Old 03-31-2013, 08:44 AM   #8011
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
Originally Posted by slidefighter View Post
Dirty_Sanchez: You say you passed on the Akro remap and it runs really well. What are you running, please?
P.S. Geaux Tigers (Class of '67...yes...'67!). It's even worse, I started in '59 (slow learner), Billy Cannon was a senior...
Thanks...
Lee...
I have the '12 model, UNI drop in air filter, canisterectomy/desmoggification has been done with the 22k ohm resister applied where appropropriate, Wings slip on with the large diameter sparkie installed, and have the stock map loaded up which came on the bike as delivered.
It ain't broke, I do the 15 minute idle reset with large seasonal/ambient temperature changes, I have never gotten a code, it doesn't stall, it makes me smile, a whack at the throttle lifts the front in 3rd, and I ain't gonna remap the thing.
Keep in mind for all practical purposes, I'm at sea level here in south Louisiana at 13 feet. The low fuel light usually comes on right around 125 to 130 miles, so your experience may vary.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 03-31-2013, 11:10 AM   #8012
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by RoninMoto View Post
I dropped my bike first day I owned it. Kickstand sunk into grass. The clutch leaver bent at the "break off" notch at about 35 degrees. I then cut the break leaver about 1cm past that notch and it makes a great short lever.
you could do the same pretty easily... minus dropping the bike.
Same story here ...
Originally Posted by thorinoakenshield View Post
So what coolant are you pimps using?.
Propylene Glycol.
Could be from Caterpillar, "Engine Ice" (http://www.engineice.com/) and many others ...
It will lower your temp by around 30 degrees. It is compatible with water, but not with Ethylene Glycol (which is the most standard coolant)
Evans Coolant is far better, but it is not compatible with water and other coolants. Evans Coolant will make you radiator last forever (most probably longer then yourself ) because of the absence of water and water vapor. It is not water based, but some kind of alcohols if I remember well.
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 03-31-2013 at 11:20 AM
Gros Buck is offline   Reply With Quote
Old 03-31-2013, 11:34 AM   #8013
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,005
Originally Posted by fluff34567 View Post
has anyone found a good adaptor to swap the crappy S2 35w bulb for a H4 55/65w bulb ?
or is changing the headlight the only way to go.?
I was lucky enough to pick up a 2008 headlight from another inmate. That's the best solution IMHO. Plug n play.
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 03-31-2013, 12:27 PM   #8014
fluff34567
fluff34567's Avatar
Oddometer: 1,063
yep thats what im looking for also.. if anyone hears of one available let me know. doesnt matter if its in the US, i have ways and means of getting it to europe. !
fluff34567 is offline   Reply With Quote
Old 03-31-2013, 01:24 PM   #8015
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 336
Thanks for the info, D_S. I'm effectively at sea level too at only 79' in South Carolina and have a virtually identical setup (still waiting for the Wings to come in). Good info to know, thanks for that.
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 03-31-2013, 02:28 PM   #8016
slidefighter
Oddometer: 336
Am I missing something? Been trying to look at some of the Slavens Racing videos on YouTube and I can't get any of them to open. Have they been moved somewhere else, or closed out or something?
Ararragghh! Edit: Found 'em alive and well at: http://www.slavensracing.com/video
Lee...
Slidefighter
Old 03-31-2013, 05:40 PM   #8017
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 760
side case protection
sooo, water crossings on concrete can be slippery, and one should not try to change direction to miss the flailing copperhead on the water's edge.
Once again proves wearing gear helps as no issues other than bruised pride.
That said, I can now see how the brake pedal can take out the side cover..... Mine indented with the pad teeth, but did not break anything.
G-It, or Carbonati for protection?
Any preferences?
sdd04 is offline   Reply With Quote
Old 03-31-2013, 06:00 PM   #8018
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,419
Wonder how if it protects against snake bites.
Albie is offline   Reply With Quote
Old 03-31-2013, 06:07 PM   #8019
sdd04
Oddometer: 760
Funny you should mention that as the thought that crossed my mind when I first saw him was that I was glad I had my SG-12's on lol. After the fall, it was, pick up this silly thing and get out of here! Good thing these bikes are light.
Old 03-31-2013, 06:13 PM   #8020
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,005
... Good thing these bikes are light.
A nice big dose of adrenaline does wonders for human strength.
Tom
My2Wheels
690 WIKI
Old 03-31-2013, 06:27 PM   #8021
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
Anyone had an issue with a touchy/grabby rear brake? I've lowered it as much as I can but still manage to lock it at the slightest provocation. Any way to make it less sensitive? Or lower further than stock adjustment? I have the CleanSpeed lever.
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 03-31-2013, 06:34 PM   #8022
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,005
Mine was grabby to the point of killing the bike in turns. I slid the Master Cylinder all the way back. No change to the lever level. I now go down much further before engaging.
Tom
My2Wheels
690 WIKI
Old 03-31-2013, 06:38 PM   #8023
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 447
You have to cut the threaded end of the pushrod shorter.
That's what I did and it's in a good spot.
I got the idea from Roadracer_Al .
thorinoakenshield is offline   Reply With Quote
Old 03-31-2013, 06:45 PM   #8024
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,005
The pushrod on my 690R isn't threaded. The ones on my RFS bikes are.
Tom
My2Wheels
690 WIKI
Old 03-31-2013, 06:45 PM   #8025
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 795
I did that. No help.
Bob Hancock
Times are GMT -7.   It's 10:27 PM.
