Old 03-06-2013, 08:59 AM   #7621
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 169
Originally Posted by Albie View Post
I imagine NOT having a thermonuclear reactor bolted to your bike will be a lot less likely to burn out components and ADD to reliability.
Not really - Sherri Jo has plenty more km's on her 690 with a stock can. That said I have had both a Leo Vince and Akra on my 690's and couldn't be happier. Anybody want to buy some unused stock cans
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 03-06-2013, 10:08 AM   #7622
ghostridergary
Oddometer: 4
Why is fuel filter between the pump & regulator?
I've seen lots of posts about in tank and outside tank filters and their benefits.
Could someone explain to me the rationale for why the filter is between the pump and the regulator - presumably there is a reason for having it there rather than where the disconnect is (outside the tank)?
The fuel going to the regulator from the pump has already passed through the mesh screen before entering the pump so why does it need to be filtered again? Is the regulator that sensitive?
Why not just connect the pump to the regulator (without the filter) and put a filter in place of the disconnect?
Any explanations appreciated........
ghostridergary is offline   Reply With Quote
Old 03-06-2013, 10:39 AM   #7623
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,323
Some of us do just that. I moved mine outside and reduced the tubing mess in the tank considerably. I can swap filters at any interval I choose now without much fuss.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC
To Think is to Create!http://my2wheels.com/forum/cmps_index.php
dad2bike is online now   Reply With Quote
Old 03-06-2013, 10:54 AM   #7624
Velociraptor
TrackBum
Oddometer: 457
Good question. I do not have an answer since I do not know the details of how a regulator works. I once took apart the in-tank fuel filter. The filter material was darker colored compared to a new one but that seemed to be due to being exposed to gas rather than being clogged. There was no debris in the screen or the filter. For now I left the in-tank fuel filter and added an external one in place of the quick disconnect in order to minimize the chances of the injector clogging. Probably overkill. My 09 has 11,000 miles on it and I have never had a fuel related issue. I replaced the stock fuel pump a long time ago with one from CA Cycleworks.
2009 KTM 690r Enduro in da house
2002 RC51 SOLD
2010 KTM 990 Supermoto R
Velociraptor is offline   Reply With Quote
Old 03-06-2013, 11:38 AM   #7625
690R
Oddometer: 14
KTM 690 Carbon/Kevlar Parts
Hey guys,
Just wanted to give you all a heads up. I posted up an add for the Carbon Fiber/Kevlar rally style skid plate and carbon fiber exhaust guards for sale over in the Vendor section. Here's a link to pics. Shoot me a PM if you're interested.
690R is offline   Reply With Quote
Old 03-06-2013, 12:26 PM   #7626
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 446
Rear brake pads
Having a bit of a problem getting them back in. The pad away from the piston rotates down on the bolt as if there's nothing to keep it up on the front end. The owners manual says "Check that leaf spring (5) in the brake caliper and sliding plate (6) in the brake caliper are seated correctly." The picture next to the words shows the leaf spring and sliding plate. But I don't see a sliding plate in my brake caliper. Just the leaf spring which is positioned properly. I can't find this "sliding plate" in the spare parts manual, nor did anything fall out when I removed the pads.
But I can't get the referenced pad to stay put, up in the caliper. I'm obviously missing something. Help.
Bob Hancock
'12 MultiStrada 1200 (For Sale)
'09 F800GS
'10 R1200GS
'10 690 EnduroR
JustBob is offline   Reply With Quote
Old 03-06-2013, 12:37 PM   #7627
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,323
If you spread the caliper all the way out there is a small gap that the pad can drop thru. I had this happen to me.
With the wheel off you can put the pad back into the groove. Push on the brakes a bit to put the caliper close enough to keep them in before putting the wheel on. Wheel still on takes pulling that PITA pin to get the pads off. Then put back on.
Tom
Old 03-06-2013, 12:40 PM   #7628
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 3,853
Originally Posted by Head2Wind View Post
I also slotted the forward airbox mount tabs so I can remove the airbox without pulling the Rally tanks, which included cutting up a engineered design..... works better now with better engineering
This sounds interesting, do you have any pictures?
BK.RD.RNR is offline   Reply With Quote
Old 03-06-2013, 01:19 PM   #7629
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 446
Got it! Pushing on the brake a bit was the key. Thanks.
Bob Hancock
'09 F800GS
'10 R1200GS
'10 690 EnduroR
Old 03-06-2013, 02:15 PM   #7630
modeselector
Common as muck
modeselector's Avatar
Oddometer: 482
Anyone care to post the material and procedure here? Will then get it posted to the Wiki.
modeselector is offline   Reply With Quote
Old 03-06-2013, 02:26 PM   #7631
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,323
I used the existing Wiki fuel pump post to do the inside with some tweaks removing the plastic lines all together. As far as outside, there seems to be a variety of opinions on locations for the filter. I chose my location to allow easy access for changes.
Tom
Old 03-06-2013, 02:28 PM   #7632
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,323
BTW Thanks for keeping that Wiki up. It has been extremely helpful to me in getting all those little things taken care of.
Tom
Old 03-06-2013, 02:37 PM   #7633
DirtJack
DirtJack's Avatar
Oddometer: 330
Originally Posted by Kirk the Jerk View Post
For the 690's, I don't believe that is correct. I believe that option is only for newer 990's...
http://tuneecu.com/TuneECU_En/mapedit.html
Just did a reset two days ago. For those not sure, read page 169 of the 690 shop manual.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack screwed with this post 03-08-2013 at 02:52 PM
DirtJack is offline   Reply With Quote
Old 03-06-2013, 02:42 PM   #7634
modeselector
Common as muck
Oddometer: 482
I'd love to take credit for the 690 Wiki but MuffinMan and others have really made it happen.
The fuel filter relocate to the exterior is a common question here and would be great to have this on the Wiki.
Anyone have a step-by-step?
Old 03-06-2013, 02:50 PM   #7635
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 446
Where is the Wiki?
Bob Hancock
'09 F800GS
'10 R1200GS
'10 690 EnduroR
Times are GMT -7.   It's 07:59 PM.
