Old 02-18-2013, 06:12 PM   #7336
Hoots
Hoots's Avatar
Oddometer: 405
Originally Posted by Seth S View Post
Flickering light should be easy to diagnose..
Yes, you would think so - but two mechanics can't track it down ...
If light flickers and psi is good its electrical.
Yes, it probably is 'electrical', but on a fuel injected bike that doesn't narrow it down much ...
Is idle set at proper spec?
As far as they can tell, idle speed is as per Akro/after-market air filter KTM map ...
Proper oil filters...oil..valve cover sealed proper...vents clear etc
Yes, all that's fine ...
It may be the sensor - or someone at KTM Australia wondered whether a hot hose was too close to the sensor - said he'd seen that once before, with similar symptoms ...
This bike also does the stalling thing sometimes on aggressive braking into corners (clutch in) - probably part of the same issue ...
Hoots is offline   Reply With Quote
Old 02-18-2013, 09:08 PM   #7337
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,830
So these are all well documented issues that have simple solutions know to the 690 crowd since about mid 08. Unfortunately every bike has its issues.
My 08 has about 12 rally motos on it, a hill climb, one endurance rally lots of trail riding and about 10000 miles on the clock.
I zip tied the rad guard on
replaced the clutch slave
Custom mapped the ecu
Insulated the fuel line
Changed air filter to foam
Changed to fmf exhaust
replaced seat
Changed upper and lower tank bolts.
My original fuel pump lasted 9500 miles and siezed due to dirty fuel in australia.
i fixed my "clouding" speedo problem but then got a new one warranteed.
Installed a different headlight.
Have done many other changes for ergo, performance, suspension etc.
You left off the spacer/silicon hose on the fan shroud to prevent it from wearing holes into the rad.
Guess what doofus, nobody reads your lame blog.
Old 02-18-2013, 09:47 PM   #7338
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 170
Originally Posted by sdd04 View Post
Can these lights be seen flashing from the side, or only behind?
They can be seen from the side. I'll get some pics up when I get a chance
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is online now   Reply With Quote
Old 02-18-2013, 09:53 PM   #7339
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,197
Yep...good call.
Seth S
Husaberg tank for sale: HERE
Seth S is offline   Reply With Quote
Old 02-19-2013, 12:28 AM   #7340
fluff34567
fluff34567's Avatar
Oddometer: 458
i have a new to me 2010 690R, the licence plate holder has been changed from stock, i would like to put it back to stock but i am missing a few bits...
does anyone know what bike the plate holder in the photo is from? looking at google images i have seen it on a few SM bikes but cant find it in the parts fiche.
fluff34567 is online now   Reply With Quote
Old 02-19-2013, 01:44 AM   #7341
milzispete
Conquistador
milzispete's Avatar
Oddometer: 109
This isn't standard either I'm affraid. The tail light is but the rest is aftermarked. Would you like the numbers for the stock items?
i contacted the spirit world but they don't know what's wrong with my 690 either
milzispete is offline   Reply With Quote
Old 02-19-2013, 02:22 AM   #7342
fluff34567
fluff34567's Avatar
Oddometer: 458
yep go on then..... thanks..
Old 02-19-2013, 04:16 AM   #7343
nibby
Oddometer: 101
gearing
Guys, currently got 14/48 gearing which is great off road. I know stock is 15/45 - what would be the closest to stock but keeping the 14 on the front please?
Cheers
nibby is offline   Reply With Quote
Old 02-19-2013, 04:33 AM   #7344
francs
Oddometer: 165
42
But why?
Put the 16 in front (it's the same) .
francs is offline   Reply With Quote
Old 02-19-2013, 05:14 AM   #7345
nibby
Oddometer: 101
Cheers. So 42 rear will bring me close to stock.
Why? might have access to a spare rear wheel so easy to swap out depending on the type of riding I'm going to be doing.
Old 02-19-2013, 05:23 AM   #7346
milzispete
Conquistador
milzispete's Avatar
Oddometer: 109
Here you go -included nuts, bolts, flashers and wiring as I don't know what you have already
54814025200 FLASHER CPL. FR.L/S RE.R/S Qty 1
54814026200 FLASHER CPL. FR.R/S RE.L/S Qty 1
49011435100 BULB 12V 5W (W2,1X9,5D) PHIL. Qty 1
76511078000 WIRING HARN. LIC. PLATE ILLUM. Qty 1
44111015100 BULB 12V 10W (BA15S) Qty 2
0081250181 SCREW FOR PLASTIC 50 X 18 T20 Qty 1
58414030000 HEX HEAD COLLAR NUT M10 X 1, 25 WS=13 Qty 2
76511076000 WIRING HARNESS FLASHER REAR Qty 1
0017060203 EJOT PT SCREW K60X20 WS=6 Qty 4
75014047000 LICENSE PLATE ILLUMINATION Qty 1
0433100003 WASHER 18 X 10,5 X 1,6 Qty 2
0797100003 LOCK WASHER DIN6797-J10,5 ZI Qty 2
0017060303 PANEL SCREW T60 6 X 30MM Qty 2
76508016050 NUMBER PLATE LO. PART Qty 1
0025080256 TX/HEX HEAD BOLT M8 X 25MM Qty 4
76508016000 NUMBER PLATE CARRIER TOP Qty 1
Old 02-19-2013, 05:49 AM   #7347
Seth S
Seth S's Avatar
Oddometer: 3,197
Ok, Said this back in 08 when I got my bike and when we 690 pioneers started working through all these issues and sorting out the problems. Fuel injection in motorcycles has not been a given mainstream component for that long...unlike the automotive world where it has been present since the early 70's. FI in bikes does benefit from 40 years of automotive component development and even though all these EFI bikes have issues they do work well for the most part. The big issues behind the 690 system is the attempts to make the thing emission compliant.
