09-11-2011, 07:55 PM
#61 | |
Safari Scramble!!!!!
Oddometer: 3,202
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
09-11-2011, 07:59 PM
#62 |
TrackBum
Oddometer: 463
Will do. Thanks!
2009 KTM 690r Enduro in da house 2002 RC51 SOLD 2010 KTM 990 Supermoto R |
09-11-2011, 11:51 PM
#63 |
Supern00ba
Oddometer: 519
2011 owners manual - Static 25mm, Riding sag 70 - 80 mm
Makes a tallish bike huge
KTM 690 R - "Its just a little crush..." |
09-11-2011, 11:54 PM
#64 | |
Supern00ba
Oddometer: 519
I think you are definitely on the right track here.
09-12-2011, 05:29 AM
#65 |
Oddometer: 569
Service tech says I have stator issue
I've been getting FI faults and overheating errors periodically. Finally got worse and just died. Sometimes would restart sometimes not and seemed to have low battery. Charged it and same thing again. Dealer service rep put it on the computer and said multiple sensor errors from many places so checked the stator output. 10.5V at idle and 11.5V at high RPM. Said the low voltage caused all the errors including the erroneous overheat indications plus didn't keep the battery charged. Now waiting for a new stator. I haven't read of any stator issue, has anyone had similar prblems?
Johnlt 2007 BMW R1200 RT, 2002 Suzuki DRZ400S, 2000 Suzuki DR200 1985 BMW R80RT, 1975 BMW R75/6 Yamaha WR250R |
09-12-2011, 06:23 AM
#66 |
Oddometer: 3,202
interesting. well you can always try going more or less till you find what works best for you. maybe its because of the linkage...where the other bikes (exc's and husabergs etc...not the other 690's) have no linkage.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE Seth S screwed with this post 09-12-2011 at 07:48 AM |
09-12-2011, 06:53 AM
#67 |
Oddometer: 38
I helped Daniel out with the map. He has a 2011 Enduro R with a FMF Apex pipe and a Evo1 airbox lid. It wouldn't idle when cold and was noticably lean. I started with the 2011 Akro map (it was a little richer than the Evo1 map) and I did the changes outlined in the "Code Orange" thread. He had a big smile when he came back from the test ride!! |
09-12-2011, 08:13 AM
#68 |
Dirty Old Man
Oddometer: 772
anybody remember what rear rotor will work for the 690? bent mine and need it asap
thanks btw 1800 miles off road zero problems with anything but the bent rotor. fi worked flawlessly. thanks to those that helped me sort the maps.
Ride the DEZ 05 FE 550 Husaberg plated 09 KTM 690 |
09-12-2011, 09:04 AM
#69 |
Rookie
Oddometer: 265
If you still need stiffer spring, you can also contact Javier @ Trailtricks. He has progressive 8.4-10.4 in stock. I have one and it works very well, both in the woods and fast gravel. I weight 103 kg's w/o gear. I didn't change the fork springs as it works good enough and they must've been a tad too stiff in comparisation to what they threw on the rear stock wise. It's more 'balanced' now.
09-12-2011, 09:11 AM
#70 | |
Way Offline
Oddometer: 1,162
I am at one with my duality. |
09-12-2011, 09:59 AM
#71 |
Oddometer: 3,202
I got one from EBC thats not a wave rotor and I got a stock galfer wave rotor...neither are floating. Barman or someone got a floater rear but I never figured out where he got it from.
09-12-2011, 10:03 AM
#72 |
Oddometer: 63
Galfer Floating Rear Rotor
09-12-2011, 10:24 AM
#73 | ||
Way Offline
Oddometer: 1,162
I am at one with my duality. Barman screwed with this post 09-12-2011 at 04:13 PM |
09-12-2011, 10:31 AM
#74 | ||
Supern00ba
Oddometer: 519
It appears that a simple tightening up of the steering head bearing helped a fair bit. I'm still going the Superplush 90 route, as I can get it easily via KTMTwins. I believe that static sag must be in the correct range as well.
09-12-2011, 11:25 AM
#75 | |
Hey, watch this!
Oddometer: 898
It completely transformed the bike. It helped just as much when I did the 15 min idle procedure (which I could not before because it would die after <1min at idle when cold). I can tell the "code orange" changes as well. It has very predictable power with a nice boost in the mid range torque curve. I owe you for the help.
Daniel What would you attempt to do in life if you knew that you could not fail? |
