Old 03-01-2013, 04:25 AM   #7516
nibby
Oddometer: 105
OEM toolkit
Does anyone have a picture of what should be included in the OEM toolkit with the 690 please?
cheers
nibby is offline   Reply With Quote
Old 03-01-2013, 04:33 AM   #7517
johnno950
Oddometer: 1,068
Originally Posted by Raceforever View Post
Looks great,very high quality workmanship!
johnno950 is offline   Reply With Quote
Old 03-01-2013, 04:39 AM   #7518
johnno950
Oddometer: 1,068
Originally Posted by MeinMotorrad View Post
Kind of my thoughts too. Do you get any advantages with this set up? Looks like you might cook your foot
Maybe suits oldmates tanks better,fair airgap between footpeg pipe,doubt would be a issue.
Old 03-01-2013, 04:54 AM   #7519
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
cheers
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 03-01-2013, 05:03 AM   #7520
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Originally Posted by Dotbond View Post
Yep, got a burn hole in the left leg of my $400 Revit pants. Not happy about that. Dumb Austrians.
Klim puts leather on the inside of both legs. Just sayin'
Old 03-01-2013, 05:24 AM   #7521
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,582
Restarting a drowned 690?
Restart procedure for a drowned 690? Is there any easy way to get to the plug, seems like it would be a bit of a PITA to get to if you had to pull it to blow the water out.
CanadianX is offline   Reply With Quote
Old 03-01-2013, 05:50 AM   #7522
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,570
Got a piar of Klim Dakar's that my stock can burned a hole in, just sayin.
Old 03-01-2013, 06:08 AM   #7523
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,535
Stock can...just sayin....would burn a hole through depleted Uranium
Seth S
Seth S is online now   Reply With Quote
Old 03-01-2013, 06:09 AM   #7524
Seth S
Seth S's Avatar
Oddometer: 4,535
When you get the kick I suggest you take item 31 and sell it for the $ .0003 scrap value it is worth. Replace it with something a bit more substantial.
Seth S
Old 03-01-2013, 06:11 AM   #7525
Seth S
Seth S's Avatar
Oddometer: 4,535
I just finished moving out of my apartment and both bikes are currently residing in my garage...a 2004 Sprinter van...very good for sprinter snow traction. I turned the key on the 690 to see where the battery is at and it came right to life and cranked no problem. It has a Shorai battery and the bike has not been Run since last June.
Seth S
Old 03-01-2013, 06:36 AM   #7526
nibby
Oddometer: 105
Perfect. Thanks for that
Old 03-01-2013, 06:44 AM   #7527
nibby
Oddometer: 105
Cheers.
What apart from tyre changing tools would you add to the standard KTM toolkit if wanting to keep it to a minimum for day trips? If the worst happens and it's not a quick fix then wont be too far from home and breakdown cover will get me there type of thing?
Old 03-01-2013, 06:54 AM   #7528
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,123
Hondas will burn a hole in em too. Ask me how I know.
fastdadio is offline   Reply With Quote
Old 03-01-2013, 07:08 AM   #7529
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Cheers.
This is my tool kit. But i'm on an RTW.. not on a day trip. Its basically everything I need to take apart most of the bike. Including most of the motor. (calipers and multimeter cus i'm a nerd)
I would keep E-tape and a few connections just in case. Zip ties, tube, radiator fix, fast dry epoxy puddy, a select few bolts/nuts/washers and a vice grips. I know some people are going to say the vice grips is to heavy.. but if you need it, you need it.... and you are thankful you have it.
Old 03-01-2013, 07:58 AM   #7530
nibby
Oddometer: 105
Great help, thanks again.
If it's going to take more than an hr on a day ride I'll call the tow truck and do it in the garage
Times are GMT -7.   It's 12:14 PM.
