Old 02-13-2013, 03:57 AM   #7186
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 588
I have the same light, clear, with integrated blinkers. The light itself is very bright, but the blinkers are so close to each other (well, what did I expect, in such a small unit ) that they're not very distinguishable or visible for riders or cars behind you while riding.
I'd go for this unit without integrated blinkers, and use separate blinkers instead. Just my 2ct off course :)
The seller provides clear instructions and support, so you won't have any trouble installing it.
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos is offline   Reply With Quote
Old 02-13-2013, 04:28 AM   #7187
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
I've already been thru this before with led unit on my 950. I keep my external turn signals. This is in addition. I want those dam cagers to see me. I make up Molex y cables so it all plugs in cleanly. I absolutely hate to cut up a harness. Most all mods I do are at the connectors. Did similar for SAS foolers.
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 02-13-2013, 05:04 AM   #7188
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 973
Originally Posted by Honkey Cat View Post
ok, I've got the vortex ecu installed with a leo vince slip on and open stock air box. Bike runs amazing except it does have some very slight surging. Once you notice it, it will drive you bonkers ( it does me ) It also has some very snappy throttle. I've been told that 30% of the TPS are bad and you have to bring it to the dealer to check the ohm's etc... Is there a way to check it out myself with a snap on meter?
Thanks for your reply's
I've posted the procedure (link to a supermoto site) to check it with a VOM meter somewhere on this thread, but I cant find it.
Adding some fuel via the trims will improve the throttle and the surging. I run the 10% slower throttle map off-road and the 25% when commuting. The 10% is not too snappy, but its jerky when shutting off. When off-road you can't feel it, but running on a trailing throttle in town is crap. The 25 % slower throttle is much gentler when closing. Am I making any sense?
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 02-13-2013, 05:31 AM   #7189
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Didn't Richard at Vortex make an updated map?
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-13-2013, 08:08 AM   #7190
Velociraptor
TrackBum
Oddometer: 1,122
The latest map updates I have seen are dated Jan 18,2013. I have been in contact with Richard because I got the map switch. That switch switches between map1 and any other map. The new map setup has 5 maps for open airbox and 5 maps for closed air box. My bike has closed airbox. The problem is the first 5 maps are for open airbox, so the switch is kind of useless. I asked him to do a setup where the first map will be the power map for closed air box and also to add an economy map. He said he would do it last week but so far no word. I will have to mail the ECU to Mike Tolle in California to get it reflashed, but I am not going to mail it until Richard sends the setup I want to Mike. I have not had any issues with surging though.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 02-13-2013, 10:04 AM   #7191
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Originally Posted by dad2bike View Post
I installed the upgrade fuel pump into the tank. Part of that job included relocating the fuel filter to the outside. Using plenty of hose I was able to put the filter in a location easily accessable for field access on trail.
NO the one clamp is not loose. I started with the small size clamp and went to the larger size on the second. Too much fight to get the small one to fit.
Hey man, what size fuel line do you need to do this? Did you replace all of it from the regulator forward? I'm considering doing this soon, because I've ran into some issues fitting this into the available space...
THAT, and having access to an external fuel filter would be much more desirable.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 02-13-2013, 10:13 AM   #7192
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
I bought a 36" piece of 5/16" injector line bulk. Yes, it comes from the regulator and sweeps under the TB and around to the left side of the filter. Length isn't much of an issue at those pressures. I found a purilator version of the filter at Pep Boys along with the injector line and the good fuel clamps. For inside the tank I got a packaged 18" piece of injector line (cheaper and I had already bought it before finding the bulk). Perfect length to take out the filter and the plastic line from the pump to the first connector. That way no adapters needed. Just 2 clamps.
FYI for those carying a spare pump. I found a #8 press nut works perfect for the OEM screen assembly. I'll be picking up a couple to put with the Original pump I'll be carrying for spare.
I'm considering using this to replace all the clamps inside the tanks. I picked one up at SEMA a few years ago. Neet tool for hose clamping in places that a long term.
http://www.clamptitetools.com/home.html
Tom
My2Wheels
690 WIKI
Old 02-13-2013, 11:03 AM   #7193
Biped
NooB Again
Biped's Avatar
Oddometer: 339
.......For inside the tank I got a packaged 18" piece of injector line (cheaper and I had already bought it before finding the bulk). Perfect length to take out the filter and the plastic line from the pump to the first connector.......
You will need submersable fuel injection hose for inside the tank, it is not cheap. The regular stuff does not have a fuel proof outer skin and will deteriorate over time while submerged and spring a leak.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is online now   Reply With Quote
Old 02-13-2013, 12:21 PM   #7194
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
Hmm, yeah I forgot. Headed to the parts shop now. No gas in the tank yet.
Tom
My2Wheels
690 WIKI
Old 02-13-2013, 12:58 PM   #7195
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
I found the corrugated flexible line on McMaster Carr. The only difference is that it's clear instead of black. I eliminated the inline filter and quick disconnects entirely and it's much easier to change out the pump with out needing to stuff all the crap into the tank. 12" line was $14 as I recall.
Just say'IN
Old 02-13-2013, 01:05 PM   #7196
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
Got more info on that?
Tom
My2Wheels
690 WIKI
Old 02-13-2013, 01:21 PM   #7197
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 429
Originally Posted by BK.RD.RNR View Post
I'd be interested if someone is putting together another group buy, or if someone has one they did not use and want to sell, PM me please.
Give Acme Rider Supply (local shop here in the Atlanta area a shout. I believe he's putting together a group buy on the Oberon Slave cylinder (he did some research and I guess determined this was the best thing going.)
Andrew (owner) is a great guy and an inmate on here. Highly recommended. (And no, I have no financial incentive for the referral, just a happy customer.)
Hope this helps,
Jeff
PS: Hope this isn't 205--I haven't been keeping up lately.
FriedDuck is offline   Reply With Quote
Old 02-13-2013, 02:55 PM   #7198
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
Looks like I will be reworking the fuel pump assembly tomorrow night. The parts place I deal with has to order in another piece of hose. That stuff is only sold in 12" sections. I need 2 to do the entire rework similar to what is in the WIKI. At least I get a good guy price.
Tom
My2Wheels
690 WIKI
Old 02-13-2013, 05:04 PM   #7199
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
http://www.mcmaster.com/#catalog/119/143/=lgtglr
The teflon line 55155K42
Even the submersible hose seems to get weak after a period of time, I wasn't please at all with it. I bought 5/16 cinch clamps and from my local parts store, an entire bag for $6
Just say'IN
Old 02-14-2013, 08:23 AM   #7200
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,748
Hope this helps,
Jeff
Thanks for the info.
BK.RD.RNR is offline   Reply With Quote
Times are GMT -7.   It's 03:34 PM.
