Old 01-30-2013, 12:23 PM   #6991
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,057
Thanks for the response. It was an old thread. I thought he indicated he was going to go much further. He never followed up with his long term results that I noticed.
My new to me 690 has 8800 miles on it. I think the rings are broken in by now. LOL
With all my reading I haven't found a specific reason for the heavy weight oil. My 950 specs 50w. It seems to be very happy with the 5w40. I'm thinking I will give the T6 a try for a cycle or 2 and see if there is any issues or oil consumption. Go from there.
I've still got packages showing up at the house. Parker 425 this weekend. Next week I get to start tinkering.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 01-30-2013, 01:15 PM   #6992
Baja Dad
Baja Dad's Avatar
Oddometer: 1,981
I have used Rotella in all my KTMs from my 150 thru my 640 and now in my 690
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 01-30-2013, 01:21 PM   #6993
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,057
Tom
My2Wheels
690 WIKI
Old 01-30-2013, 05:33 PM   #6994
ten.98
...leave a trail
Oddometer: 51
Question 2012 690 w/Evo2 wont start.
Hey Everybody, I bought a brand new 2012 690 Enduro R a few weeks back and just got a bunch of goodies in the mail for it today. Did the full Evo2 kit w/Akra pipe minus the cam. Did the SAS delete as well as the Canisterectomy as documented along in this thread.
Got it most of the way back together, but figured I'd fire it up and make sure everything was good to go before I put the fairing and whatnot on.
Bike turns over strong but wont fire. I tried starting it before I applied the map with the stock map, then I loaded the Evo map and tried again and nothing. I don't have any codes showing up in TuneECU and all the sensors are showing up fine. Fuel pump even kicks on after about 5-10 seconds of cranking.
Haven't pulled the plug yet to see if I'm getting spark, that will be on the list of things to check tomorrow.
Has anyone run into something like this before or heard of a similar situation?
Jeremy
ten.98 is offline   Reply With Quote
Old 01-30-2013, 05:55 PM   #6995
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,537
Jeremy
Did you load the efi map and the throttle map?
Seth S
Seth S is offline   Reply With Quote
Old 01-30-2013, 06:47 PM   #6996
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,605
Take it back appart and see which mission-critical doohicky you left unplugged.
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 01-30-2013, 07:56 PM   #6997
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
The 690 clutch doesn't seem to get along with the Rotella in my experience. The shifting action is stiff and it doesn't seem to slide into gear easily. Maybe your experience would be different? I thought you are sponsored by an oil company?
Just say'IN
crankshaft is offline   Reply With Quote
Old 01-30-2013, 08:55 PM   #6998
Baja Dad
Baja Dad's Avatar
Oddometer: 1,981
Seems to work perfectly fine all my other bikes
I am going to try it in the.690
Did have an oil sponsorships
But cutbacks hurt everybody.
Save the good stuff for the Race bikes
And use Rotella all the other times
Old 01-30-2013, 09:50 PM   #6999
Seth S
Seth S's Avatar
Oddometer: 4,537
At $10000 the 690 is a ghetto bike..i would run whatever oil is on sale at the local jiffy mart
Seth S
Old 01-30-2013, 10:43 PM   #7000
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Jeremy
Check your spark. No need to pull the plug.. just put a spare spark plug on the plug wire. The evo 1 you have to move the coil.. do you have to move the coil for the Evo 2? Maybe your low voltage coil wire came lose or something. This has happened to me and others.
Good luck.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-31-2013, 04:35 AM   #7001
Swap
Swap's Avatar
Oddometer: 29
Originally Posted by Dotbond View Post
Has anyone pulled the front forks apart on the 2012 690?
No-one in NZ has really had a lot of experience with the 690 suspension in general. 50mm race sag and i weigh around 78kg in my birthday suit. Front suspension is way too hard for general off-road riding, they bounce off small stones/bumps instead of soaking up the bumps.
I have been recommended to take out the base valve stack and replace the 0.15 shims with 0.10 shims.
Any ideas/comments welcome.
+++++++++10000
and for the rear shock too who gives sometimes kick ass......
Swap is offline   Reply With Quote
Old 01-31-2013, 05:21 AM   #7002
ten.98
...leave a trail
Oddometer: 51
I tried starting before and after loading both maps. Since I haven't been able to do the 15 minute idle adaption I'm sure the FI map hasn't been committed to the ECU yet. Either way, having the proper map shouldn't keep me from being able to start I wouldn't think, it was just effect how well it ran once it was going.
That's the plan for today. After doing all of the work required to fit the Evo2 I'm kind of second guessing whether or not I want to stick with it. It seems the battery relocation kit puts the positive terminal perilously close to the frame ( like within 3mm) and a good bump would possibly end badly for my electrical system. I'm guessing if I put in a small 8-cell battery it wouldn't be an issue.
Also, with the airbox deleted it gives much easier access to the valves (which is what I was going for) but it also makes it a lot easier for water to get into the intake.
Good luck.
I did have to move the coil to get the airbox out. I'll follow the wires around to see if I may have accidentally pulled something loose. Thanks for the tip.
Jeremy
Old 01-31-2013, 06:35 AM   #7003
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,570
Snerk
Old 01-31-2013, 08:21 AM   #7004
wsmc831
wsmc831's Avatar
Oddometer: 744
Originally Posted by Swap View Post
+++++++++10000
Are you saying you've replaced the shims and it's an improvement?
I've seen the information on that reduction of thickness but haven't seen much feedback from people that have actually done it.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 01-31-2013, 08:39 AM   #7005
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Ok, I misunderstood. You installed the KTM evo2 Tuning kit...
I was thinking you were talking about the Rally Raid Evo2 tank kit.
I would check the spark as suggested before. Did you put the cam in also? If so.. Maybe the camshaft timing is off?
Times are GMT -7.   It's 05:54 AM.
