Old 02-01-2013, 02:34 AM   #7036
ktmmitch
Oddometer: 578
Originally Posted by Dotbond View Post
Are you able to give me some guidance on how to soften up the compression damping on the front forks? There is a suspension guy in NZ but he hasn't really had much to do with 690's and in particular the 2012 model. I told him my problem of the front bouncing off bumps and rocks while trailriding ( I weigh 78kg in my birthday suit) and he said to unscrew the base valve from the bottom of the forks and send them up to him and he would replace the 0.15 shims with 0.10 shims. Does this sound right?
I'll pay you for your advise and buy the parts from you if necessary ktmmitch!!
Cheers
Trev
Best thing to do first is to fit 4,8Nm springs,they are too hard stock,Then 5W oil with 115mm air gap.
ktmmitch is offline   Reply With Quote
Old 02-01-2013, 02:54 AM   #7037
Swap
Swap's Avatar
Oddometer: 29
Originally Posted by wsmc831 View Post
Are you saying you've replaced the shims and it's an improvement?
I've seen the information on that reduction of thickness but haven't seen much feedback from people that have actually done it.
i'm not realy happy whith ride comfort for the long travel track
i did'nt try to modify setting of fork and rear schock after 12 000 km yet
it's realy urgent for me now (my back is not happy)
Swap is offline   Reply With Quote
Old 02-01-2013, 03:12 AM   #7038
Chris 690R
Oddometer: 66
Anyone know what the diff is between the 12 690 and the new 2013 690?
Chris
Chris 690R is offline   Reply With Quote
Old 02-01-2013, 06:33 AM   #7039
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,887
Chris
365 Days?
I haven't heard of any changes what so ever to the '13 bikes.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 02-01-2013, 07:08 AM   #7040
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
Chris
Unlike 2012 there will be no adventure model offered in 2013
Seth S
Seth S is offline   Reply With Quote
Old 02-01-2013, 07:10 AM   #7041
Seth S
Seth S's Avatar
Oddometer: 4,454
Originally Posted by shipwrek12001 View Post
thanks all for your input about water pumps
Seth, when you say yours failed, what failed on the water pump, and why do you think it failed.
The inner water pump seal failed. The coolant filled the oil chamber and the bike overheated. It was during a race...as a result the headgasket also failed. However I did not realize that the headgasket had failed until I replaced the water pump seals. When I fixed the pump seals I could see clear signs of coolant leaking past the inner seal (oil/water barrier) along the shaft.
it took 4 oil changes in rapid succession to clean all the contaminated oil out of the engine. The first batch of fresh oil turned instantly to a milkshake....so I drained it and filled with used oil...ran for a couple of minutes and then drained...refilled with used oil and repeated until the oil drained out clean.
Seth S
Old 02-01-2013, 07:14 AM   #7042
Seth S
Seth S's Avatar
Oddometer: 4,454
Cheers
Trev
Easiest way to fix the 690 suspension is to pull it off the bike and throw in in the dumpster and then invest in some good stuff. I have a reworked set on my bike and though it is vastly better than stock it still doesn't feel as good as some of the older 525's and a 640 adventure I have ridden with well setup suspension.
Seth S
Old 02-01-2013, 07:57 AM   #7043
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,922
Originally Posted by ktmmitch View Post
New Billet Clutch & Brake levers to suit KTM 690 Enduro,these have been specifically designed for these models by Rally-Raid Products,as the EXC clutch lever,whilst similar looking,will not actuate the clutch switch,so not giving full power.
Huh ?
The factory clutch lever has a cast in boss which depresses the clutch switch when the lever is pulled in to allow the m/c to be started in gear [provided the side stand is up].
Aftermarket lever replacements, such as Motion pro, which don't have that boss will result in nothing more than the clutch switch not being depressed when the lever is pulled in, therefore not allowing the m/c to be started when in gear.
Bruno T . is offline   Reply With Quote
Old 02-01-2013, 08:37 AM   #7044
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
Actually, the stock reworked suspension works really well when you put 17" wheels and sticky tires on them.
Old 02-01-2013, 09:27 AM   #7045
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,922
I have been recommended to take out the base valve stack and replace the 0.15 shims with 0.10 shims.
That's what i ended up with on my 10, but only the larger diam ones, not all of them. Removed the small backer too. It's certainly not the same as springing for closed chambers, but it doesn't deflect like it used to.
I'd pull the stack and measure it up as a 12 might be different.
Old 02-01-2013, 10:05 AM   #7046
Seth S
Seth S's Avatar
Oddometer: 4,454
Originally Posted by Bruno T . View Post
Huh ?
this is true. And it is a major pain in the ass having to start the bike in neutral every time. Disconnecting the clutch switch and shorting it out will result in poor running and less power though
Seth S
Old 02-01-2013, 10:16 AM   #7047
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,922
Indeed.
Oh, so what he was saying is that if you were to install a non OE lever, and short the switch to get around not having to be in neutral to start the m/c, that would result in less power.
Makes sense. Thanks for clarifying, Seth.
Old 02-01-2013, 10:31 AM   #7048
Baja Dad
Baja Dad's Avatar
Oddometer: 1,959
WHY ???
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-01-2013, 10:32 AM   #7049
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
Originally Posted by Baja Dad View Post
WHY ???
Because neutral is a bitch to find on the bike.
Old 02-01-2013, 11:06 AM   #7050
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,922
WHY ???
I assume you mean why the power loss . .
Good question.
atom7 confirmed it by rigging a switch that he could toggle on and off - here.
I wonder if the clutch switch simply activates the neutral throttle map. If that's the case, it'd be easy to modify that map [mine already is].
I need to rig up a similar switch and do some testing.
Times are GMT -7.   It's 03:08 AM.
