Old 01-17-2013, 12:39 PM   #6901
ABuck99
0.0
ABuck99's Avatar
Oddometer: 579
Muffinman-
A good quality and inexpensive option to OEM is Hiflo Oil Filter HF 155 & 157- $5.00ea HF157 is the small filter
I can ship you some if you like
http://www.hiflofiltro.com/catalogue#search-results
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 01-17-2013, 12:57 PM   #6902
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,771
Originally Posted by ABuck99 View Post
Muffinman-
They don't make a short oil filter for the 2012 yet (the design changed).
I didn't get a parts manual; I bought the bike used, from a guy (even though it only had 220 miles or so on it). All it came with was an owners manual.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 01-17-2013, 01:25 PM   #6903
ABuck99
0.0
ABuck99's Avatar
Oddometer: 579
sorry for that- Hiflo has it wrong
here you go
KTM PN: 75038046100 OIL FILTER SHORT
http://partsfinder.onlinemicrofiche....ICATING-SYSTEM
Old 01-17-2013, 04:31 PM   #6904
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
Muffinman-
It should also be noted that HiFlo makes the filters for KTM and KTM then puts their stamp on them and doubles the price
Seth S
Seth S is offline   Reply With Quote
Old 01-17-2013, 04:35 PM   #6905
Kirkster
Parts Murderer
Oddometer: 296
Originally Posted by Kirkster View Post
Anyone know if we can swap out the 2012 instrument cluster for an older digital one?
I already have white dust in my 2012 one as well as LCD issues with parts of it blanking out...
Cheers..
K
Anyone??? Anyone???
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 01-17-2013, 04:58 PM   #6906
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
No the plugs are different but the wiring maybe the same you might be able to do s plug swap
It will be a fiddly pia job .
Mudguts is offline   Reply With Quote
Old 01-17-2013, 05:00 PM   #6907
Mudguts
Mudguts's Avatar
Oddometer: 2,105
Oh you will have no taco if you do the swap
Old 01-17-2013, 08:48 PM   #6908
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 446
Anyone??? Anyone???
I've seen folks on supermotojunkie.com take their speedos apart, clean and reseal them.
Is this helpful?
http://www.supermotojunkie.com/showt...edo-fog-repair
thorinoakenshield is offline   Reply With Quote
Old 01-17-2013, 10:05 PM   #6909
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,661
Is this helpful?
I just cleaned mine out a few weeks ago. Turned out one of the pins for the LCD was broken so I had to solder. I can also recommend using some di-electric grease on the pins for the LCD. This will help the crappy connection.
I can post pics if you want.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-18-2013, 05:35 AM   #6910
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 576
I need to do a valve check, I understand how to do it but I'm not sure about the TDC part, does anyone have info/pictures on how to do that?
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos is offline   Reply With Quote
Old 01-18-2013, 08:39 AM   #6911
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,355
There's a timing mark on the camshaft, you'll see it when you are looking down on it right by the timing chain gear. Also, the holes will line up that allow you to remove the rocker arm shafts when you're at TDC.
Old 01-18-2013, 08:44 AM   #6912
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,661
There are 3 holes in the cam shaft gear. You turn the crank shaft CCW until the center hole is about at the 8mm bolt that holds the cam shaft in. Shine a light through this hole, there is a small line on the cam shaft and a small line on the camshaft retainer. When they line up, you are at TDC. Sorry I don't have a pic.
Old 01-18-2013, 08:48 AM   #6913
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,355
Here's a pic of the timing mark:
And the hole alignment
Old 01-18-2013, 08:49 AM   #6914
KTM-RIDER4LIFE
Born to ride
KTM-RIDER4LIFE's Avatar
Oddometer: 4
Originally Posted by Night Falcon View Post
.....I got the first 690 on a beach next to an upside down car wreck on beach photo covered
Nice picture of the upside down wreak on the beach!
Keep the rubber side down
KTM-RIDER4LIFE is offline   Reply With Quote
Old 01-18-2013, 09:29 AM   #6915
Seth S
Seth S's Avatar
Oddometer: 4,454
There is TDCF and TDCE... you will want to line up the crank mark as well...as you want TDCF---firing...all valves closed.
Seth S
Times are GMT -7.   It's 03:43 AM.
