Old 02-18-2013, 06:06 AM   #7306
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
Originally Posted by MrHix View Post
That is not the "new" style. This is the new one:
The handguard bolts only thread into the first 1" of the outer end.
Cheers,
MrHix
The website indicates having to chop off the first 1" of bar. I run about 1/2" of spacer out to my cycra's now. I'm thinking I could just use these on the end. Have really good clearance from my lever ends.
They are local to us. I'm hoping they are open today. I can swing by and talk with Don. I've got 4 bikes to fit if they prove out good on the Ginger.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 02-18-2013, 08:09 AM   #7307
MrHix
MrHix's Avatar
Oddometer: 384
Yup,
Just have to slide the grips further onto the bars to leave the 1/2". Only drawback might be that it is easier to get grit under the throttle tube? Maybe not.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 02-18-2013, 01:53 PM   #7308
dazler
Oddometer: 178
Hi I tought all KTM were high maintenance wise, so I overlook this one.
I been reading and found that some people say the 2012 have some issues how hard are they to resolve. is the 2013 the same?
separated the throttle body from the motor
bad tank bolts
pivot bolts
radiator fan shroud and blades wearing into radiator quickly
leaking coolant on metal pump face thingo
stalling at idle at lights,ecu fuel tuning etc
polycarbonate sub frame ?
rubber fuel or coolant? hose needs to be zip tied to frame to avoid wear
How long it takes to change oil/filter?
also what is the alternator rated at?
dazler is offline   Reply With Quote
Old 02-18-2013, 02:14 PM   #7309
MrHix
MrHix's Avatar
Oddometer: 384
bad tank bolts
pivot bolts
I've only got about 1500 miles on my '12, but have had no problems. I did change the lower tank mount to a through bolt, but it only cost me about $2. I just did it because I could do it easily & cheaply, not because anything broke.
Oil & filter change only takes 20 minutes or so.
Alternator puts out 224 watts (according to the service manual).
Not all the 690s are falling apart!
MrHix
Old 02-18-2013, 02:26 PM   #7310
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
bad tank bolts
pivot bolts
So these are all well documented issues that have simple solutions know to the 690 crowd since about mid 08. Unfortunately every bike has its issues.
My 08 has about 12 rally motos on it, a hill climb, one endurance rally lots of trail riding and about 10000 miles on the clock.
I zip tied the rad guard on
replaced the clutch slave
Custom mapped the ecu
Insulated the fuel line
Changed air filter to foam
Changed to fmf exhaust
replaced seat
Changed upper and lower tank bolts.
My original fuel pump lasted 9500 miles and siezed due to dirty fuel in australia.
i fixed my "clouding" speedo problem but then got a new one warranteed.
Installed a different headlight.
Have done many other changes for ergo, performance, suspension etc.
Seth S
Seth S screwed with this post 02-18-2013 at 02:34 PM
Seth S is online now   Reply With Quote
Old 02-18-2013, 02:53 PM   #7311
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
My son TJ rode Ginger & I rode Big Orange over to Vibranator before lunch.
WOW! I can't say enough good about Don over a Virbanator/Ricor.:Pom
We did a bunch of experimenting before & after lunch at his place.
Finished results:
Big Orange now has a set of the regular Vibranators. Took my bars vibes to near nothing. Man I wish I had done this long ago.
Ginger started with the regular units. I rode her around the parking lot and still noticed considerable vibes.
After lunch we went back and changed up to the heavier units. Takes a huge Tap to do the end of the bars. I probably should have cut off some of the bar ends. They now stick out an inch. More clearance for the levers I guess. :p
I'm gonna say the heavy ends reduced my vibes about 70% on the 690.
Tom
My2Wheels
690 WIKI
Old 02-18-2013, 03:15 PM   #7312
Hoots
Hoots's Avatar
Oddometer: 1,457
bad tank bolts
pivot bolts
Somebody just said that these were well-documented issues with easy fixes, but I disagree.
