Old 02-06-2013, 01:31 AM   #7066
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,113
Sacreligioius pictures
Been "tied up" a bit but thought I'd post some pics of my $4 mod that made my recent West coast trip so much more comfy in the 30-40 degree weather. (FWIW I had just come from 95 deg F and didn't have any good warm clothes!)
rickypanecatyl is offline   Reply With Quote
Old 02-06-2013, 02:03 AM   #7067
Chris 690R
Oddometer: 66
Originally Posted by Seth S View Post
There is also a bleeder valve on the top left as I recall...make sure that is tight.
Oh that could be it then. It is def coming form LH side radiator when I looked again right where the fan is! Surely this would not fail after 500km? The fan did a lot of work coming on when I did a bit of single stuff? Maybe that did it?
Surely if this is know issue they would have fixed it for 2012 model?
Now to,dealer and how long to diagnose and fix it????
Nice first experience with 690!!!!!
Will let you know the outcome!!!!!
Chris
Chris 690R is offline   Reply With Quote
Old 02-06-2013, 02:07 AM   #7068
Chris 690R
Oddometer: 66
Originally Posted by Mudguts View Post
Sounds like the old thremo fan rubbing through again , has your bike been dropped ? On the left side ?
Never dropped, 500km old. This must be issue as the leak is right where the fan is LH side arrrrrr!!!
Chris
Old 02-06-2013, 06:20 AM   #7069
MrHix
MrHix's Avatar
Oddometer: 384
Nice! Is that a rubbermaid screen?
On another note, can you post a couple of pics of your bike from the side & back with the bags on? Are the cases Pelican 1550s? I have been looking at making that setup.
Thanks,
MrHix
MrHix is offline   Reply With Quote
Old 02-06-2013, 06:34 AM   #7070
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
Chris
Just pull off the fan shroud and take a look, it's pretty easy to spot where the shroud rubs a circle into the rad. I have to say though, with only 500 K's I would think that this may not be your problem, that is something that takes a bit of time to happen. More then likely it's probably like my 1st replacement just a bad seam.
Old 02-06-2013, 07:56 AM   #7071
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,493
Originally Posted by ten.98 View Post
Can someone take a quick peek at their 690 for me and let me know if the o-ring is seated such that you can see a small amount a bare (silver) aluminum around the outside? I want to make sure I get this thing put back together as best I can and the repair manual has nothing on this.
Yep. You can see a small amount of metal (less than 1mm probably) - this on my 2012.
MeinMotorrad is offline   Reply With Quote
Old 02-06-2013, 09:56 AM   #7072
lightfighter
where does this go?
Oddometer: 2,287
couple quick questions
I had an 09 which I sold, and shouldnt have... but I just unloaded an 11 that I picked up off craigslist with 736 miles on it... the owner bought it in Alaska in early 2012, and obviously wasnt getting much use out of it. Has not done anything to it except ride the breakin, and take it to the dealer for service.
question is, did KTM do anything about the radiator fan spacing or do i need to get in there and shim it back? I noticed they added a tie-off to keep the fuel line off the frame bolt next to the air box... so i was hoping maybe they are paying attention?
lightfighter is offline   Reply With Quote
Old 02-06-2013, 12:19 PM   #7073
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,831
Chris
I have heard of the little vent in the top of the radiator cap pulling out or cracking at the base, check its not running down from there
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 02-06-2013, 01:29 PM   #7074
Noyah
poser
Noyah's Avatar
Oddometer: 400
The -11 are indeed updated, wise to check tho!
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 02-06-2013, 01:46 PM   #7075
Honkey Cat
Tailights Fade!
Oddometer: 1,120
pic of lexan guard
So in my continued effort to serve as but a warning to others, I shall let it be known that plugging this port:
while performing the air box delete step in the EVO2 tuning kit install will turn your clutch cover into a makeshift blowoff valve.
I now have a rather odd request...I can't remember exactly how deep the o-ring around the clutch cover is supposed to be seated. I've looked through this entire thread for close up pictures of clutch covers, and the ones I've found it's hard to tell if you can see a small amount bare aluminum on the outside of the oring or not.
Here's a pic of what I'm talking about (from another inmate who had a similar issue):
here is a pic of my 2010
Uploaded from the Photobucket iPhone App
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 02-06-2013, 02:27 PM   #7076
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
Well, clutch slave cylinder finally took a shit. Looks like tomorrow I'll be installing the Sigutech one I bought a couple years ago.
Old 02-06-2013, 03:21 PM   #7077
lightfighter
where does this go?
Oddometer: 2,287
maybe this should go in an exhuast thread somewhere, but my previous 690r had a LV on it... before I buy another one, can anyone direct me to a thread where there are pics of a stock can cut open and de-catted? I did that on a BMW collector and it worked out nicely... im inclined to try it here.
Old 02-06-2013, 04:13 PM   #7078
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Take pics - maybe I'll get inspired and install mine - thanks group buy.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 02-06-2013, 06:27 PM   #7079
ten.98
...leave a trail
Oddometer: 51
Awesome, thanks for the help guys.
ten.98 is offline   Reply With Quote
Old 02-06-2013, 07:02 PM   #7080
Motomochila
Mad Scientist
Motomochila's Avatar
Oddometer: 1,017
690 speedo to 990 speedo
I know it's been done here about 8,000 times, or I thought its been done...but can anybody direct me to the thread or tell me what speedo upgrade works best. My junker..er, stocker is not working and I want to get something I can actually see at speed. Did some searching but could not find it. ..and yep I'm a bit inept on searching here.
Does the 950-990 exchange easily? Is there an aftermarket that works better and connects to the stock wiring harness?
Bike is an 09. I had a Britannia Composite Lynx fairing mounted up and I loaded the stock speedo onto the dash panel. Seems all the tabs have broken loose and the unit has stopped working due to excessive vibration. Going back to a stock number plate with a Baja Designs LED light set-up, then I want to mount a new or working speedo to the stock mounting location.
Any words of wisdom or guidance?
Jerry
2014 KTM 690 Enduro R, 2014 EXC500,2012 BMW GTL1600, 2015 BMW F800 GS Adventure, , 2015 Ducati Hypermotard SP and 16 other motorcycle projects in various stages of completion. It's an addiction thing.
Motomochila is offline   Reply With Quote
Times are GMT -7.   It's 07:10 AM.
