Old 03-20-2013, 11:17 AM   #7876
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,671
Originally Posted by StevenD View Post
err, 8.8 is what i call coca cola can material :-)
The RR top bolts are sure stronger, but the side panels dont fit as they should with it.. I replaced them not knowing, but if i did know, i'd have stuck with stock.
I never noticed this. In fact, you might be first person to ever mention this.
I really like the fact that there is a nut on the RR bolts and you don't have to rely on a torx driver. I also really like the fact that they don't break. I'll take "ill fitting" side panels over broken tank bolts any day.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 03-20-2013, 01:50 PM   #7877
Harpoonalt
Harpoonalt's Avatar
Oddometer: 285
Originally Posted by JustBob View Post
Well then you've got a light bike...sorta. My GS's are both 475. The Ducati a bit less. All more than a KTM 500 or the 690. So your 425 lb Gixxer is a pig or a fairy, depending. It's all relative....my only point.
I got your point right away!
Harpoonalt is offline   Reply With Quote
Old 03-20-2013, 02:07 PM   #7878
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,743
Originally Posted by fluff34567 View Post
from reading thru many posts here a lot of people buy the RR product and a lot replace the original cheese bolts for those with a better material spec as originals are crap.
try a 8.8 spec bolt instead - same for the lower bolt.
The difference in the RR tank bolts is not just the grade or strength of the bolts, if you look at there design they put the load on the bolt in a different way, that is the main difference.
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 03-20-2013, 03:01 PM   #7879
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
Vortex ECU settings
How can I safely change it to leaner without a dyno sniffer? Bike is my new to me 2010 690 ER with the Vortex ECU, FMF can and foam air filters. (The stock ECU is still there but I guess it's irrelevant...just along for the ride...right?)
It runs like a scalded dog. But it uses too much gas...between 35 and 38 mpg depending and I'm not the hardest rider around by any means. The three mixture settings on the Vortex are at 3-3-3, which is the leanest the instructions say I should go unless I have a sniffer. I don't.
The can exhibits a bit of black soot and a riding buddy said he could smell it....smells like too rich.
So I'm thinking to turn the three mixture screws to 2-2-2 and ride a tankful. Comments?
One other question. The 15 minute idle thing. After changing the Vortex, should I do the 15 min idle?
Thanks.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 03-20-2013, 03:13 PM   #7880
Velociraptor
TrackBum
Oddometer: 1,107
Thanks.
I don't think going from 3 to 2 will make the bike too lean. Do you know what maps are in the Vortex? With the Vortex no 15 min idle. I went back and forth with Vortex a couple of times to get the right maps in the right order for my bike with the map switch they offer. All good now. I am surprised the stock ECU is still there. There are two of them. If this ECU is still plugged in then it must be the smaller one. I would remove it. These days they put 5 maps for open airbox and 5 maps for closed airbox. I asked them to do an economy map too. Have not tested it yet.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 03-20-2013, 03:55 PM   #7881
motoged
motoged's Avatar
Oddometer: 908
Yep....my GS is a Fairy Pig:
But when I get on my 690....it is a Rocket Pig:
And when I get on my 450, it is a nuclear pig:
Just love riding those pigs
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 03-20-2013, 04:10 PM   #7882
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 03-20-2013, 07:36 PM   #7883
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
Bob Hancock
Old 03-20-2013, 07:51 PM   #7884
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
I may have this wrong in saying that I still have the stock ECU. What I have is the Map-Select switch under the seat. I haven't done anything with it, so maybe the ECU (wherever it is) isn't there? The X10 ECU settings in the instructions say it's for the Enduro-Open airbox, release 4, 28-4-11.Vecu1. It then gives a list of maps. Mine is set at X10 position 1 which says "Power Map1 (Softer initial throttle). Other options are for Traction, torque, power with variIous descriptors. Right now I'd just like to get some better mileage without hurting the motor. Should I dial back the fuel trim settings on all three throttle ranges to 2-2-2? This gives Base minus 7.5%.
Bob Hancock
Old 03-20-2013, 08:00 PM   #7885
Velociraptor
TrackBum
Oddometer: 1,107
Maybe best thing to do is send an e-mail to Richard Muurling at Vortex in Australia with your question and all the details you mentioned here. He may take awhile to reply but he always gives informative answers.
richard@vortexcdi.com
If all the maps are for an open air box then the bike would run rich with the foam air filters.
The last option would be to send the Vortex ECU to Mike Tolle in California to get proper maps for your bike setup. He charged me $100 to do that so not cheap.
2014 KTM EXC 500
2002 RC51 SOLD
Old 03-20-2013, 08:03 PM   #7886
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
Thumb
Thanks for that. I'll contact Richard first.
Bob Hancock
Old 03-20-2013, 09:27 PM   #7887
bayarearider
Oddometer: 135
Issue with rear break pedal M10 special screw
After noticing a drop in rear brake pressure, when I removed this M10 special screw (KTM#76513057100) it was broken in half and the other half got basically stuck in the round piece ( looks like a nut) that's on the foot rest bracket. I then had it looked by a mechanic and he wasnt able to pull the rest of the broken screw out of it. I looked at the parts list and called KTM and went back and forth and concluded that the round nut like looking piece cannot be ordered separately and the only alternative is to order the entire right side foot rest bracket (KTM#7650303904401S). I have the cleanspeed break pedal if it matters.
Does anyone here offer any feedback on how to solve this. For now I have ordered the entire right side foot rest bracket. Below is the parts diagram from the manual. The part 6 is the special screw, part 4 are the 2 slide bearings and the screw goes into the round looking thing in the footrest bracket (if you follow the dotted line all the way to the footrest bracket).
Below is another view of the footrest bracket labelled as 17.
bayarearider screwed with this post 03-20-2013 at 09:39 PM Reason: added photo
bayarearider is offline   Reply With Quote
Old 03-20-2013, 11:25 PM   #7888
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 962
You do know that the bolt is left hand thread correct?
The Letter J is offline   Reply With Quote
Old 03-21-2013, 06:24 AM   #7889
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 425
any positive/negative comments about the cleanspeed brake pedal ?
http://www.cleanspeedeng.com/Brake%20Pedal.htm
cheaper than the RR version and different milling design.
Have it and it's awesome. I've crashed on that side since installing it and it held up beautifully. I'll take this opportunity to remind you of the reverse threaded bolt that holds the lever on.
Jeff
FriedDuck is online now   Reply With Quote
Old 03-21-2013, 06:48 AM   #7890
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 577
I had to find that out the hard way... Broke tools and bolts, and had to redrill and retap the footrest bracket to be able to re-use it.
Another disadvantage of the setup (2008-2009) is that when the rear brake pedal joints get's dirty, it will tighten the bolt, making it very difficult to remove later.
The newer rear brake pedal (I think 2010 and on) uses a different system, still left hand thread but with bushings to prevent this problem.
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos is offline   Reply With Quote
Times are GMT -7.   It's 08:36 AM.
