Old 02-24-2013, 08:55 PM   #7456
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
A snipet from the restacker.com site regarding dance between spring selection and associated damping:
Summary
Through tuning of the compression and rebound damping both the soft and stiff spring setups can be made to produce identical bump travel and nearly identical suspension response times. Soft springs require heavy compression damping and light rebound damping. At the limit, soft springs are unable to produce the wheel acceleration rates needed in the rebound stroke to keep the suspension from packing.
Stiff springs with light compression and heavy rebound damping produce the fastest suspension response and the plushest ride. The trick in setting up a motorcycle suspension is to find the stiffest possible spring that still uses all of the suspension travel for the speeds and terrain that you ride. For a trail setup at low speed a light spring will be needed to insure the suspension uses all of the travel. At the higher bike speeds of a desert suspension setup a stiffer spring is needed to keep the suspension from bottoming.
EDIT: i keep doing this.... :) the working setup that I have in my 950 ADV includes a set of .60s and a complete rework of all shim stacks, hand blended transfer ports, 1/8" top drilled the spring guides, 1/8" drilled bottoming cups, no mid valve free float(some suspension shops drill a bleed hole through the valve piston), doubled drilled base compression valve holder, back relieved stack holders... Thinking that I am going to try this recipe on the 690, adjusted for weight and give it a try
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind screwed with this post 02-24-2013 at 09:11 PM
Head2Wind is offline   Reply With Quote
Old 02-25-2013, 12:15 AM   #7457
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,596
Originally Posted by thorinoakenshield View Post
What's the deal with the rear wheel spacers on the sprocket side?
I had this problem before, and I kind of ignored it. Now, I'm chaning my rear tire again and I was determined to remove the leftmost spacer.
What a pain in the ass! I had to bang it out with a screwdriver and aluminum rod. I marred the spacer all up to holy hell!!
Whoops....not a big deal,really.....
Why was I so determined? I wanted to see how effed my bearing where.
They're ok, thankfully, but I did find some RUST!! Most bike aren't lubed for shit from the factory, and this bike is no exception....
Dammit. Atleast the bearings spin fine....
So then I greased those spacers up with some marine grease and attempted to stick them back into the sprocket hub.
It's a tight fit! What the hell?! I had to tap them in with a mallet kind of hard!!! This seems really weird. The spacers have always slid in and out for every bike I've had, including another KTM.
Is that what everybody else has to do??!!
This means that for the next tire change, I'm going to have to go through all this crap again!!
It's such a tight fit, I'll have to struggle to get the spacers out again (even if I lubed them up)...for rust cleaning/bearing checking and re-lubing.
This is how I feel right now:
Don't have a problem with the spacer on either my 17" 0r 18" wheels. Hell, it usually falls off just as I'm trying to slide the wheel back in.
Old 02-25-2013, 03:24 AM   #7458
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 256
Originally Posted by scholz View Post
any quick fix for movement in tank? bolts are and have always been checked tight. Need to fix before sandblast rally.
It appears the play is in the bottom bolts assy.
I bought rally raid top bolts but didn't use because stock ones fit better.
Isolation tape around the inserts and tape around the metal part as tight as you can-> no movement
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 02-25-2013, 04:23 AM   #7459
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 158
What is isolation tape?
Bumpaman is offline   Reply With Quote
Old 02-25-2013, 04:31 AM   #7460
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,479
Electrical tape.
MeinMotorrad is offline   Reply With Quote
Old 02-25-2013, 05:08 AM   #7461
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 453
if my experience is contrary to what everybody else is experiencing, maybe i should make a warranty claim?
i know stuck spacers are not uncommon, but the bike is less than a year old.
and putting them back in? i had to bang them back in. wtf?!??!
thorinoakenshield is offline   Reply With Quote
Old 02-25-2013, 05:48 AM   #7462
snakepilot
Oddometer: 64
Originally Posted by CanadianX View Post
Anyone know if the KTM Powerparts rad protection fits a 2012?
