Old 03-11-2013, 09:57 AM   #7711
Baja Dad
Baja Dad's Avatar
Oddometer: 1,976
Originally Posted by BK.RD.RNR View Post
That must be why my bike goes from running a little rough, to obviously much more smoothly, in the seconds just prior to me getting ready to switch the bike off while looking at my watch.
It works for me !!!!!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 03-11-2013, 10:26 AM   #7712
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
Beanie
RIP.
Will miss your balanced view on 690 Rally issues.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 03-11-2013, 10:47 AM   #7713
DirtJack
DirtJack's Avatar
Oddometer: 1,580
Originally Posted by Albie View Post
Doubtful batteries are magically disconnecting in rush hour traffic to accomplish an actual reset.
A battery disconnect doing a reset adaptation is a myth too. The FI adaptation data acquired during the 15 minute idle procedure is stored in non-volatile memory. If the ECU were powered up to hold this data, battery life would be affected. Nothing in the manuals about needing to do a 15 minute idle after changing a battery.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-11-2013, 12:28 PM   #7714
Noyah
poser
Noyah's Avatar
Oddometer: 400
Originally Posted by Bruno T . View Post
It's really not that hard, research "reset adaptations".
If you do that, you will learn that the ecu must be commanded to perform that function [via tune ecu or the ktm XC-1] prior to the 15 min idle procedure.
No thats how it works on KTM 990, not 690 rtfm
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 03-11-2013, 12:49 PM   #7715
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by RoninMoto View Post
On my 2010 and my 2008 I just replaced the filter with a small metal tube and relocated the filter outside the tank. When putting the pump back in the tank, you have to give it a "twist" as you are putting it in to avoid the kinking. This is how they do it from the factory.
To keep this info flowing and clearer.....I have some observations and questions:
I have been into the tank once in order to install Safari Tank and will be in there again soon to do a filter change and maybe install my CA pump...bike has about 18,000 kms with no fuel delivery problems noted at this time.
Uller identified the Napa immersible fuel line and my research indicates that rubber injector fuel line is designed so the INTERIOR wall of line is fuel resistant while the EXTERNAL rubber wall is not. As such, the Uller-identified fuel line has the line's exterior wall made of the same fuel resistant rubber: regular FI line will expend/deteriorate when submersed in fuel over time and this will lead to fuel line deterioration and problems (there is an industry standard for such immersible fuel lines....the Napa line satisfies this standard as does the stock and some aftermarket "corrugated " fuel lines). Crankshaft recently sourced some of the corrugated fuel line....my research indicates it comes in various lengths, each length having a non-corrugated end so as to accept a clamp. It appears that the corrugated line is designed to resist kinking....and experience suggests that the immersible line is thick enough that it is highly unlikely to kink if the length of the line is not excessive.
The Napa fuel line (and similar line w/ industry standard approval) ranges from $20-$30 a foot....the part # Uller provided is for 12 inches of line (#H209 -- 5/16” x 1’) a different part # is used for longer Napa fuel line "package", as it comes pre-measured and not on a spool in the back of the shop.....
So that's the poop on fuel line for use IN the tank as far as I have determined.
Question #1: Uller, it looks like you have not replaced the in-line filter in the tank and have externalized your filter....if my understanding is correct, was the 12 inches long enough to connect fuel pump assembly to regulator, and have fuel pump assembly remain in lowest position possible in tank (i.e. as in stock set-up), or did you do a "splice" as it appears Ronin did when he externalized his fuel line filter in order to meet this positioning requirement ?
#2: Crankshaft....did you purchase that aftermarket line you sourced (likely from the automotive world) and if so, what length did you buy (re: fitted line ends issue) ?
#3: Ronin, it appears that you kept the stock corrugated fuel line in the tank and simply spliced it. Any thoughts on the comments above and/or the value of replacing corrugated line with Napa type immersible line? And what about the risk of kinking line when reassembling?
Thanks folks.....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 03-11-2013, 01:17 PM   #7716
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,058
FWIW- I used 2 pieces of the sumbersible fuel line to remove all the plastic lines in the tank. It was a royal PITA to get clamps on. That hose is much thicker than regular hose. Very tight on the housings. Clamp placement is critical. I noticed no kinking issues. When I go to put my shock back on in the next couple weeks I'll take things out for a couple of pics. I hope that helps some.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 03-11-2013, 02:19 PM   #7717
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,954
Wrong.
Same procedure for both.
If/when you upload a new FI map via tune ecu it automatically instructs the ecu to reset the adaptations, that's why you don't need to preform that step in that case.
Bruno T . is offline   Reply With Quote
Old 03-11-2013, 02:24 PM   #7718
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,549
I find burning the bike to the ground does wonders for resetting the ecu
Seth S
Seth S is offline   Reply With Quote
Old 03-11-2013, 02:33 PM   #7719
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,954
Or that . . yes.
Full reset .
Old 03-11-2013, 02:38 PM   #7720
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
I never had trouble with the kinking. I knew it would be problem putting the pump back in the tank so I was very careful. When ever I worked on the fuel tank, I removed it from the bike. this gives you much more space to get it wright.
I had every intention of replacing the line with some different line but as dad2bike said, it was very very difficult to get the clamps on the fuel line at the regulator. The line I had purchased would not fit with the clamps on the regulator. this is why I stayed with the stock line.
When I set up the external fuel filter on the 2008 in the UK, I knew how much of a PITA replacing the fuel line is so KTMMitch machined me an aluminum tube to replace the internal fuel filter. This is the easiest way to do it in my opinion.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 03-11-2013, 02:42 PM   #7721
Baja Dad
Baja Dad's Avatar
Oddometer: 1,976
IMS has the IN TANK fuel line They use it allthe time.
Call them they May sell it to you
800-237-9906 Talk to Steve
Old 03-11-2013, 03:48 PM   #7722
motoged
motoged's Avatar
Oddometer: 908
Thanks....uh....who/what is IMS?....Google gives 3 gazillion responses.
Just wondering because websites are a helpful "context" for such a call.
Ged Schwartz
Kamloops , BC
Old 03-11-2013, 03:55 PM   #7723
Velociraptor
TrackBum
Oddometer: 1,119
http://www.imsproducts.com
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is online now   Reply With Quote
Old 03-11-2013, 04:00 PM   #7724
motoged
motoged's Avatar
Oddometer: 908
Answered my own question with a call to Steve at IMS (the tank folks....I got it now).
Steve clarified that the hose they use in fuel tanks is simply a transfer hose that delivers the fuel from one section/compartment of the fuel tank to a separate compartment which houses the stock FI fuel pump assembly which has retained the stock fuel pump-to-regulator immersible-approved fuel line....
So..... the IMS hose is not to be used in place of fuel injection hose/line which needs to meet pressure demands (the Napa stuff is tested at 500psi).
So thanks for the link/info BajaDad.....but no go for that line for our purposes here
Ged Schwartz
Kamloops , BC
Old 03-11-2013, 04:53 PM   #7725
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 768
RIP Beaney.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is online now   Reply With Quote
Times are GMT -7.   It's 06:55 PM.
