Old 03-24-2013, 08:21 AM   #7921
allroadrider
Oddometer: 115
Safari Fuel Tank
Anybody put one of these on lately and have the printed instructions
I purchased one of these from an inmate and he didn't have the instructions, I have looked at the various post's but would like to have a copy of the instructions if any one happens to have one laying around and could scan them or fax them to me
ARR
allroadrider is offline   Reply With Quote
Old 03-24-2013, 08:28 AM   #7922
ramjet
ramjet's Avatar
Oddometer: 2,132
KTM 690 Auxillary fuel tank-suggestions please
I like the concept here:
http://www.advrider.com/forums/showp...postcount=6004
Can someone tell me how it connects/drains to the rear main?
And where to get the fittings for the replacement air filter?
Any other thoughts?
Coffee first. Then your mundane socialist bullshit.. Lenny Bruce
ramjet is offline   Reply With Quote
Old 03-24-2013, 08:58 AM   #7923
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
ARR
Here's the online set.
http://safaritanksusa.com/downloads/...structions.pdf
Print what you need.
Here's some helpful pics from another rider.
http://picasaweb.google.com/dpeward/...44625479545170
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 03-24-2013, 10:28 AM   #7924
Noyah
poser
Noyah's Avatar
Oddometer: 400
Any other thoughts?
No pumps, it will empty front Alutank first.
You see the fuelline in the last picture going back to the filler neck and connects there.
Airfilter is easy, the EVO2 filter won't work tho, I use an uni filter.
KTM 690 Enduro R
--> My Movies <--
Noyah is online now   Reply With Quote
Old 03-24-2013, 04:30 PM   #7925
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
ARR
Be sure not to open the safari tank until you have ridden about 60 miles on the main tank otherwise the main tank will overflow
Seth S
Seth S is offline   Reply With Quote
Old 03-24-2013, 09:03 PM   #7926
allroadrider
Oddometer: 115
Safari Tank
This is what I needed another example of what a great site this is
ARR
Old 03-24-2013, 09:31 PM   #7927
motoged
motoged's Avatar
Oddometer: 907
Safari Tank:
Rinse out new tank several times to clean out plastic shavings, mouse turds, and other crud before installing...
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 03-25-2013, 05:22 AM   #7928
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,084
I put an inline filter between the safari and the main tank...
I just finished changing the fuel pump in my bike as it died in my driveway two weeks ago... and set code 4long one short.
taking it apart.. don't forget to unplug the air box sensor, when removing the airbox, don't forget to remove the frame grnd before you flip up the main tank as they will break...
I found the fuel line was kinked from the dealer when he put the fuel line adapter on the main fuel tank...
I used the wiki690 web site http://ktm690.info/index.php/Main_Page for the recipe for the napa/ ca cycle pump... worked out wonderfully... not likely to kink again because of the rubber lines... vs plastic. I also found it was quite easy for the power lines to fall off the fuel pump when reinstalling so I put a zip tie right at the connections.. hopefully won't fall off...
dealer 400$ for fuel pump
ktm690.info recipe less than 200$ including shipping..
The bike is running again, but the bars got bent somehow last year, so the controls are all removed and the new bling is now on order for that...
shipwrek12001 is offline   Reply With Quote
Old 03-25-2013, 07:00 AM   #7929
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 157
May I ask what filter you used between the Safari and the main tank? Thanks
Bumpaman is offline   Reply With Quote
Old 03-25-2013, 08:31 AM   #7930
dunefreak
dunefreak's Avatar
Oddometer: 93
I'm having an issue with coolant venting out of my overflow bottle tube. I already replaced the radiator cap and made sure the tank wasn't overfull. I seem to remember reading some guys were having this problem. Mine is a 2012 and has been doing this since new. Any ideas? I'm tired of coming home after a ride with coolant all over my right boot.
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 03-25-2013, 08:39 AM   #7931
daveknievel
daveknievel's Avatar
Oddometer: 418
Mine did the same thing. But it wasn't coming out the hose. It was running down the hose because of a hole in my rad.
daveknievel is offline   Reply With Quote
Old 03-25-2013, 10:23 AM   #7932
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Anybody CONUS have a set of .56nm 485mm springs sitting around they would like to unload? Even .59nm would work for me.
I finally got to serously ride Ginger after the rework of my shock. I put the 1-5/8 Kouba link back on first. Just so I could freaking touch the ground at least with my toes. I've decided to order in a 1" Kouba Link to keep from trashing my pan and tank. This chunky boy hits really HARD.
Now the front needs a bit more spring to match up with the rear. My valving is great, just a bit more spring.
Tom
My2Wheels
690 WIKI
Old 03-25-2013, 11:37 AM   #7933
dunefreak
dunefreak's Avatar
Oddometer: 93
I haven't seen any leaks. The radiator looks ok. It's like when the bike gets warm it just slowly vents and fills the overflow bottle up and then pisses some out the overflow tube.
Old 03-25-2013, 12:15 PM   #7934
Seth S
Seth S's Avatar
Oddometer: 4,454
could be a bad radiator cap that is not holding the pressure. If this happens you will overflow more liquid. Bad radiator caps are more common than you might think.
Seth S
Old 03-25-2013, 12:21 PM   #7935
dunefreak
dunefreak's Avatar
Oddometer: 93
I just replaced it. It's brand new.
Times are GMT -7.   It's 03:35 AM.
