02-10-2013, 02:00 AM
#7156 |
Oddometer: 66
Are they 690's?
Cool! |
02-10-2013, 02:36 AM
#7157 |
Oddometer: 4,924
Does anybody know how much offset the 2012 690 Enduro models are running in the triple clamps? I think it was KTMmitch that posted it was increased from the previous 22-24mm, and axle clamp offset reduced, in order to gain more steering lock.
A guy on another forum wants to put on a set of full travel closed cartridge forks so he would probably have to switch to the older triples.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
02-10-2013, 05:33 AM
#7158 | |
Red Sox Nation
Oddometer: 8,902
I'm 5'9" and a 1 inch Kouba link worked for me. I had to cut the sidestand, though. The only place I needed it lower was parking lots and foot dabbing in the city. I'm still tippy toe but no problem if I'm mindful. At least it's light enough to pull it back when she starts going over on me. I'd just step off my 950 and let her go.
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
02-10-2013, 05:48 AM
#7159 |
Uh...who me?
Oddometer: 448
Where do you think the foil came from? Part of the pump or....?????
Bob Hancock '12 MultiStrada 1200 (For Sale) '09 F800GS '10 R1200GS '10 690 EnduroR |
02-10-2013, 06:27 AM
#7160 |
Cranky Old Fart
Oddometer: 2,329
I've spent all day giving my new Ginger some TLC. She be nekked and all in pieces.
![]() I just pulled all my fuel tank inners. I expect to install a CACW pump tomorrow. Preventive. I noticed one of those plastic tubes was kinked. Is there any reason to leave all those lines vs replacing with hose? I guess they would less likely deteriorate. Part of my plan was to relocate the fuel filter to the outside of the tank. Replace with metal one. Anybody got pics of where they relocated theirs? Did you just put it up where the present disconnect is?
Tom 2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC To Think is to Create!http://my2wheels.com/forum/cmps_index.php |
02-10-2013, 07:01 AM
#7161 |
Supern00ba
Oddometer: 519
450RRs. However, the angle that photo was taken at makes it all a bit deceptive, Riaan and Darryl are both average lads, neither is really small.
KTM 690 R - "Its just a little crush..." |
02-10-2013, 07:14 AM
#7162 |
Oddometer: 458
i have a 690 coming to me in the next few days
i read about the tank bolts and seen the offering from various vendors but the prices seen quite excessive.... for a few bolts.Any reason why I cant just replace the originals wiith stronger bolts ? i also believe the tank bushes are part of the problem, i heard some one makes replacements - who? or where on the tank are the bushes? |
02-10-2013, 07:26 AM
#7163 | |
Cranky Old Fart
Oddometer: 2,329
When I went to remove the existing bushing I found one side was locked in place. Had to put the other side bolt back in and use an impact to break it loose. Using a single bolt eliminates that possible issue.
02-10-2013, 08:24 AM
#7164 |
Oddometer: 458
yep saw that post now.. ill have a look when i get it and go from there.
02-10-2013, 09:32 AM
#7165 | |
lost in the 690 mega
Oddometer: 319
I see a lot of people changing the lower tank bolt (good idea) but not too many people changing the bushings themselves. My lower bushings were sloppy as all hell by the time I hit 3k miles so I replaced them with Delrin bushings that I purchased from "partmaker" in the vendor's forum here on ADV. Absolutely no slop in the 9k miles since!
02-10-2013, 09:39 AM
#7166 |
Cranky Old Fart
Oddometer: 2,329
I was thinking of throwing some shrink tubing on mine to shim them up.
Sent from outer space with my Thunderbolt with Tapatalk.
02-10-2013, 09:56 AM
#7167 | |
Oddometer: 169
On my simple fix, I just ordered a few grade 8, 5/16" bolts (Amazon) to replace the softer bolt I bought locally. Cheers, MrHix |
02-10-2013, 10:04 AM
#7168 | |
Cranky Old Fart
Oddometer: 2,329
I can get grade 8 from a place near my work. Sent from outer space with my Thunderbolt with Tapatalk.
02-10-2013, 10:14 AM
#7169 |
SE Asia adventure tours
Oddometer: 598
02-10-2013, 10:18 AM
#7170 | |
Oddometer: 193
www.rally-raidproducts.co.uk |
