Old 02-01-2013, 10:06 AM   #7051
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,434
Originally Posted by Baja Dad View Post
WHY ???
I assume you mean why the power loss . .
Good question.
atom7 confirmed it by rigging a switch that he could toggle on and off - here.
I wonder if the clutch switch simply activates the neutral throttle map. If that's the case, it'd be easy to modify that map [mine already is].
I need to rig up a similar switch and do some testing.
Bruno T . is offline   Reply With Quote
Old 02-01-2013, 10:11 AM   #7052
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,329
Good question.
Yes. Please do.
I found that switch a PITA on my 950A and simply jumpered it. I surely would want to do the same on this bike.
Please tell us where in the map to turn it off as well.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC
To Think is to Create!http://my2wheels.com/forum/cmps_index.php
dad2bike is offline   Reply With Quote
Old 02-01-2013, 10:23 AM   #7053
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,202
Originally Posted by Albie View Post
Because neutral is a bitch to find on the bike.
Its also a pain if you are racing...or riding in traffic or someplace inconvenient to have to drop down to neutral and start the bike.
In australia we had problems with an aftermarket brake lever as it did not hit the switch properly and thus required neutral to start. So we cut the switch wires and shorted them together. I ran the prologue of the Safari with it this way and the bike stalled left and right, was way down on power, and generally ran like crap. After that we reconnected the switch and I ran my "modified" stock clutch lever and it was back to normal. The clutch switch does something to the efi on the stock system...what exactly I do not know but it does run like poo
Seth S
Husaberg tank for sale: HERE
Seth S is offline   Reply With Quote
Old 02-01-2013, 11:07 AM   #7054
DirtJack
DirtJack's Avatar
Oddometer: 340
This is yet another topic which was discussed/explained several times on the old mega thread which is now lost. Don't know if I can remember all the details or not, but the Kehein ECU has logic (to save fuel/emissions) which cuts off fueling if the motor is in gear and above a certain rpm and the clutch is not pulled, when the throttle is closed, knowing the motor will restart when the throttle is opened. If these conditions are not met, then the idle map must be used to keep the motor running. If the ECU thinks the clutch is always pulled, then the idle map gets used in situations it should not be.
I don't think anyone had solved this problem while disabling the clutch switch.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 02-01-2013, 12:24 PM   #7055
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 648
Send a message via Skype™ to Dotbond
Originally Posted by Swap View Post
i'm not realy happy whith ride comfort for the long travel track
i did'nt try to modify setting of fork and rear schock after 12 000 km yet
it's realy urgent for me now (my back is not happy)
Well, at least you are a lot closer to the UK and Rally Raid Products than I am ( New Zealand ) to get your suspension to them to sort out for you.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 02-01-2013, 01:06 PM   #7056
Chris 690R
Oddometer: 66
Unlike 2012 there will be no adventure model offered in 2013
Man why don't they produce a true adventure version of the 690?????????
Because it will effect the sales of the 990 of course!!!!!!
I need a proper screen and dash for my 690, but don't want to spend $3k to do it!
Chris
Chris 690R is offline   Reply With Quote
Old 02-01-2013, 02:29 PM   #7057
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
After reading the drama about the clutch switch, I'm really glad I ditched the KTM nanny boxes
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-01-2013, 02:41 PM   #7058
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 325
I snapped a clutch lever and replaced it with a motion pro version and it has the boss on it to engage the switch. (Dealer, though, sold me the wrong lever on the 1st try. In fact those f***ers sold me both the wrong brake lever AND the wrong clutch lever. It was mail order after that experience )
FriedDuck is offline   Reply With Quote
Old 02-01-2013, 02:51 PM   #7059
Seth S
Seth S's Avatar
Oddometer: 3,202
An added bonus for sure
Seth S
Old 02-01-2013, 04:34 PM   #7060
DirtJack
DirtJack's Avatar
Oddometer: 340
Damn computers, can't live with em, can't have this discussion without em.
2008 KTM 690 Enduro
Old 02-01-2013, 06:41 PM   #7061
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 648
Originally Posted by ktmmitch View Post
Best thing to do first is to fit 4,8Nm springs,they are too hard stock,Then 5W oil with 115mm air gap.
Do Rally Raid sell these 4,8Nm springs? 465mm long from what i have read.
I see in an older blog on the Rally Raid website that you are developing a insert for the front forks in conjunction with Ohlins, hows that coming along?
2012 KTM 690 R
Dotbond screwed with this post 02-01-2013 at 06:56 PM
Old 02-02-2013, 07:58 AM   #7062
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 398
anybody install fork bleeders on the 690?
just curious.
i have them on my 450, they are nice to have.
ktm 450xcw, ktm 690 enduro r, kawasaki versys 650
"In Europe we ride about eight-tenths. If we really have to, we might ride nine-tenths. The crazy ones ride ten-tenths—but not for very long. In America, they seem to ride eleven-tenths all the time."-- Phil Read
thorinoakenshield is offline   Reply With Quote
Old 02-02-2013, 08:17 AM   #7063
MrHix
MrHix's Avatar
Oddometer: 169
Motion Pro Micro Bleeders on mine. They sit lower and are less likely to rip off.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 02-02-2013, 08:19 AM   #7064
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
I carry a screw driver in my fanny pack, seems to work well and have never ripped the stock bleeder screws off. Not for lack off trying mind you
Just say'IN
Old 02-02-2013, 08:56 AM   #7065
Baja Dad
Baja Dad's Avatar
Oddometer: 1,222
just curious.
I have them on All my bikes.
I have NEVER broke one off
Thanks for the 2013 support:GPR Stablizers,Seat Concepts,Kriega.us,
Precision Concepts, Acerbis, AME Grips,Rally Raid UK
TLD, Klim,Oakley, Sidi-Motonation, Dunlop,ZLT
Three Brothers Racing KTM,Multitool
FOREST PLYWOOD SALES
Baja Dad is offline   Reply With Quote
Times are GMT -7.   It's 01:39 AM.
