Old 02-23-2013, 05:21 AM   #7411
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,199
My fork mods worked great! Nice and plush.
Still working with the rear shock. I got the PDS spring to fit. However, not happy with the action. Ends up with too much preload. That defeats the goal. I may just have to pay for the rear to be revalved. Holy crap that shock almost doesn't need a spring. On the bench I could barely get it to stroke.
On a related not- Those with Safari Tanks. Have you ever considered or found a second valve to put on between the tank and the Safari valve by the reservoir? Stretching that poor hose when raising the subframe to access the shock is brutal. I've used hemostats to pinch the line. That's hard on the line. I was thinking of a small ball valve near the base of the tank.
Hmm, Maybe reuse the disconnect I removed from the injector line.
I got my wide pegs all made up. I'm still milking out a 30+ year old can of Malcolm Smith Silver Husky Frame paint. I've never found a replacement for it yet.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger"
My2Wheels
dad2bike is offline   Reply With Quote
Old 02-23-2013, 07:09 AM   #7412
kevmo250
Seeker
kevmo250's Avatar
Oddometer: 2
tank bolts
Does anyone have a lead on where to buy tank bolts for the 690. KTM twin and rally raid are back ordered until April
kevmo250 is offline   Reply With Quote
Old 02-23-2013, 07:28 AM   #7413
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,199
Seems like they do them in runs. I waited for over a month for mine. I only did the top kit. The bottom I just bought a long bolt locally & drilled out the bushing.
FWIW Twins did get them in stock a week sooner than the Backorder date that was listed.
My2Wheels
Old 02-23-2013, 07:53 AM   #7414
scholz
bush league
scholz's Avatar
Oddometer: 54
any quick fix for movement in tank? bolts are and have always been checked tight. Need to fix before sandblast rally.
It appears the play is in the bottom bolts assy.
I bought rally raid top bolts but didn't use because stock ones fit better.
scholz is offline   Reply With Quote
Old 02-23-2013, 07:56 AM   #7415
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,891
I believe it was PartsMaker? here on adv had a good solution to the easily worn lower tank bushings. Maybe check the Vendors section. I am very happy with mine.
BK.RD.RNR is offline   Reply With Quote
Old 02-23-2013, 08:58 AM   #7416
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by Evil Invader View Post
Now if only Crankshaft would get his wiring harness out together with some nice ecu setups that eliminate all safetygadgets like clutchgrip preassure switch, sidestand switch and what not...
I'm heading to the Dyno on Tuesday to refine the map a bit more. It runs great, fires up easily and pulls really good in the mid range. I need to tweak the low RPM, high load portion of the map. The MAP signal is a bit bouncy and needs to be smoothed out a bit.
My 690 is already running far better than it ever did, so my project is a success. It's going to get it's trial by fire at the Sandblast rally in South Carolina a week from today!
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-23-2013, 01:16 PM   #7417
Evil Invader
Evil Invader's Avatar
Oddometer: 697
Really glad for you!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 02-23-2013, 01:52 PM   #7418
WIsixfitty
ceiling unlimited
Oddometer: 2,349
simple question (I think).
What is the valve check interval?
I checked the lc4/690 index but nothing jumped out at me.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 02-23-2013, 02:23 PM   #7419
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 2,069
I can tell you what 690 says.
Section 9 in my 2013 690 owners manual says 10,000 KM's. it used to be 7,500 KM's. I gonner get mine done at 5,000KM's.
A link to 2011 au model here, check valve clearance page 52 7,500KM's
http://www.ktm.com/uploads/tx_ktmpro...1653_en_OM.pdf
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 02-23-2013, 02:44 PM   #7420
Velociraptor
TrackBum
Oddometer: 1,139
I did not check the valves on my 2009 690r until 6,000 miles-about 10,000Km and they were all tight and just barely in spec.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 02-23-2013, 02:47 PM   #7421
BygDaddee
BygDaddee's Avatar
Oddometer: 2,069
Yeah I'm concerned about doing an inspection on Cam Rollers and Cam Roller Bearings rather then the valves
Old 02-23-2013, 03:55 PM   #7422
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 164
Re: Renazco seat fitment
I have just installed a Safari tank on my 2010 690 and am having trouble fitting my Renazco seat back on the bike with the tank on. The Olympic way to install the seat is to put it on with he tank unbolted and then bolt the tank down. I have the tank installed as high as possible and still be able to bolt it up, so what am I doing wrong? Has anyone else had this problem? Thanks
Bumpaman is offline   Reply With Quote
Old 02-23-2013, 04:00 PM   #7423
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,215
I'm pretty sure the Rally Raid guard had been sitting around for a year before the Sigutech group buy... check!
Rattle canned the guard and finally got around to it on this dreary southern winter day.
Before:
During:
Done:
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 02-23-2013, 05:03 PM   #7424
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,199
I have a Corbin seat and a Safari tank. The seat fits very tight under the tank. The front mounts on the frame & seat need to be removed. The previous owner also left off the tank bracket up front. No need for it.
My2Wheels
Old 02-23-2013, 07:17 PM   #7425
Bumpaman
Oddometer: 164
Thanks d2d. I will remove the bracket for the seat.
Times are GMT -7.   It's 03:56 AM.
