Old 01-17-2013, 03:58 PM   #6871
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
No the plugs are different but the wiring maybe the same you might be able to do s plug swap
It will be a fiddly pia job .
Mudguts is offline   Reply With Quote
Old 01-17-2013, 04:00 PM   #6872
Mudguts
Mudguts's Avatar
Oddometer: 2,128
Oh you will have no taco if you do the swap
Old 01-17-2013, 07:48 PM   #6873
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 451
Originally Posted by Kirkster View Post
Anyone??? Anyone???
I've seen folks on supermotojunkie.com take their speedos apart, clean and reseal them.
Is this helpful?
http://www.supermotojunkie.com/showt...edo-fog-repair
thorinoakenshield is offline   Reply With Quote
Old 01-17-2013, 09:05 PM   #6874
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Is this helpful?
I just cleaned mine out a few weeks ago. Turned out one of the pins for the LCD was broken so I had to solder. I can also recommend using some di-electric grease on the pins for the LCD. This will help the crappy connection.
I can post pics if you want.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-18-2013, 04:35 AM   #6875
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 605
I need to do a valve check, I understand how to do it but I'm not sure about the TDC part, does anyone have info/pictures on how to do that?
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
| Balkan ADV RR | Bacon trip log map | KTM 690 Wiki |
LethPhaos is offline   Reply With Quote
Old 01-18-2013, 07:39 AM   #6876
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,824
There's a timing mark on the camshaft, you'll see it when you are looking down on it right by the timing chain gear. Also, the holes will line up that allow you to remove the rocker arm shafts when you're at TDC.
Old 01-18-2013, 07:44 AM   #6877
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
There are 3 holes in the cam shaft gear. You turn the crank shaft CCW until the center hole is about at the 8mm bolt that holds the cam shaft in. Shine a light through this hole, there is a small line on the cam shaft and a small line on the camshaft retainer. When they line up, you are at TDC. Sorry I don't have a pic.
Old 01-18-2013, 07:48 AM   #6878
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,824
Here's a pic of the timing mark:
And the hole alignment
Old 01-18-2013, 07:49 AM   #6879
KTM-RIDER4LIFE
Born to ride
KTM-RIDER4LIFE's Avatar
Oddometer: 4
Originally Posted by Night Falcon View Post
.....I got the first 690 on a beach next to an upside down car wreck on beach photo covered
Nice picture of the upside down wreak on the beach!
Keep the rubber side down
KTM-RIDER4LIFE is offline   Reply With Quote
Old 01-18-2013, 08:29 AM   #6880
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,759
There is TDCF and TDCE... you will want to line up the crank mark as well...as you want TDCF---firing...all valves closed.
Seth S
Seth S is online now   Reply With Quote
Old 01-18-2013, 08:46 AM   #6881
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,824
I just wiggle the rocker arms, if they have some slop then I know I'm at TDCF.
Old 01-18-2013, 08:52 AM   #6882
Seth S
Seth S's Avatar
Oddometer: 4,759
I don't bother even lining up marks but I figured the new guy would be safer doing it the factory way
Seth S
Old 01-18-2013, 09:00 AM   #6883
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
The cam shaft rotates 1 time for every 2 times the crank shaft rotates. So if you line up the cam shaft mark, it will always be TDC firing.
Old 01-18-2013, 09:14 AM   #6884
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,262
I don't have pictures yet but, here's the text.
http://ktm690.info/index.php/Valve_Check
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 01-18-2013, 09:53 AM   #6885
Seth S
Seth S's Avatar
Oddometer: 4,759
good point. Was thinking about the valve adjustment procedure of the 950's where you have to pull the cams out to get at the buckets. Forgot that the cam stay in place in the 690 motor...makes life a lot easier.
Seth S
Times are GMT -7.   It's 02:45 PM.