I have still not managed to solve the sporadically flashing oil light problem on my 2012 Enduro R - Twin Air filter seems to have cut down the incidence, but the light still flickers sometimes at low revs and at idle - oil pressure OK on test - KTM are concerned, and want to keep trying to find the issue - possibly just a buggered sensor - it's booked in for another look in a couple of weeks time - this bike is still under warranty, and has been off the road for more than half its short life ...
Great bike to ride - the Twin Air filter has given it wings - astonishing difference ...
But all my riding is out in the bush, a long way from civilisation - ie 400km or more - can't have flashing oil lights in the middle of nowhere - much as I hate to say it, at least the DR650 (with suspension and other mods) was completely dependable and completely fixable by the roadside - I sold the Husaberg recently for similar unreliability issues - twice had to leave it hidden under trees, and go back for it with a vehicle - a third time a mate left me by the roadside guarding it, and came back with the car ...
High-performance bikes are fun, but for some people they also need to be reliable ...
I'll hang onto this 690 and try to get the oil light issue fixed - after that, it will need to behave for 6 months or more before I consider it a genuine adv bike (c.f. high-specced toy) - planned run to the desert in May - you really don't want complex issues out there ...
Hoots is offline   Reply With Quote
Old 02-18-2013, 03:32 PM   #7313
Seth S
Seth S's Avatar
Oddometer: 4,545
I will say the stock efi, wiring harness is not so good. Wiring harness is ok at furst but no good after too short.
Flickering light should be easy to diagnose..install gage and ride. If light flickers and psi is good its electrical. Is idle set at proper spec? Proper oil filters...oil..valve cover sealed proper...vents clear etc.
Seth S
Old 02-18-2013, 03:32 PM   #7314
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,789
IMHO the ones in the list are well documented and easy to fix, that's what the person responded too.
You've introduced another early life random failure to the mix
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee screwed with this post 02-18-2013 at 04:16 PM
BygDaddee is offline   Reply With Quote
Old 02-18-2013, 04:00 PM   #7315
dunefreak
dunefreak's Avatar
Oddometer: 93
bad tank bolts
pivot bolts
I have a 2012 with about 4500 miles on it. Not one issue yet other than a melted turn signal which I fixed by upgrading to smaller signals.
I still plan to upgrade my tank bolts. Never once had a stall that wasn't caused by myself.
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 02-18-2013, 04:31 PM   #7316
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 801
From what I understand the other fix to melted turn signal is an aftermarket can which eliminates the cat in the OEM can and thus all the heat. I pick my '10 up next week and it has this and other fixes.
Have really enjoyed this thread, learning all about my new to me 690ER.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 02-18-2013, 05:01 PM   #7317
dunefreak
dunefreak's Avatar
Oddometer: 93
I forgot to mention I upgraded to an FMF pipe as well.
Old 02-18-2013, 05:58 PM   #7318
Seth S
Seth S's Avatar
Oddometer: 4,545
Aftermarket can...reposition turn signal stalk...or switch turn signal model.
Seth S
Old 02-18-2013, 06:12 PM   #7319
Hoots
Hoots's Avatar
Oddometer: 1,457
Yes, you would think so - but two mechanics can't track it down ...
Yes, it probably is 'electrical', but on a fuel injected bike that doesn't narrow it down much ...
As far as they can tell, idle speed is as per Akro/after-market air filter KTM map ...
Yes, all that's fine ...
It may be the sensor - or someone at KTM Australia wondered whether a hot hose was too close to the sensor - said he'd seen that once before, with similar symptoms ...
This bike also does the stalling thing sometimes on aggressive braking into corners (clutch in) - probably part of the same issue ...
Old 02-18-2013, 09:08 PM   #7320
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,586
replaced seat
You left off the spacer/silicon hose on the fan shroud to prevent it from wearing holes into the rad.
Times are GMT -7.   It's 09:42 AM.
