Old 01-18-2013, 09:46 AM   #6916
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Originally Posted by Seth S View Post
There is TDCF and TDCE... you will want to line up the crank mark as well...as you want TDCF---firing...all valves closed.
I just wiggle the rocker arms, if they have some slop then I know I'm at TDCF.
Old 01-18-2013, 09:52 AM   #6917
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,442
I don't bother even lining up marks but I figured the new guy would be safer doing it the factory way
Seth S
Seth S is offline   Reply With Quote
Old 01-18-2013, 10:00 AM   #6918
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,660
The cam shaft rotates 1 time for every 2 times the crank shaft rotates. So if you line up the cam shaft mark, it will always be TDC firing.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-18-2013, 10:14 AM   #6919
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,733
Originally Posted by LethPhaos View Post
I need to do a valve check, I understand how to do it but I'm not sure about the TDC part, does anyone have info/pictures on how to do that?
I don't have pictures yet but, here's the text.
http://ktm690.info/index.php/Valve_Check
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 01-18-2013, 10:53 AM   #6920
Seth S
Seth S's Avatar
Oddometer: 4,442
good point. Was thinking about the valve adjustment procedure of the 950's where you have to pull the cams out to get at the buckets. Forgot that the cam stay in place in the 690 motor...makes life a lot easier.
Seth S
Old 01-18-2013, 12:47 PM   #6921
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,106
Valve Job
Damn I need a valve JOB. Dont think I can convince the wif of the living room being the right spot. Dont think I can squeeze it into an afternoon while she is at work, so I'm f"d. Dont want to pay the steelers and it would be my first v'job...yeah I'm virgin. And my math aint so gooood. Measuring the little f'ers (assuming I'm out of spec) is going to test my logic skilz. Suppose it is easier the second time for you pros.
So, gonna have to delay the inevitable for a sunny day in the condo parking lot. Seen the links, time for a deep breath of spring air, in the spring, and go for it. FYYFF.
KTM 1190 Adventure
OhBoy is offline   Reply With Quote
Old 01-18-2013, 12:51 PM   #6922
yuu
yuu's Avatar
Oddometer: 122
Technology to the rescue
I didn't make this gem, but it's an excel spread sheet that you punch in the numbers to and it spits out closest shim fit KTM part number
http://dl.dropbox.com/u/19350741/690...Calculator.xls
FWIW - you can get harley Shims for the V-rods in smaller increments than the ones from KTM if you want a more accurate fit. KTM ones go at 0.005 mm and the HD ones are 0.0025 per step
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-18-2013, 01:39 PM   #6923
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
It surely does, 15 minute valve checks, another 5 if you have to re-shim.
Old 01-18-2013, 01:44 PM   #6924
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Valve JOB or valve clearance check? Two very different things.
Old 01-18-2013, 11:40 PM   #6925
jorich
jorich's Avatar
Oddometer: 75
Hey has anybody seen or (hopefully have a link) for an extension harness for the 2010 enduro R instrument? I swear I have seen one for sale somewhere, but I have been looking all night without success
A ship is safe in the harbor, but that's not why ships are built...
'10 KTM 690R:)
jorich is offline   Reply With Quote
Old 01-19-2013, 04:43 AM   #6926
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,106
Thank you
KTM 1190 Adventure
Old 01-21-2013, 02:23 AM   #6927
ktmmitch
Oddometer: 576
Now we have finished the EVO2 moulds we are back onto some development jobs we want to get into production this spring.
One of them is our 2 piece billet clutch cover to suit the KTM 690 Enduro and Rally.
Here are a couple of shots of the finished CNC machined model,which we will fit to an engine,before making the final billet aluminium parts.
ktmmitch is offline   Reply With Quote
Old 01-21-2013, 04:30 AM   #6928
Evil Invader
Evil Invader's Avatar
Oddometer: 686
Dammit ktmmitch, I want your job!
Nice
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 01-21-2013, 10:34 AM   #6929
ktmmitch
Oddometer: 576
Nice
I'd like to train someone up,just like me.............
But then I think,no,they would be a bitch to live with!!!!!
Old 01-21-2013, 01:10 PM   #6930
Baja Dad
Baja Dad's Avatar
Oddometer: 1,949
My Evo 2 parts are starting to land at my front door
I will post pics as thing get opened up !!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Times are GMT -7.   It's 02:10 AM.
