Old 03-20-2013, 12:10 AM   #7831
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,110
Originally Posted by JustBob View Post
Well then you've got a light bike...sorta. My GS's are both 475. The Ducati a bit less. All more than a KTM 500 or the 690. So your 425 lb Gixxer is a pig or a fairy, depending. It's all relative....my only point.
+1
My bikes have been two v-strom 650's at 480lbs ish, a Moto Guzzi Griso 8v at 540lbs or so, a 950 at 520lbs with bars, racks, skidplate etc., and now the 690 which feels like a toy. I'm going to do naughty things with it off-road when the front suspension is sorted out.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 03-20-2013, 01:17 AM   #7832
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,495
Sort of related
Originally Posted by DirtRideRoader View Post
Those that have removed their broken upper tank bolts, what is the easiest way to do this?
Seems like it will be easiest if I disconnect the opposite side and pivot the tank out of the way in order to drill a hole in the broken bolt to allow the use of an easy out bolt extractor.
I have put this off for far too long. Any suggestions would be appreciated.
If I've got the RR bottom tank bolt I shouldn't need to replace the stock top ones if they seem OK, or are the RR top bolts a must have?
MeinMotorrad is offline   Reply With Quote
Old 03-20-2013, 03:34 AM   #7833
fluff34567
fluff34567's Avatar
Oddometer: 1,092
from reading thru many posts here a lot of people buy the RR product and a lot replace the original cheese bolts for those with a better material spec as originals are crap.
try a 8.8 spec bolt instead - same for the lower bolt.
fluff34567 is offline   Reply With Quote
Old 03-20-2013, 06:05 AM   #7834
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,144
err, 8.8 is what i call coca cola can material :-)
The RR top bolts are sure stronger, but the side panels dont fit as they should with it.. I replaced them not knowing, but if i did know, i'd have stuck with stock.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 03-20-2013, 06:17 AM   #7835
fluff34567
fluff34567's Avatar
Oddometer: 1,092
sure there are harder bolts available but they are more brittle.
Old 03-20-2013, 06:21 AM   #7836
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 815
Does anyone else sell bolts that do fit better with the side panels?
sdd04 is offline   Reply With Quote
Old 03-20-2013, 06:25 AM   #7837
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,695
Your point that 475 for a STREET bike was light. That ain't the case.
Old 03-20-2013, 06:31 AM   #7838
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 807
OK you win junior. Now go joust at another windmill.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 03-20-2013, 06:32 AM   #7839
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,695
Sure thing gramps.
Old 03-20-2013, 10:17 AM   #7840
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
I never noticed this. In fact, you might be first person to ever mention this.
I really like the fact that there is a nut on the RR bolts and you don't have to rely on a torx driver. I also really like the fact that they don't break. I'll take "ill fitting" side panels over broken tank bolts any day.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 03-20-2013, 12:50 PM   #7841
Harpoonalt
Harpoonalt's Avatar
Oddometer: 295
I got your point right away!
Harpoonalt is offline   Reply With Quote
Old 03-20-2013, 01:07 PM   #7842
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,849
The difference in the RR tank bolts is not just the grade or strength of the bolts, if you look at there design they put the load on the bolt in a different way, that is the main difference.
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is online now   Reply With Quote
Old 03-20-2013, 02:01 PM   #7843
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 807
Vortex ECU settings
How can I safely change it to leaner without a dyno sniffer? Bike is my new to me 2010 690 ER with the Vortex ECU, FMF can and foam air filters. (The stock ECU is still there but I guess it's irrelevant...just along for the ride...right?)
It runs like a scalded dog. But it uses too much gas...between 35 and 38 mpg depending and I'm not the hardest rider around by any means. The three mixture settings on the Vortex are at 3-3-3, which is the leanest the instructions say I should go unless I have a sniffer. I don't.
The can exhibits a bit of black soot and a riding buddy said he could smell it....smells like too rich.
So I'm thinking to turn the three mixture screws to 2-2-2 and ride a tankful. Comments?
One other question. The 15 minute idle thing. After changing the Vortex, should I do the 15 min idle?
Thanks.
Bob Hancock
Old 03-20-2013, 02:13 PM   #7844
Velociraptor
TrackBum
Oddometer: 1,122
Thanks.
I don't think going from 3 to 2 will make the bike too lean. Do you know what maps are in the Vortex? With the Vortex no 15 min idle. I went back and forth with Vortex a couple of times to get the right maps in the right order for my bike with the map switch they offer. All good now. I am surprised the stock ECU is still there. There are two of them. If this ECU is still plugged in then it must be the smaller one. I would remove it. These days they put 5 maps for open airbox and 5 maps for closed airbox. I asked them to do an economy map too. Have not tested it yet.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 03-20-2013, 02:55 PM   #7845
motoged
motoged's Avatar
Oddometer: 908
Yep....my GS is a Fairy Pig:
But when I get on my 690....it is a Rocket Pig:
And when I get on my 450, it is a nuclear pig:
Just love riding those pigs
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
