clearance and the surface roughness adequately to the piston ring. Cylinder head porting inclusive radius valve seat cutting. Inclusive shot peen of the combustion chamber and channels.665,71
KTM690/06-09/ST3Tuning-Kit 3Tuningkit KTM690 stage 3. New Camshaft Stage 2. CP forged pistonkit of the extra class 102 mm. Compression 11,8 : 1. Delivery including the suitable piston rings, wrist pins and wire locks. Inclusive cylinder honing with diamond honing stones. Cylinder honing is necessary concerning the correct running clearance and the surface roughness adequately to the piston ring. Cylinder head porting inclusive radius valve seat cutting. Inclusive shot peen of the combustion chamber and channels. Including crankshaft balancing.789,86
KTM690/06-09/ST4Tuning-Kit 4KTM 690 bigbore - tuningkit. New camshaft stage 2. Cylinder boring for 104 mm and new LFC plating. CP forged pistonkit of the extra class 104,00 mm, + 2 mm oversize, compression 12,5 : 1. Delivery including the suitable piston rings, wrist pins and wire locks.Cylinder head porting inclusive radius valve seat cutting. Inclusive shot peen of the combustion chamber and channels. Including crankshaft balancing.1090,47
NKTM690/06-10/ST2 CamshaftNew camshaft stage 2! More top end power ! Very good for bigbore engines.292,86
PCPKTM690/06-09/102mPistonCP pistonkit of the extra class 102,03 mm. Compression 11,8:1. The cylinder must be honed with diamond honing stones. Cylinder honing is necessary due to the fact that the piston especially for the overhaul has a slightly oversize of 0,03 mm.220,00
PCPKTM690/06-09/104mPistonCP - Forged Pistonkit of the extra class 104,00 mm, + 2 mm oversize, compression: 12,5 : 1,. Delivery including the suitable piston - rings, wrist pins and wire locks. The cylinder must be bored for oversize and new coated. 220,00
KTM690-HSC3Piston coatingHSC3 piston coating
40,86
Old 01-17-2013, 11:31 AM   #6865
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
Originally Posted by TheMuffinMan View Post
Anyone have the part number of the 2012 short oil filter? The one I got in the mail is different from the one I pulled out of the bike and want to make sure I have the correct one. I'll call the dealer$hip in the morning unless someone here knows.
Did you not gt a parts manual with your new '12 bike?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 01-17-2013, 11:39 AM   #6866
ABuck99
0.0
ABuck99's Avatar
Oddometer: 609
Muffinman-
A good quality and inexpensive option to OEM is Hiflo Oil Filter HF 155 & 157- $5.00ea HF157 is the small filter
I can ship you some if you like
http://www.hiflofiltro.com/catalogue#search-results
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 01-17-2013, 11:57 AM   #6867
TheMuffinMan
Oddometer: 6,099
Originally Posted by ABuck99 View Post
Muffinman-
They don't make a short oil filter for the 2012 yet (the design changed).
I didn't get a parts manual; I bought the bike used, from a guy (even though it only had 220 miles or so on it). All it came with was an owners manual.
Old 01-17-2013, 12:25 PM   #6868
ABuck99
0.0
ABuck99's Avatar
Oddometer: 609
sorry for that- Hiflo has it wrong
here you go
KTM PN: 75038046100 OIL FILTER SHORT
http://partsfinder.onlinemicrofiche....ICATING-SYSTEM
Old 01-17-2013, 03:31 PM   #6869
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,604
Muffinman-
It should also be noted that HiFlo makes the filters for KTM and KTM then puts their stamp on them and doubles the price
Seth S
Seth S is offline   Reply With Quote
Old 01-17-2013, 03:35 PM   #6870
Kirkster
Parts Murderer
Oddometer: 296
Originally Posted by Kirkster View Post
Anyone know if we can swap out the 2012 instrument cluster for an older digital one?
I already have white dust in my 2012 one as well as LCD issues with parts of it blanking out...
Cheers..
K
Anyone??? Anyone???
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Times are GMT -7.   It's 01:10 PM.