Yes. I have it on my 2012 R.
snakepilot is online now   Reply With Quote
Old 02-25-2013, 05:59 AM   #7463
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,591
Great, thanks snakepilot.
CanadianX is offline   Reply With Quote
Old 02-25-2013, 06:33 AM   #7464
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,549
Originally Posted by Head2Wind View Post
EDIT: Oh, and as a side note, I have to say that the Factory rally bike that I rode (thanks Steve) before I got my 690 was one of the things that led me to really really want one of these bikes. The factory race suspension is SO AMAZING on fast stutter bumps. The faster the bike is ridden, the better it gets and it REALLY likes it when you are on the power through all types of corners, just CLAMPS the bike to the earth. freaking amazing. HOWEVER... the "public" version of the 690 suspension is very much NOT what the rally bike is.... the next HOWEVER is I hope that I can manage to get the WP suspenders close to the factory stuff...
I think there are several of us who fell in love with the factory rally bike through actually riding it or just seeing it in action...who now want something similar in the normal version. I think the suspension that the factory bike starts with is just better out of the box and more tuneable. The rear shock is different as are the forks and even the frame is different on that bike. The closest out of the box is probably a set of SXS forks and maybe an Ohlins shock ...if there is one that fits the frame...probably a $4000 package before tuning.
Seth S
Seth S is offline   Reply With Quote
Old 02-25-2013, 07:00 AM   #7465
Noyah
poser
Noyah's Avatar
Oddometer: 400
Öhlins KT 122
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 02-25-2013, 07:13 AM   #7466
MeinMotorrad
Oddometer: 1,479
Exactly the same as my 2012. I was going to try to prise them out but didn't bother in the end. I've got that rust too. I just greased the hell out of everything and put it back together. I'll check every time I change tyres and again near the end of the warranty period. If it's not good then KTM can fix it
There's hardly any grease on the front wheel either.
Old 02-25-2013, 12:12 PM   #7467
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,954
That's it, Seth.
Bruno T . is online now   Reply With Quote
Old 02-25-2013, 01:16 PM   #7468
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
I agree, pretty much different motorcycles that are sharing a few components and a KTM badge. If I recall correctly the RR frame has a few less cross braces in a few areas. With the fixed and dynamic mass locations, weight and suspension being rather different the semi common area is the engine. Even at that the 700cc RR race spec engine behaves differently than the 08 short stroke 654cc
Crankshaft went the SXS fork route. I've chatted with him about this change. After doing a bit of research about the differences of close/open chamber forks, I am going to stay away from the closed twin chamber forks for this application.
My goal is going to be setting it up in "soft desert" trim (245lb rider weight) with clickers set at mid positions to deal with the broad range of DS type work the bike will be doing. I believe the best way for me to get there is to run higher rate springs both front and rear (.56-.58 front, 9.2-9.5 rear) with associated damping changes (soften compression, increase rebound bases). The hope is that when I get off into the local single track and jeep trails I can pull back the dials enough to get it close to a "stiff trail" setup. I might even take a look at the RR fork clamp assembly on Steve's RR to see if the offset and total trail is different. That might be interesting to know.....
Old 02-25-2013, 05:22 PM   #7469
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,110
Once you see the price of the RR triple you will re think and just use a sxs triple
The frame has more gussets and longer at the head stem / back bone there are some pic of comas bike and deperes and there's is a noticeable differences in the head stem area
Mudguts is offline   Reply With Quote
Old 02-25-2013, 06:37 PM   #7470
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
I am sure the RR prices are crazy. Just curious if it would be possible to emulate the geometry without cutting/pasting the frame, which is technically possible, just lots of work. I am going to see if i can spend some one on one time with a RR and a frame jig to baseline and compare to the 690 E
Sent from ADVmachines.com via Tapatalk
Times are GMT -7.   It's 02:08 PM.
