03-11-2013, 02:42 PM
#7741 |
Oddometer: 1,214
IMS has the IN TANK fuel line They use it allthe time.
Call them they May sell it to you 800-237-9906 Talk to Steve
Thanks for the 2013 support:GPR Stablizers,Seat Concepts,Kriega.us, Precision Concepts, Acerbis, AME Grips,Rally Raid UK TLD, Klim,Oakley, Sidi-Motonation, Dunlop,ZLT Three Brothers Racing KTM,Multitool FOREST PLYWOOD SALES |
03-11-2013, 03:48 PM
#7742 | |
Oddometer: 527
Just wondering because websites are a helpful "context" for such a call.
Ged Schwartz Kamloops , BC '96 GS 1100 '04 450 EXC '09 690 EXC Baja '05 Baja 06/07 Baja 08/09 BC Alpine Single Track |
03-11-2013, 03:55 PM
#7743 | |
TrackBum
Oddometer: 457
2009 KTM 690r Enduro in da house 2002 RC51 SOLD 2010 KTM 990 Supermoto R |
03-11-2013, 04:00 PM
#7744 |
Oddometer: 527
Answered my own question with a call to Steve at IMS (the tank folks....I got it now
Steve clarified that the hose they use in fuel tanks is simply a transfer hose that delivers the fuel from one section/compartment of the fuel tank to a separate compartment which houses the stock FI fuel pump assembly which has retained the stock fuel pump-to-regulator immersible-approved fuel line.... So..... the IMS hose is not to be used in place of fuel injection hose/line which needs to meet pressure demands (the Napa stuff is tested at 500psi). So thanks for the link/info BajaDad.....but no go for that line for our purposes here ![]()
03-11-2013, 04:53 PM
#7745 |
Africa, Africa
RIP Beaney.
2012 KTM 690 R 2010 KTM 990 R (Sold) 2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905 2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557 |
03-11-2013, 05:00 PM
#7746 | |
Oddometer: 1,214
I thought it would help.
03-11-2013, 05:27 PM
#7747 |
Oddometer: 527
No need for apologies....we are all trying to sort out these ideas and issues....and close up some issues with definitive solutions that we can all apply.
![]() I am far from being a good mechanic, but have certainly benefited from the guys here that know their stuff....and the others that, like me, learn from others as well as trial and error.
03-11-2013, 06:00 PM
#7748 | |
Shipwrek
Oddometer: 1,587
pulled my fuel pump yesterday, I have the filter, pump, I get the line from napa tomorrow... ![]()
03-11-2013, 06:28 PM
#7749 |
Oddometer: 558
![]() ![]() Rest in Peace Beany. My 690 will forever have just a little bit of you (his programming) in it. Best wishes to his loved ones.
03-11-2013, 06:37 PM
#7750 |
Oddometer: 527
Hmmmmmm ?????
Is that a kink I see in the fuel line by the clamps????? ![]() If so, I would think that the sturdy Napa line would not do that in that configuration. My thinking is to use the Napa line, externalize the filter, and use Noah's "in-line splice" to compensate for deletion of internal filter. This being said with the cautionary info that the Napa line makes applying the hose clamps a challenge. I would be using a FI line clamp which is a screw clamp with rounded edges less likely to cut into line than regular worm-style screw hose clamp: Proper clamp: ![]() Improper clamp: ![]() I haven't included the type of clamp that requires special tool....whatever they are called...
03-11-2013, 06:46 PM
#7751 | |
Oddometer: 558
Hi Ged!
Hope your trip went well.Quote:
I do have my fuel filter outside my tank in the location of the quick disconnect. I didn't route it lower like Noah or others (didn't need to add hose here) however, I can get my airbox out much quicker though. If you hold the pump & regulator in relation to one another as they sit inside the tank; while they are out of the tank, you will understand better why 1'-0 is enough. In reality, I only used 9" of the submersible line. You need just enough to allow you to work with the hose while it is connected to the regulator and sticking out of the pump opening of the tank. I believe that the shorter the better to stop kinking. If you want you can connect the entire length to the regulator, install it and route the hose out the pump opening and then trim to desired length. I originally left 5" of the return line still connected to the regulator and then used the remaining 3" of submersible line to connect it to the fuel pump cup cap. If this line kinks, maybe it isn't an issue????? If I were to do it over again, I would probably leave the entire return line and just use the submersible for the pump to regulator connection. It is a challenge to get the hoses secured to the regulator body as it is designed for a thin walled hose as Baja Dad mentioned. I made it work though and it has withstood over 5,000+ miles now. I believe I sanded a little and trimmed a certain spot of the outside of the hose. |
03-11-2013, 06:57 PM
#7752 |
bush league
Oddometer: 38
Anyone have a link to valve adjustments? I checked the 690 wiki but no pics. Thanks!
03-11-2013, 07:03 PM
#7753 | |
Shipwrek
Oddometer: 1,587
I let a dealer put in the fuel plate adapter for the safari tank... Thinking i'd be safer.... not ..... that set up lasted a season.. even a trip to Moab..The new pump came with the band clamps but only two, for pump and filter. the napa 3095 filter is 5/16, the pump is 1/4, the napa h209 fuel line is 5/16 I haven't seen the reg. yet I assume it is 1/4.... I have to figure how i'll come up with the difference on the high pressure line... |
03-11-2013, 07:17 PM
#7754 |
TrackBum
Oddometer: 457
Same here. I used some of his Tune ECU programming tips to get rid of the stalling issue with the stock ECU. I am running the Vortex now but my stock ECU still has his stuff in it. Terrible news........
03-11-2013, 07:31 PM
#7755 |
poser
Oddometer: 255
I missed the part about uploading TuneEcu maps. Thats good news!
