Old 02-10-2013, 07:26 AM   #7126
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
Originally Posted by MrHix View Post
I did that simple bolt fix. I drilled the sleeve out CAREFULLY (it is very hard) to fit a 5/16" bolt (Lowes). I put a washer on both ends of the bolt with a nyloc nut to hold it. I don't know how strong the bolt is, but I can replace it every year to maintain a safety margin.
Cheers,
MrHix
This is what I'm doing to my lower mount. I have the RR upper coming from KTMtwins. Should be here tomorrow.
When I went to remove the existing bushing I found one side was locked in place. Had to put the other side bolt back in and use an impact to break it loose. Using a single bolt eliminates that possible issue.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 02-10-2013, 08:24 AM   #7127
fluff34567
fluff34567's Avatar
Oddometer: 1,090
yep saw that post now.. ill have a look when i get it and go from there.
fluff34567 is offline   Reply With Quote
Old 02-10-2013, 09:32 AM   #7128
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,013
I see a lot of people changing the lower tank bolt (good idea) but not too many people changing the bushings themselves. My lower bushings were sloppy as all hell by the time I hit 3k miles so I replaced them with Delrin bushings that I purchased from "partmaker" in the vendor's forum here on ADV. Absolutely no slop in the 9k miles since!
Originally Posted by partmaker View Post
The problem: Fuel-n-whatnot deteriorates the OEM lower tank mount bushings
Solution: Either Aluminum(2pc) or Delrin(2pc) $25 shipped to your door in USA or Canada. $30usd to anywhere else
Want a backup set?
$40usd gets you 4pc of either material
Aluminum
Delrin
Black Delrin installed
You can take your pick between the aluminum or black Delrin. Both (2pc alum. 2pc Delrin) can be had for $40 shipped, so you can try each. Both of the materials hold up well. Some prefer aluminum because it will last longer, others chose Delrin due to it's self lubricating properties - you chose (it's simular to the 'what kind of oil should I use').
How long will these last?
I don't know.
The in-house "Test Bike" had 3000 miles on the Delrin bushings when I took it apart to inspect. There was no wear, visibly or by measuring . So they could last 10k or 50k miles.
I've been selling these for a while via Mudguts vendor thread for his Upper Tank Bolts. This thread was started so you could find these faster.
PM for ordering info.
Have a great ride!
The Letter J is online now   Reply With Quote
Old 02-10-2013, 09:39 AM   #7129
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
I was thinking of throwing some shrink tubing on mine to shim them up.
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
My2Wheels
690 WIKI
Old 02-10-2013, 09:56 AM   #7130
MrHix
MrHix's Avatar
Oddometer: 384
UPDATE
On my simple fix, I just ordered a few grade 8, 5/16" bolts (Amazon) to replace the softer bolt I bought locally.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 02-10-2013, 10:04 AM   #7131
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
UPDATE
Cheers,
MrHix
You just saved me a trip to Lowe's.
I can get grade 8 from a place near my work.
Tom
My2Wheels
690 WIKI
Old 02-10-2013, 10:14 AM   #7132
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,122
Originally Posted by Bill the Bong View Post
450RRs. However, the angle that photo was taken at makes it all a bit deceptive, Riaan and Darryl are both average lads, neither is really small.
I could've sworn they were hobbits!
rickypanecatyl is offline   Reply With Quote
Old 02-10-2013, 10:18 AM   #7133
ktmmitch
Oddometer: 662
Originally Posted by LukasM View Post
Does anybody know how much offset the 2012 690 Enduro models are running in the triple clamps? I think it was KTMmitch that posted it was increased from the previous 22-24mm, and axle clamp offset reduced, in order to gain more steering lock.
A guy on another forum wants to put on a set of full travel closed cartridge forks so he would probably have to switch to the older triples.
The 2012 triple clamps have more offset,but to counteract the reduction in trail,they reduced the fork clamp offset,it would be better to fit the earlier triples when using EXC type forks,or the steering gets a bit "lively" on the flat,but really sharp in the tight stuff.
ktmmitch is offline   Reply With Quote
Old 02-10-2013, 12:26 PM   #7134
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,029
upper tank bolts
Originally Posted by fluff34567 View Post
i have a 690 coming to me in the next few days i read about the tank bolts and seen the offering from various vendors but the prices seen quite excessive.... for a few bolts.
Any reason why I cant just replace the originals wiith stronger bolts ?
i also believe the tank bushes are part of the problem, i heard some one makes replacements - who? or where on the tank are the bushes?
I had my upper tank bolts kinda made for cheap. Ground off the threaded part ( that breaks) and had it drilled and tapped out then put in a new stronger threaded piece. So far so good and it only cost $20 to do both sides.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 02-10-2013, 12:34 PM   #7135
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,996
There are several ways to skin this cat....I bought hardened bolts and used a Delrin shoulder to replace my stock bolts....no problems at this point....I think it was a $10 fix.
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 02-10-2013, 03:00 PM   #7136
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,029
lower
Yes I did the same thing on the lower tank bolts also, easy fix. It was the upper ones that made me think of a cheaper (KLR) way to fix them lol.
Old 02-10-2013, 03:07 PM   #7137
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Really liking the RR EVO2 tanks, they sure do snug in very well!
The only issue I had with the install was mounting my upgraded Reg/Rect, I need to make a bracket to position it lower. My RR has plugs instead of leads, so the width is wider than the stock R/R that comes on the 690. Personally, I think it's in a better place for cooling anyway but it's also probably more prone to damage. I'll post pics when I get it sorted out!
The HDB Nav tower is great, love the simplicity and the dual Squadrons should provide plenty of light
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-10-2013, 03:09 PM   #7138
DirtRideRoader
Armed and Dangerous
DirtRideRoader's Avatar
Oddometer: 410
How did you remove the broken piece out of the frame? Drill and easy out or can you just thread it out to the inside with a pair of visegrips?
Chris
IBA #23263
DirtRideRoader is offline   Reply With Quote
Old 02-10-2013, 03:25 PM   #7139
Honkey Cat
Tailights Fade!
Oddometer: 1,113
Can you put up a front shot of bike?
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 02-10-2013, 03:27 PM   #7140
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Best I can do at the moment....
Just say'IN
Times are GMT -7.   It's 10:07 AM.