Next issue. Up until 08 most KTM shops sold carbureted (I find it humorous that a motorcycle forum reply window indicates that "Carbureted" is spelled incorrectly)...or is that my computer?...I digress. So they sold relatively simple mechanical machines that had a couple of wires for the charging system and some simple lights. many of these dealers were forced to sell a limited number of the big 950 adventure bikes and many of those dealer mechanics had no clue how to work on them...many horror stories of dealer repairs gone wrong on those 950's...which were in reality just big simple dirt bikes. Now we quite literally jump into fuel injection...a paradigm shift in technology and for the long term traditional motorcycle mechanic a bit of a mystery. Repairing a fuel injected vehicle is not magic. Its all about learning proper trouble shooting skills, reading wiring schematics, and following logical methods of locating the problem.
So you have a flickering oil light and the bike is fuel injected...doesn't mean that its a complete loss because no one could possibly find the issue with all those wires . It is entirely possible that you have a couple of mechanics who are at this very minute being forced into a crash course with KTM efi trouble shooting and may for the first time be learnign what a DVOM is or a wire probe. In many ways EFI is a lot easier to trouble shoot. You have these nice color coded wires that connect everything...you have nice outputs on computer control boxes, you have a ton of ways to check things out. You don't have a bunch of passages in a mechanical box that may or may not be clogged...etc.
Seth S
Old 02-19-2013, 06:03 AM   #7348
Seth S
Seth S's Avatar
Oddometer: 3,197
I had an interesting problem a couple years ago on my 690. I was on a long solo trail ride and I was going down a long hill and at some point I stabbed the front brake the and bike stalled. I hit the start button and the bike cranked but didn't fire. Because it was a fuel injected bike I decided nothing could be done and that bike is now sitting at the bottom of a ravine here in Vermont.
Acutally I wiggled the ignition switch...cycled the switch on and off and noticed that the instrument cluster didnt do anything. Then I popped the seat off and checked the fuses...found the injection/cluster fuse was blown and I had 2 spares...replaced the fuse and fired back up...rode 100 feet...hit the front brake again and blew another fuse . I then coasted down the mountain until i rolled out to the highway. I inserted my last fuse and realized the one connecting factor was something around the front brake. So I rode home and didn't touch the front brake. When I got home I could not duplicate the problem. I looked through the wiring harness and found some cracked wires in the front loom...repaired those and figured that was it. A week later I went for another ride and about 20 miles from home I had the same problem. replaced my fuse, turned around, and rode home...avoiding front brake.
So fuses blow because they overload on current...when you short 2 wires together your current goes infinite...hence blown fuse...so somewhere I figured there was a short. It only happened when I applied the front brake hard and the bike dove down in front. So I started inspecting any and all components in the front end that were affected by break dive...it took some time but I finally found a spot where the insulation on the speedo sensor cable had abraded against a metal fitting on the brake line and revealed the 3 wires inside. There is a power, ground, and sensor wire inside the sheath and as luck would have it the power wire had rubbed through. Every once in a while under hard front braking the power wire would rub against the fitting on the stainless front brake line which would short out the sensor through the instrument cluster and blow the fuse....which also killed the bike because the injection was on the same fuse.
Seth S
Old 02-19-2013, 06:09 AM   #7349
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 448
Over the last 45 years I have owned many motorcycles and have never had these wiring loom problems. All this talk about rubbing wires and dieing bikes is cause for concern to one who expects the bike to do what it's told.
Makes me wonder.
Bob Hancock
'12 MultiStrada 1200 (For Sale)
'09 F800GS
'10 R1200GS
'10 690 EnduroR
JustBob is offline   Reply With Quote
Old 02-19-2013, 06:40 AM   #7350
Seth S
Seth S's Avatar
Oddometer: 3,197
Makes me wonder.
Thats because the bikes of the last 45 years have had wiring looms that had little to do with the running of the bike.
My bikes get ridden year round, in rain, mud, deep water, rough terrain, dust, sand, dirt...experience big suspension hits, vibration, crashes, tip overs, high temps etc. While the stock harness on this bike isnt great it has held up surprising well for how crummy it is :) . Try submerging your car in a mud hole up to the door tops 3 or 4 times in a summer and see how it holds up.
Seth S
Times are GMT -7.   It's 12:45 AM.
